View Full Version : my brushless proboat apache 24
SweetZ28
11-10-2009, 02:42 PM
I am happy with it now!:bounce:
http://www.youtube.com/watch?v=sibSxqJVlUc
Rumdog
11-10-2009, 06:58 PM
Smooth running!
Brushless55
11-10-2009, 11:17 PM
Looks good man!
did you check temps? I bet you could run a bit bigger prop
SweetZ28
11-10-2009, 11:22 PM
Looks good man!
Thanks I have the 3300KV motor and my prop was 31.5mm the esc ws 79deg and motor bairly over 100 deg but my 3S battery got hot 130 to 135deg but i ran it till 3.4 lipo cut off...I am going to grind a cf prop down to 30mm or 29mm it will make the battery run cooler ... and you never know it could get faster also.
If it don't work out well i could just run it a min or so less and it should be ok.
Z
Brushless55
11-10-2009, 11:38 PM
sounds a little odd to me that your esc is cold and your motor warm but your battery is hot?
SweetZ28
11-11-2009, 12:00 AM
Yea i know ... well i got the 3000 lipos on e-bay for $22.00 shipped each they say there 35C?
here is the link to them..
http://cgi.ebay.com/EC-POWER-3000mAh-35C-11-1V-3S-LIPO-li-po-BATTERY-AKKU_W0QQitemZ180431019236QQcmdZViewItemQQptZRadio _Control_Parts_Accessories?hash=item2a0286dce4
Rumdog
11-11-2009, 09:41 AM
take temps 2 minutes in. If the batt is cool, youre prob running too long.
Jesse J
11-11-2009, 10:11 AM
runs real nice, yes good batts are good. might go 2P if possible to get you mah ~ 5000 or so. Really like how she rides, congrats. could you post some shots of the hardware?
J
SweetZ28
11-11-2009, 11:47 AM
J
Hi thanks i think i posted some shots in the apache section i will see if i can get the URLs to it for you.
THANKS
Hi here look through this there are some photos there are more in different spots in the apache section also.
http://forums.offshoreelectrics.com/showthread.php?t=10491
Brushless55
11-11-2009, 02:00 PM
that was my first thought, possibly getting hot running down to lvc?
SweetZ28
11-11-2009, 03:57 PM
Yes most likely but i am going to try the new 29mm prop and see how that goes...it may cavatate to much and if that happens back to 31mm and just time my run until lipo cut off comes on and subtract a min and i think i will be good.
Brushless55
11-11-2009, 05:36 PM
I'm thinking, the 29 will just spinnn and spinnn
SweetZ28
11-11-2009, 08:28 PM
We will see I have to try it.
Z28
FE Wannabe
11-11-2009, 09:23 PM
Z28,
Glad to see that it is running good! Those Apache's can be fun once you get them moving twice the stock speed or better.
How is it turning for you under power? I am supposing a lot better than with the outdrive doing the turning. I know mine was hooking badly before I went to the separate rudder. I think I may need to trim a little of the bottom of my rudder, because it is pulling a little to the right when going straight, and I think it may be the extra drag of the long rudder.
Have fun with the fine tuning!:rockon2:
Brad
Brushless55
11-11-2009, 09:45 PM
Z28
Love to know..
keep us up to date :beerchug:
SweetZ28
11-11-2009, 10:03 PM
Z28,
Brad
Hi Brad that is funny I was thinking my steering rudder was to long for this boat also...It turns nice i guess but i feel it may be better shorter?
See the photo in the apache part on the board ..first picture on my brushless post.
Feels to me like the rear of my boat sticks in like a slot car in a slot.
SweetZ28
11-11-2009, 10:04 PM
Love to know..
maybe i can go thursday and run it.
will Let you guy's know for sure.
Unsullied_Spy
11-12-2009, 02:38 AM
Nice vid (I gave you a 5/5 :wink:). Could you post up some good pics of it inside and out? I am trying to help my brother convert his Apache and it's already gutted, just looking for a little inspiration on a few things.
SweetZ28
11-12-2009, 09:12 AM
Hi look here there is some info and photos...there is more info in the apache section.
SweetZ28
11-12-2009, 05:10 PM
:thumbup1:Brushless55 you hit the nail on the head!!
Look in the proboat section in my brushless thread.
adam777
10-29-2012, 03:42 AM
hi friends . i have a RC boat last month. and i have a battery problem with it.it got a rechargeable battery with it. but it does not do longer than 2 or 3 minutes. what should you suggest me to do.i have cahange the battery with my frieng but still the same problum.
Adam smith
adam.smith402@yahoo.com
nitrotek (http://www.nitrotek.se/)
