- Spy Shot of a new Prototype Hull!!!!
- New AquaCat
- @@@ The Wait is Over VIDEO of the Prototype Aqua Cat @@@
- Aquacraft Motley Crew Cat
- unique idea using a motley crew
- Vid of the Motley Crew
- Motley Crew Graphics
- Motley Crew Cat...Coming Soon to a Workshop Near You.
- Lets See Who's Paying Attention.
- Pics of the Motley Crew
- 1st Run of the Motley Crew
- motley boat
- Aquacraft Motley Crew - Diesel
- 1st run of motley crew
- First out today w/ MC and the MG boats
- First Impressions??
- dealing with hobby services
- Motley crew
- Motley crew
- Dissapointed with Motley crew
- Motley Crew "Fix"
- First run
- 2nd try with motleycrew
- Motley Crew thoughts.....
- broken shaft again
- Just recieved my new Motley Crew today
- Collet question
- motly crew race water and speed
- Race Prep on my Crew Hull
- Motor swap
- new parts from AC
- 60.4 MPH New Motley Crew
- Newbie with a few questions
- Water tubing
- MC flexcable fix?
- Esc blowout
- What prop with 2300kv
- MC first batch
- Motor Upgrade/Outrunner???
- Carbon Filled Propellers
- Scooped up a MC.
- x440 or x442 On Stock Setup
- What's a better prop for sport running?
- Race Results
- Good upgrade motor
- AQ Motley Crew - please check your water pickups before your first run
- Motley Crew Questions.
- Battery Question
- How hot is to hot
- Just bought new Motley Crew --- not very fast ??
- What strut depth would be best to get the nose up?
- Death wobble
- new motley crew run times?
- Prop shaft broke
- Thank you Aqucraft for losing a brand new prop!
- Whats loose
- prop suggestion
- 6 out of 10 rating on this boat. Handles great, seriously lacking quality!
- anyone running 5s on the stock speedo?
- need help on installing water jacket
- need speed help mc
- Just got new Motley Crew have a few questions
- Running a little too warm I think...
- motley crew batteries??
- Upgraded water cooling system....
- Where can i get a balanced prop for my motley crew?
- Is this true?
- Motor lead wire and plug solder issue
- Will this prop be ok in my Motley Crew?
- traxxas spartan motor and esc in mc
- Bad strut bushing
- airplane esc?
- Check your stuffing tube is still glued in!
- Short video of Sept 5
- what prop with a 2074 1800kv leopard and T180 esc???
- motely crew 68.4 mph
- Dual Water Pickup Rudder
- Motley Crew Leopard 4074 install
- Does this lipo look swollen of puffed at all?
- what do you think of this set up
- Why is the cut-off so LOW?
- Motley crew motor question
- What is inside the hull of the Motley Crew?
- Motley Crew Back ordered
- I gotz me a question (about props)
- Painted MC?
- First time MC boat story Debacle , with some questions
- Water outlet
- how to make your motley crew haul butt !!
- What all do I need to run a motor like this
- Water jacket leaks
- size of water lines??
- Can I strip down boat and add my own paint?
- Adding expanding foam inside hull??
- correct Prop choice...
- the stickers...
- ul1 2030kv instead of the 1800kv...
- beautiful
- Question about teflon liner and strut bushing in my Motley Crew
- Im happy with my MC...
- mc
- Cold weather affecting speed?
- First Rc Boat...First Run..whole 6 mins of it...LOL (PICS)
- What changes were addressed with motley crew?
- What size lipos to run? What C rating?
- My MC flips over....Driver or Boat?
- Stuffing tube and shaft alignment issues...pics
- Tested my new set-up today, and gotz me a question.
- I think my teflon liner is spinning in the shaft....
- Newbie.. Fuel tubing in front of prop nut?
- Avoid losing flex shaft and prop?
- Stock ESC and motor?
- Kintec upgraded flex cable
- AQ MC Bobbing at WOT...Video Help.
- 2700kv Outrunner motor & 60a esc for MC from seagad stock upgrade or downgrade?
- I'm going to "foam" my hull
- Looking for a second boat?
- Thinking MC but need some affirmation...
- Radio range?
- First run of my Motley Crew
- Finding a few extra mph?
- strut
- Motley crew gold aluminum cooling jacket
- Motley Crew / Decals and Tupperware
- Is this how its supposed to look when its running VIDEO
- Finally scored one- setting up for NAMBA P-Ltd Cat Sprint race
- Motley Crew Hull Repair
- Hello, count me in!
- Traxxas TQi for a Motley?
