View Full Version : 5mm to 1/8 motor coupler
soulreaper
10-12-2009, 12:52 AM
I have a Rio EP. I plan on going brushless. Most of the brushless motors that I have considered have a 5mm shaft. The Rio has a 1/8 flex cable. I need a motor coupler that will fit. I checked the couplers Offshore has, but they dont have the one I need. Does anyone know where I could get one? :confused1:
Jeff Wohlt
10-12-2009, 09:18 AM
I make the set screw style. If this is going to be a hot boat with this upgrade then I would be happy to make more for anyone needing them.
Is the flex a true 1/8" or is is a 130 cable? 130 cable is around a 127 dia. If you can check the true id of the 1/8" cable I can get them on the money. Try some digi calipers and let me know.
soulreaper
10-12-2009, 06:18 PM
Thank you so much. I will find out and let you know. Thanks again.
Reaper:thumbup:
soulreaper
10-12-2009, 08:20 PM
"Got Rpm" from RCU said that Offshore Electrics Octura Coupler Flex hex 5mm to .130 would work. Im going to give it a try. Wish me luck. Thanks
Reaper
soulreaper
10-17-2009, 12:22 PM
Update, I got the above listed coupler in the mail yesterday. I works like a charm.
Reaper.
