FE Wannabe
11-16-2009, 08:09 PM
Hello all,
I was going to add the Etti cap board to my Etti 150, but I do not have enough room in my N2 Sport Hydro. So I figured I would just add a few axial capacitors between the positive and negative battery leads feeding the ESC.
I noticed the 35V 470uf caps on the Etti ESC are about a 1/3rd in size to the other axial or radial 35V 470uf caps from other manufacturers like Rubycon or Xicom.
So my question is - Do all 35V 470uf caps have the same capacity to protect my ESC or are the larger ones more capable?
I see that the Etti cap board contains 10ea of the 35V 470uf smaller caps.
Would I have to add 10ea of the larger Rubycon 35V 470uf caps to match the capabilities of the caps on the Etti or would a smaller number work?
I know more is better, but do I need 10ea of them to protect an 7.4V N2 Sport Hydro?
I have heard that the larger 35V caps like the 1000uf and 2200uf have a higher resistance than paralleling a bunch of smaller caps, so I assume that is not the best way to go either. I am just trying to figure out the best way to go with my limited real estate.
Any info would be appreciated.
Thanks,
Brad
Thanks,
Brad
