View Full Version : whats need a good turn fin setup for the villain ex?
Jcarlton
04-09-2007, 08:07 PM
modding my villain ex up need to know good turn fin setup? any suggestions?
hookedup
04-09-2007, 08:51 PM
ive seen pictures of other villains with these.http://www.offshoreelectrics.com/proddetail.php?prod=kyo-94471 or you could make your own, something like this. check this site for a FAST villian.http://www.lousfastrc.com/click on the P offshore or Q mono tabs.
Jcarlton
04-09-2007, 10:49 PM
thankx just picked a set up!!
NorthernBoater
04-09-2007, 10:58 PM
I also found that any brushed motor that requires changing the brushes is a bad idea for the Villian Ex if you leave the battery box in. The box makes the motors very difficult to unscrew.
RMZDADDY
04-09-2007, 11:15 PM
I've never had a problem changing motors out in that boat, I just use a L shape allen wrench to break the capscrews loose, then a magnetic bit of the same size to back the screws all the way out with my fingertips. I can change out both motors in about twenty minutes.
Jcarlton
04-09-2007, 11:18 PM
not gonna put the brushless in the villain ? thats my next project. RZM ive got the m tronics genessis 3000k brushless motor , with esc . what boat should i use?
Jcarlton
04-09-2007, 11:19 PM
its the brushless for the e-maxx got for a steal 155 on ebay new esc motor only has 3 runs!!
RMZDADDY
04-09-2007, 11:38 PM
You talking a single brushless motor/esc? I thought of maybe putting a dual brushless in the villain but the cost for two motors and two esc was too much. I really think 30mph is about as fast as that hull design can handle and remain at all stable. in the vid I posted on your other thread I had a gps on the villain and it reached top speed of 28.1. With a single brushless setup I'm sure you could make it fly!
RMZDADDY
04-09-2007, 11:47 PM
did you check out the vid of the "mod traxxas villain" under the videos link at the top of this page, it's a pretty crazy fast brushless setup!
Jcarlton
04-10-2007, 12:06 AM
im saving the brushless for another boat project . juat wanted to know a good handling hull to go from?
