View Full Version : Delta Force 33 47MPH flip
LiPo Power
09-20-2009, 08:47 PM
This is the damage after acrobatic flip/turn/dive etc on my delta force 33. Too bad I have no video of it but pictures are here...... Jesse!!!! Where do I get this part new??? :bowdown:
I need to fix it before next Saturday....
Cheers
Robert
http://www.youtube.com/watch?v=BhP9bWxHa78
Raydee
09-20-2009, 08:51 PM
CHeck out the second half of this vid. EverythingRC's Delta 33" doing som nice acrabatics at about 60mph. He also bent his rudder but the actual blade. I didn't get any pics of the blade.
http://www.youtube.com/watch?v=434zgBgm1NI&feature=channel_page
LiPo Power
09-20-2009, 09:15 PM
Yap! That is just like watching my boat going in to the air.....
Rumdog
09-20-2009, 09:28 PM
Why not just bend it back?
It was a sight to see when it flipped, rolled, bounced etc.
Hey Robert, Were is the GPS pic of my new personal best of 58.6Mph today on 4S?????
LiPo Power
09-20-2009, 09:38 PM
What picks of personal best of 58.6MPH ????
Was the boat red or yellow????
Comming up soon.....
Did you respond to my e-mail quastion for you?
LiPo Power
09-20-2009, 09:47 PM
Here it is my friend.....
Two pictures for everyone with little trouble seeing it.....:tongue_smilie:
Good Job!!!
LiPo Power
09-20-2009, 09:50 PM
I have try this but it cracked at the mounting to the boat spot so I still need a new one....
properchopper
09-20-2009, 10:59 PM
I've had the same bracket bending problems; got a piece of thick aluminum angle, a little sawing, drilling, grinding and no more bent brackets. :smile:
Jesse J
09-21-2009, 12:42 AM
sorry robert, I deleted it cause of the subject line: put something that makes me know its you. I get way too much spam and don't open stuff unless I am sure its from valid sources.
I am not sure where, I got that bracket from Nate, so I am not real sure of brand. Thought it was speed master, though. I would personally go with the propperchopper solution, will get it fixed quick too!
good luck.
LiPo Power
09-21-2009, 08:12 AM
good luck.
Thank You Jesse
properchopper
09-21-2009, 08:54 AM
Robert, contact Ray Fuller at : fastel1@cox.net. I got a bracket (like the one you bent) from him. Tell him you want the extended bracket for the Speedmaster .21 mono rudder.
LiPo Power
09-21-2009, 09:19 AM
Thank You.
I will.
Robert
LiPo Power
09-21-2009, 09:45 AM
Ray has one that is 3 1/4 x 1.1/4 I am not sure if that is what you have in mind.
I need this Before Saturday. Would like to take my DF to
http://www.wellesleyabcfestival.ca/
DOBY may be able to help me on time. Ray would ship one by global priority mail but I do not know if this part will get here on time. ( propably not )
Thank You for help, good staff
Robert
LiPo Power
09-21-2009, 09:48 AM
This is where the problem is after trying to make it straight...
properchopper
09-21-2009, 10:45 AM
It seems, by looking at the picture, that the bracket failed at it's weakest point-where material was ground off to allow it to clear the trim tab. A replacement bracket, ground similarly will eventually fail as well since the long bracket has a lot of leverage exerted on it in high speed turns. If I was in your position [boat?] and short of time, I'd find a welding shop that would weld on some reinforcing material at the point of fracture, also a small triangular shaped gusset spanning the right angle on top of the bracket. End result may not look pretty, but would get the job done. The trick is to find a friendly welder who does aluminum welding-most welders can do this. Plan "B" would to get one from Ray & hope it arrives on time, ['tho you'll have to grind off the corner to get clearance, same as your current one]. Plan "C" - I might be able to find my old bracket-same as yours, which is a little tweaked. I'll hammer it straight, grind the corner like yours, and ship it to you. I live in California so it may get to you no sooner than one from Ray, who is in Arizona.
LiPo Power
09-21-2009, 11:01 AM
My friend DOBY may have sollution to my problem. I need to wait till eavning to see what he has for me. I will update on it. In the mean time I will go and visit local hardware store to see what's avaliable.
Thank You for your great help on this.
LiPo Power
09-25-2009, 11:38 AM
Hi Tony
How much for plan C please?
Thanks
Robert
properchopper
09-25-2009, 12:02 PM
Robert, I'll look for it today. No charge for the bracket & Ill see how much shipping is. Problem is that It'll bend again where the corner's ground off. A better solution would be the heavy duty bracket extension I made ; I could make a version of it for you, drill out the holes to attach the rudder-holding piece and attach the piece that bolts to the hull -should be the same hole pattern. I'm racing this weekend so today's race prep day. After the weekend I can get started. Again, no charge except shipping.
properchopper
09-25-2009, 12:08 PM
Robert, after looking at the picture of your setup , Plan C might be easier to match up to your boat. It'll need some reinforcing at the corner; I'll come up with something.
