View Full Version : Getting an antenna out of a carbon fiber hull...
vvviivvv
11-08-2009, 03:11 PM
Whats the best way to do it, i was told you can't simply drill a hole through and screw the antenna socket in since the carbon conducts electricity well and would lead to interferance whats the best way to do this and is there any type of antenna designed around this?
i was looking at these two antenna's...
http://shop.rc-electronic.com/e-vendo.php?shop=k_emcotec_e&SessionId=&a=article&ProdNr=A73000&t=11&c=427&p=427
can't link to H&M so...
H & M with Antenna turn, 30 cm white
Low-cost, removable antenna from H & M with a screw cap
Prototype:
Antenna of your receiver to reduce by 30 cm before commissioning!
NorthernBoater
11-08-2009, 07:57 PM
What kind of radio are you running?
jcald2000
11-09-2009, 06:31 AM
The ant. MUST be completely insulated from the hull,ex. drill a hole in the hull and run the ant. wire thur a piece of silicon tube about 1" long so the wire is not touching the hull.
vvviivvv
11-09-2009, 11:49 AM
using 40... so as long as the aerial doesn't touch the hull?
