View Full Version : Proboat Impulse 31 Deep Vee Q & A
- New Proboat Impulse 31" Deep Vee
- whats going on nothing on the new impulse yet
- picking mine up today
- I got an Impulse, did you?
- Virgin Impulse 31 Run tonight
- Newbe with a Impulse31.....Questions....please help!!!
- Impulse 31 Hatch mounting holes - Sealing them up...
- Impulse on 3S what do I need?
- how would i run 2 4s packs on this boat and still be safe
- Something to look out for.
- impulse 31 2s in series or 4s in paralell
- 31 leaking still
- Dual Rudder
- How to clock speeds?
- Modded Impulse very first run!
- over sized tubing
- hey guys im trying to get my order together
- Proboat Impulse 4s2p or 5s2p Gens Ace Configuration??
- Impulse 31 ESC - Reverse?
- Impulse 31 OR Traxxas Spartan
- Removing shaft... Have to remove prop strut as well?
- What size is the prop 1/8 or3/16?
- Prop choice
- Impulse 31 totalled.......
- Post run battery voltage difference
- question on impulse 31, turnigy nano tech's and esc
- 28.7mph on 2S
- Proboat Impulse 31 - Turning Fins Mounting Question
- Drive dog pin snapped
- Need new flex shaft
- flooded stuffing tube - why?
- Tab mounting screw - Sheared off head - Disheartened to say the least
- Proboat Impulse 31 ESC Hard Timing Programming
- How does this boat compare to a Super V?
- Impulse 31 Prop Mod Opinions
- Run time with NIMH
- Impulse 31 leaking..
- Whats the Plastic tubing for in the baggie?
- Also the White coating around the driveshaft is flaking off
- Impulse 31 questions very dissapointed
- Performace between proboat brushless systems
- WOW!!! This boat is AWESOME!!!
- question with stuffing box placement
- What are known issues with the impulse 31?
- Describe your Impulse 31 using one word
- Turn Fins
- Help?,...Basic stuff for some....BUT....
- Hatch broke. How to reinforce
- Impulse 31 battery concerns
- pro boat impulse new power system suggestions
- Antenna housing
- New Motor
- running boat on 3s
- My Impulse 31 misfortune
- Impluse w/X642
- I KNOW........."MORE PROP ?'s"
- strut alignment
- Rudder slop
- New Vid
- Impulse 31 porposing at full throttle.
- Newbie Questions - Just got an Impulse 31
- Programming card
- 1500 vs 1800 motor
- Finally got to run her!!!!
- Shear Pin Too Strong on Rudder?
- Going to try 6s on stock setup wish me luck
- 2 batteries vs. 1 battery...
- Hull issues???
- Running single 3s
- Hydra 120
- Adjustable trim tabs?
- any solid motor upgrades for the impulse 31 yet??
- Fiberglass composit
- AWG wire size and connectors for a warmed over "31"...
- Using 45 amp speedcontrol with 1800 kv motor
- Antenna ?
- Max Reliable Top Speed
- New esc water cooling nipples blocked
- Firts run on new impulse:(
- Whats your thoughts.
- Any Immediate Upgrades???
- Wondering if I can reinforce with CF???
- Overtemping problems
- Longer turn fin........tighter turn???
- Gutted my Impulse....Here's what I'm doing!
- Replacing TX batteries..
- turnigy or castle 120a esc
- Impluse 31 Cut Off Voltage from Factory????
- Reliable,fast,sport running motor???
- Batteries
- water proofing a esc
- Why upgrade to 5.5mm Bullet connectors?
- More Speed questions
- Installing OSE Upgraded flex cable........
- extra cooling for Impulse
- Does the rooster tail tell a story
- First GPS run
- Need help with Impulse 31 6s build
- New Stickers
- 60 mph setup???
- Flipped my Impulse on the last run of the year....
- LiPo Question
- Method for changing the prop
- New Impulse 31 owner
- Newbie question. New to RC boating and looking for information
- Need opinion on battery purchase
- Impulse help!