LiPo Power
09-25-2009, 12:17 PM
Very kind of you, thanks a million. I will take the single bracket but please do not grind the corner. I think I will fit it in without grinding it off. Check my next picture of custom made bracket I have on my boat right now. There is enough room for not to grind the corner. Check other pictures for details of dimentions. I would also like to try your new design bracket. If it's not too much to ask please let me have one of them too. I will pay shipping. Do not have to be sent fast. I can wait at this point. Once again, THANK YOU and next Tim Hortons when you are arround here is on me...
LiPo Power
09-25-2009, 12:19 PM
Few extra pictures for you....
properchopper
09-25-2009, 12:22 PM
I'll get started next week :biggrin: The pictures do help, thanks.
LiPo Power
I LIKE THAT, SOUNDS GOOD TO ME, THANK YOU! :banana:
Flying Scotsman
09-25-2009, 12:32 PM
You are the man Tony, apart from that bald idiot who tries to video fast moving FE boats.
Love you both,
Douggie
LiPo Power
09-25-2009, 12:40 PM
One more detail. You can see that I can use all 4 holes to mount this bracket. Right now two of them have tape on the top but it's ok to use them. Thanks.
PS
We are also racing this Saturday at:
properchopper
09-25-2009, 12:48 PM
Love you both,
Douggie
Carefull Bro, we need to pick his brain for hydro secrets :spy: :w00t:
properchopper
09-27-2009, 03:00 PM
Robert, Here's where I'm at so far. The stock "replacement" bracket, once I found it and straightened it out didn't look like it would survive on it's own. I've made the angle reinforcement bracket to bolt on to the original bracket [ I'll hit the hardware stote tomorrow to get some nice bolts]. The whole deal should bolt right in place on your boat. Might be a slight interference situation with your cooling line. Easy to plug & move if need be.
LiPo Power
09-27-2009, 05:21 PM
This looks sweet.... I like it. If you have this bracket done shoot me some pictures so I can plan for water cooling line changes. Thank you.
Robert
Jesse J
09-28-2009, 12:21 AM
I am glad to see you are enjoying yourself and that the checkered babe is getting some racing action. I just felt bad keeping her cramped up in the shop collecting dust. Great work Robert!
J
properchopper
09-28-2009, 01:36 PM
Almost done. Holes are my hardware's "signature" ; as my driving skills in racewater leak out of the hole in my head on the driver's stand every time :tiphat:
LiPo Power
09-28-2009, 06:20 PM
J
Thank You Jesse... This boat I like... :smile:
Winter time we have Delta Force nock off project going.. ha....
We=Me, Doby, Daniel
LiPo Power
09-28-2009, 06:21 PM
Can't wait to see this on my boat....
Thank You...
properchopper
09-28-2009, 06:25 PM
Done. PM your address & I'll get it out tomorrow. :biggrin:
LiPo Power
09-28-2009, 06:42 PM
Wow, that was fast...
LiPo Power
09-28-2009, 06:45 PM
PM sent...
LiPo Power
09-28-2009, 06:46 PM
Any chance for few pictures in order for me to get the boat ready if I need it?
Cheers
Robert
properchopper
09-28-2009, 07:03 PM
Robert, the four outermost holes should line up perfectly with yours. I got the bracket from Ray with the innermost holes drilled, but the four outside holes are standard Speedmaster spacing. [ I had to drill the inside holes to line up with the holes on my boat which had the standard spacing ] You'll have to back out the two inside stainless clamping bolts to get access/clearance to mount the bracket, then screw them back in once the bracket's mounted to the boat transom. I threaded [cut threads] to the inner bracket to make this easy. You may have a clearance issue with your water line, maybe not. If the new bracket interferes with the trim tab, grind the bracket [or trim tab] some.
LiPo Power
09-28-2009, 07:08 PM
Robert, the four outermost holes should line up perfectly with yours. I got the bracket from Ray with the innermost holes drilled, but the four outside holes are standard Speedmaster spacing. [ I had to drill the inside holes to line up with the holes on my boat which had the standard spacing ] You'll have to back out the two inside stainless clamping bolts to get access/clearance to mount the bracket, then screw them back in once the bracket's mounted to the boat transom. I threaded [cut threads] to the inner bracket to make this easy. You may have a clearance issue with your water line, maybe not. If the new bracket interferes with the trim tab, gring the bracket [or trim tab] some.
Roger...
properchopper
09-29-2009, 04:44 PM
Just mailed it including customs declaration. Hope it gets there soon :thumbup1:
LiPo Power
09-29-2009, 04:48 PM
So fast, thank you!
LiPo Power
09-29-2009, 05:15 PM
Everyone!!!
Please have a look at this e-mail and respond!!!
I hope Jim do not mind me placing this respond for all of you to see it...
Re: Shippment
Quote:
Originally Posted by LiPo Power
Hi
Thanks for sending this so quickly. How much was it and how do I pay you back please?
Thanks
Robert
No payback needed. Glad to help. If someone else needs a favor you can help with, pay it forward.
Tony
__________________
2006 LSO Record Holder
2008 P-Mono & P-Offshore 2-Lap Record Holder
2009 P-Sport Hydro 2-Lap Record Holder
LiPo Power
10-09-2009, 04:40 PM
Tony
Bracket is here now. Thank you for your help again. Looks tough. I will have one more chance this season to test it out before my boat will sit on the shelf to wait for another.
Cheers
Robert
