View Full Version : Octura Aluminum Props
Christaphason
10-14-2009, 10:35 PM
Has anyone tried these on a brushless setup? It clearly states it is not recommended for brushless set ups.
But, im wondering why isn't it recommended?
NitroVal
10-14-2009, 11:33 PM
Aluminum doesnt have the same strength as the beryllium/titanium yada yada stuff that their normal props do..
mikesf
10-15-2009, 04:27 AM
Yes but balancing them is not a health hazard as beryllium...
http://en.wikipedia.org/wiki/Beryllium#Toxicity
Team FFRB
10-15-2009, 06:21 AM
I have used them as test props only.
Before to long they will blow a blade off from the stress.
10-15-2009, 08:39 AM
The aluminum has more negatives than positives for BL power.
- The blades cannot be sharpened enough and the result is non-optimal performance - prop walk, low efficiency.
- The castings are porous and don't polish or smooth well
- The weak nature of the metal can result in easily-thrown blades - dangerous!
- Aluminum is not without its own health concerns - it is a known neurotoxin. I'd rather have berrylium poisoning (treatable) than alzheimers!
http://www.med.nyu.edu/patientcare/library/article.html?ChunkIID=164929
http://www.angelfire.com/az/sthurston/alzheimers_and_aluminum_toxicity.html
Bottom line - follow the manufacturer's recommendations.
Christaphason
10-15-2009, 06:45 PM
Thanks, i figured it was a strength issue, just wondering if there was anything more to the reasoning.
Thanks.