- Impulse 31 setup
- Can I run 4S batteries on a stock boat?
- Intermittent power issues
- 2-part foam
- drive dog pins fragile on impulse 31, similar to Stilleto.
- Upgraded prop, now have some heat issues
- Repairing stress cracks ???
- Impulse 31 motor upgrade
- Stock ESC isues
- Impulse 31 esc programming
- Impulse 31 bouncing baby boy
- Turnigy Marine 180A/ program card
- impulse 1800 kv motor
- leopard 4074 2150 kv
- ProBoat Impulse Strut Crack
- Impulse 31 Flex shaft corkscrewing
- Servo arm
- extra capps on stock 60a esc?
- Grease hole?
- 45C-5800-2S2P-Hardcase genes ace?
- lipo question 30C-5300-5S1P-18.5v-parallel
- Running in circles
- upgrades
- Impulse 31 stock esc
- Newbie ESC Water Cooling Question
- Dual-Rudder Kit Installation on Impulse 31
- Leopard 3674 2200kv
- strut help
- Reinforce the hull
- My First run
- pro boat inpulse newbie question.....
- My first paint job on impulse 31
- newbie that needs advice!!!!!
- Painting tip on the impulse 31
- battery question....
- New life for the impulse
- Is anyone racing this boat?
- NEW Pro Boat Impluse 31 RTR V2
- FIrst night with a new lady
- Servo upgrade
- Suggestions for a 3 blade prop?
- Can someone tell me if it's motor or esc???
- Looking to get 30 mph out of 3s.
- NiMH Packs in the Revolt
- Impulse 31 Twin Setup?
- CC hydra 240 hv
- Hit 36 mph running 3s
- Problem with Impluse 31 motor mount!
- Boat transporting question...
- Rudder Push Rod...
- Is there something wrong?
- Fresh Paint, First Day on Water, OUCH!!!
- Thrust Bearing
- Race Setup Help Needed
- Impulse 31 Figerglass issues!!
- New impulse 31 owner
- Impulse Dual rudder?
- Leopard 4074
- Impulse 31 leaking water
- Death of an Impulse
- impulse hull
- Impulse OSE upgraded HD driveshaft question
- proboat impulse 31
- Impulse 31 Deep-V BL RTR V2
- I'm still in love with my 3s setup
- Sr300 rx ?
- New Impulse 31 V2 on the way!
- Flexshaft Rattle Inside Prop Strut - and other issues.
- Pro Boat Impulse V2 collet
- Proboat impulse 31
- Replacing servo mounts
- What do you think about this setup?
- T-180a placement
- Picked up a new impulse for $220 shiiped
- Impulse 31 help!! Any info will be much appreciated
- Impulse 31 Crash Damage and Repair
- Tested a Grim 42x55 on bone stock impulse 31
- CNC Prop for IM 31
- The speed of Imp.31 v2
- New paint on my "HOT" IM31
- Got a new proboat impulse 31 v2 need help
- The optimal timing for 1800 kv motor
- newbie with Impulse 31 v2 some questions and damage
- The stock prop.
- Looking for Impulse 31 Setup Recommendations
- Leak at rear of new impulse
- Nice surprise!
- Imp.31v2, Dual rudder system
- Dual rudder alignment, need help
- imp 31 basics
- (Newb questions)- can the Factory 1800kv motor handle 6s by using a upgraded 180esc?
- IM31 W/90amp esc, NEED Leopard suggestion
- looking to get the best performance out of my impulse 31 v2 PLEASE HELP ME
- impulse 31 esc question
- NiMH Battery Question
- ul1 motor
- hi need help in setting up mu 31 impulse
- New Owner First FE Boat!
- Prop. question...
- Flex shaft breaking
- Cutting Flex Shaft
- Please help(new in boating)
- .187 flex shaft problem...
- Setup question
- Help with HD flex cable and 5mm -187 coupler.
- Prop for Proboat Impulse 31
- Hull Damage
- Hi I am new to the rc boat hobby I just got a pro boat 31 impulse
