- ProBoat's new 29" Mystic Brushless catamaran
- Proboat mystic pnp now available ?
- A Main shows the Mystic in stock now
- Got her in my hands!
- mystic 29 hatch
- NEW MYSTIC - What batteries are you running?
- Drive shaft stub question
- Mystic - blown ESC
- Can't decide
- Motor/shaft collet for Mystic 29
- New Mystic bummer
- Break away rudder options anyone?
- Mild upgrade motor?
- Brand New Pro Boat Mystic 29 up in smoke !!!!
- High pitch noise in the drive system
- Seaking 180a ESC timing for stock mystic setup ?
- Stock 60 Amp ESC setup?
- Newbie Mystic Repower Questions
- Mystic 29 battery placement???
- What ECS for Mystic 29?
- Miss Budweiser Mystic 29--what's the best prop?
- Double check your connectors!!! (important info)
- PB mystic 29
- got scared of the pb mystic esc problems...
- New guy with a new boat
- inside hull past the syrofoan bouyancy
- Problem with new Seaking 180/4074 Leopard2200kv . . . need help!
- First impressions
- Bouncing, Prop choice and no reverse questions
- Need some repair help here
- No power to the motor
- mystic esc
- Need a little help here
- Mystic stock prop
- Hate my Proboat Mystic
- Mystic Stock Motor Specs? Does anyone Know?
- Quick question on new Mystic I just got
- New guy - battery advice for Mystic
- New guy - charger advice
- ESC Timing
- Proboat mystic love it
- what motor
- Max speed?
- Mystic Upgrade
- Help me guys!! Torn between motley crew and mystic
- pro boat mystic smoking!! need some help
- Just ordered a Mystic, have some questions!
- Mystic PNP build
- Trim Tabs on a cat?
- Fastest setup for 4s
- Stock esc questiion
- just recieved my mystic!
- Strangest thing I've ever seen....
- Mystic 29" drifts left at low speed
- Proboat Mystic 29 ~Runaway~ What to do now ?
- Proboat Mystic 29 with x642 prop ? What you guys think ?
- New mystic owner help needed
- New Proboat Mystic 29 need help please .....
- Help the amp draw
- New mystic owner help please,please
- noise in Mystic 29
- Coupler size
- motor cooler size
- Batteries and speed are related
- Out of Control Mystic
- Proboat Mystic Modifications and Setups
- Best prop and expected speeds.
- proboat 1800kv
- Proboat mystic looks gone, as the new blackjack comes through?
- Lipo Shield with UBEC
- Noob Owner Broke the Prop shaft Cable, Lost the Prop etc...Need Help
- More Voltage or More Motor
- Is there an Upgrade for the steering servo on the Mystic 29 BL?
- Battery Size and weight.
- Mystic and battery match
- Mystic PNP
- Mystic Died
- The "best" general all around setup for the Mystic
- Mystic Strut Bushing Install (Kintec Racing 3 Hole Bushing)
- First run with mystic.Weird noise from drive train.
- mystic questions
- How do i insert teflon tube?
- Strut Height (bouncing) and Drive Dog Distance Pics
- HELP with tuning mystic 29
- Bullet prop nut
- proboat transmitter waterproofing
- Touch Up Paint
- Are these batteries ok?
- Mystic with Prather 220+stock motor
- which speedo for 6s mystic project
- Dual Rudders on Pro Boat Mystic
- Anyone try a Leo 4092??
- New mystic owner here
- Another new Mystic owner
- Just got my Mystic....
- proboat mystic 29 question
- pb mystic rudder bushing question
- split hull
- just bought a mystic
- I need help with motor and esc
- what prop should i run with a leo 4074
- fpv proboat mystic 6s.....
- Just bought me a mystic
- 2 or 3 blade
- Got my mystic
- Mystic bushing
- Mystic maiden run
- looking for more speed in my mystic.
- these were Miss geicos
- Proud New Mystic Owner with battery question - 16.8v ?
- Setting up Seaking 180 with stock proboar radio
- Mystic stock motor on 6s or maybe just 5s?
- Could This Cause Problem
- 24 inch mystic
- Dual Rudder on Mystic?
- Replacement Propeller strut for Proboat Mystic
- Mystic servo torque rating
- Tacon 4074 motor upgrade
- HELP PLEASE mystic leo 3674
- Ride pads and blue printing???
- My plans that need to be perfected!
- suggestions wanted; replacement hull
- New system installed!
- teflon liner
- PVC stand?
- Mystic with a 2150kv tacon and seaking 180
- New Mystic
- new boat broken
- Repair or replace damaged, split hull
- Prop choice.... 3674 2200kv, SK180 ESC. 4S?
- New Video 46mph on open water
- Mystic motor and ESC upgrade, need advice!
- Mystic 29 White paint Match?
- New mystic video from today
- Mystic rebuild..
- Having some issues with my Mystic 29
- what prop to use on my mystic 29??
- Please help a NOOB
- Looking to upgrade motor mount for mystic
- Anyone replaced the steering shaft rubber boot?
- Wow! No activity in the ProBoat Mystic forum since 2015?