- Awesome Motley Video at HD Flyer
- This is one slow forum
- MC Handling question.
- MC esc issue?
- 5s lipo on motley crew .
- Foaming and fiberglass work **new guy**
- Flex Shaft
- Question on 120 esc
- Brand new MC got a total of 1 foot before flex broke
- Prop install help
- strut bushing to tight?
- Brushless Motor In MC
- Strut Height?
- Take a look please/setup help
- really thinking about buying a MC need some extra info before I do
- Third 1800kv motor dead in less than a year - what alternatives would be better?
- Need help on what all to buy?
- Blue Printing Motley Crew
- Which Prop?
- Temps
- My Motley Crew with 4 runs is up for sale
- Motley Crew Needs Speed!!!
- Motely Crew Going Left!
- 5.5MM connectors versus 6.5MM
- How to tell the difference in motors
- Motor mount Replacement question, will this work?
- Why not foam the "floor"
- My "prepped" Motley Crew
- Help with "bouncing"
- My Motley Crew Re-Build
- Need help ugrading my Motley Crew
- Best battery for stock MC with future upgrades
- My winter project, good or bad idea?
- Just bought a used MC. Need some info.
- To much prop and the wife says stick with this boat. Suggestions?
- I bought a Motley Crew off the F/S area, and I need some help
- Is this hull totalled??
- New MC with water issues!
- New MC not working HELP
- Best Rudder Replacement w/ watr P/U?
- Motley Crew Maiden dissapointment
- WTF is wrong now
- Bought a used MC, and did a complete rebuild
- Motley Crew finally runnin faster thanks to OSE members (VIDEO)
- Motor for MC
- Motor or Battery
- Help rebuild my MC after esc fire!
- Added another to the fleet
- Winter project? Need advice...
- MC or Blackjack 29
- Please help with setup
- Motley is dialed
- Decals or paint job?
- reset. my stx and rx seting
- MC high speed set up needed???
- Question about a motley crew boat...
- Base line setup for stock mc?
- MC Build, Castle 2400kv set-up and suggestions.
- ЗАВОДСКОЙ ГИБКИЙ ВАЛ
- How Fast are you running?
- How to replace stuffing tube?
- Seaking 180 problem
- Battery, Speed Control, and motor 101
- Motley Rebuild
- Help me tune my stock Motley Crew please
- Help With Motley Crew That Stopped After 20 Second First Run
- gutted motley crew
- Added a second water pickup
- MC running on one 4s or two 4s in parallel
- Newbie help
- what's everyone's struts measurements?
- Comparing MC and Revolt stock motor and ESC amp draw
- What size stuffing tube for motley crew?? 9/32??
- Just ordered a motley crew. Have some questions
- Anybody run castle spartan electronics?
- Add 2nd water cooler line to motor
- Return of my MC with Heat!!!!
- Prop questions
- Sharpening skeg
- What GPS do you use?
- Motor/Esc/battery temps
- Will running a 3s on one side and 2s on the other screw up balance?
- UL1 Motor 147 Degrees ESC & Battery Connections 108 Degrees MC Race Setup
- new to boating waiting on my motley crew to come in questions
- esc not arming
- Lucas oil ;some mods
- Lucus Oil Extra Flotation Needed?
- Does the Motley Crew hull require blueprinting to run flat?
- Drain plug alternatives?
- Lucas Oil sponson blueprinting
- Finally decided on batteries
- Motley crew flex shaft length?
- madian voyage of motcrew with smc 6000 2s lipo ran great till impact with smthing
- aquacraft lucas oil stock/factory part cables?
- How to repair damaged front hull tip
- Lucas Oil FE Cat water pickup and cooling outlet
- Lucas oil water cooling
- Flex cable length : Is this normal???
- can i use a seaking 4800kv
- I was told and ignored
- Bit the Bullet
- 3 of the best teams in offshore
- MC/LO cooling tube kinked from factory
- Lucas Oil + Grimracer L42x66 = no go!
- Is this setup safe?
- Lucas Oil strut adjustment
- some help needed with motley crew
- Wow, didn't know the Lucas Oil could go so fast in (nearly) stock trim!
- Question for Grimm
- lucas oil hull
- lucas oil
- M Crew Rudder repair. Tips wanted
- Lucas oil hull cheap?
- What prop should I get? Lucas oil
- Flex cable question
- Upgrade motor and esc?
- Lucas Oil / Motley Crew AirFoil on OSE
- Motley Crew Air foil installation
- My Review of the Lucas Oil / Motley Crew AirFoil by Hug Racing
