View Full Version : What prop for the widowmaker ?
lucozader
11-12-2009, 12:43 PM
which prop hsould i get ?
bmaxx
11-15-2009, 01:30 PM
The Octura M435 and Y535 props seem to be working good for me now. I am using a Mamba max esc and a 3cell LiPo.
lucozader
11-15-2009, 03:10 PM
thanks, the m435 is on ebay, i think i'll try that
i got a new esc that can take 3 cells
any other tips on setting up the boat ?
widow*shaver
01-04-2010, 04:07 AM
40x52/3. I flipped upside down after the second strait away. I was glad someone with a fishing pole was able to give me a tow. The prop is made for a larger shaft so some modification is needed. I used two cut pieces of brass tubing from my local hs. inserted the small tube into the larger one, then notched the end with a small file. The shaft nut does not go in all the way so some lock tight would keep it from falling off.
Jeff Wohlt
01-04-2010, 10:32 AM
The newer 3 blade 435 or whatever it is. My buds boat is fast with it.
OshkoshMono
04-30-2010, 11:50 PM
Yep! The best prop for this boat! :buttrock: I've tried quite a few. Best one I've found anyway....
