View Full Version : Electric motor power comparison
mickvk
11-13-2009, 04:54 PM
I have viewed a bunch of information about electric motors. I always found it hard to understand which ones were better, worse, faster, slower, stronger or weaker based on kV ratings. Nobody ever lists power! After a while I started comparing max watts - so I converted watts to HP and graphed it for common boat motors.. This may not be a perfect science but at least it gives some relative view of how a Neu 1515 compares to a Feigao XL. I also threw in a reference to nitros since I had it handy. Interesting, huh?
http://www.krocko.com/ftp_bucket/forum_image_upload/HP-chart2.jpg
Ub Hauled
11-13-2009, 05:08 PM
nice graphs, thanks for your time in developing this.
One question though, are you posting results for the NEU motors based on 80% efficiency as well?
NEU motors have an efficiency higher then 80%, some of them go over 90% (as per FlyDMA), the lowest efficiency I've found was 85% (as per FlyDMA)
NitroVal
11-13-2009, 05:19 PM
I think a stereo guy explained it best to my as to why a cap is almost always needed in a stereo system and how you can almost never judge a speaker by its advertised ratings. He said electricity from any power source is delivered "dirty", meaning that there is never a constant or steady flow. It is always fluctuating with temp, conductivity of wire, surges, etc.. That could be my only guess as to why there really is not a whole lot of HP ratings on electric motors.
mickvk
11-13-2009, 05:32 PM
Yeah, I did all the continuous and peak watts times 80%. Sorry.
sailr
11-14-2009, 07:23 AM
I have a real problem with using WATTS as a good comparison. WATTS is a moving target. Watts is Volts X amps. If you change the amps or the volts, you change the watts. If the motor is not very efficient or if you have a draggy driveshaft, too big prop, etc. etc. etc. then the WATTS will go up and be wasted as heat. A lot of companies who advertise watts just multiply the max volts times the max amps the motor can take. That is totally unrealistic.
I learned this a long time ago in the brushless aircraft world. Far more important than watts is THRUST. The actual work the motor will do.
Just my opinion guys.
11-14-2009, 07:33 AM
Nice graph. How did you get the numbers on the feigao motors?
mickvk
11-14-2009, 12:04 PM
What up Sail... Yeah, it's not perfect, but to me the max efficiency amp rating is useful as a rough way to do a relative comparison. For example, in my first boat I got a 9L in a 32" Delta Force that over heated like crazy. I was way over the 68A max eff line. Now I have a better understanding why. And yes, you are absolutely right, we can't always work at the voltage where "max" is measured at, so yeah, it's not a dyno. But it shows me if a motor is just a little different than another or very different...
domwilson
11-14-2009, 12:12 PM
This is interesting. But I am curious, how did you arrive at these numbers? Was this thru actual testing?
mickvk
11-14-2009, 12:23 PM
That's a good question... I forgot I had to derive that. Since they rate Max Efficiency Amps, kV and RPMs, you can take max RPMS - 50,000 and divide by the kV. For a Feiago 540 9L for example, that's 50,000RPM / 2713kV = 18V. Multiply that times Max Eff Amps of 68 and you get 1224 watts. That's close to another place I had that series of motors listed at 1300 max. Then 80% of that for heat, then divided by 745 watts per HP, you finally arrive at 1.3 HP.
I don't really mean for this to be anything official, just my swag at understanding what's relative across motor choices.
I'd appreciate any input.
mickvk
11-14-2009, 12:58 PM
But motors dont make thrust, propellers do, so I guess that would quantify an entire setup.
I have no idea idea how thrust would be derived or measured though, do you?
ozzie-crawl
11-14-2009, 07:40 PM
i have access to a proper rc dyno, and hopfully over christmas will get some testing done
the dyno is for 2-4 wheel drive,will do 1/5 -1/10 scale
but it also has the capacity to bolt the motor straight up with out it being in a vehicle
will be testing a few diffrent electric motors in vehicles and straight bolt up :buttrock:
questtek
11-14-2009, 08:27 PM
A test system for actual boat thrust I have used is a digital fish scale attached to my dock and a line at the CG of the boat thru a Y harness. Since I also have an Eagle Tree set up I can work the fish cale registered digital force against RPM, amps, volts, watts, etc. Granted this is a static test but it simulated to the best of my knowledge, true lbs of forward force. The digital fish scales go to 50 lbs and are only about $15 at WalMart. When I was expermenting with larged ducted fans on cats this test set up proved very valuable. Joe
ozzie-crawl
11-14-2009, 09:11 PM
thats the problem with boats static testing is to inaccurate for real world applications as there is to many things come into play
if you test 2 diffrent motors and one is producing more watts than they other can meen bugger all when actully running the boat
if you data log a run and you see your producing x amount of max watts this really meens little in performance as max watts is produced when the motor is under max load,usally under take off or accelerating out of a corner etc. when the boat is actaully running full speed the amps drawn hence watts produced is a hell of a lot less
so a boat producing 1500 watts or around 2 hp under load may only produce 800 watts or just over 1 hp when running at full speed
just my thoughts
sailr
11-14-2009, 09:28 PM
On a boat, no, but it's real easy on an airplane. A digital fish scale secured to the tail with a stake in the ground and let her rip. You try different props until you hit on the right amp draw for the motor/battery combination. You just read the pounds and oz. of thrust on the digital fish scale.
