View Full Version : AquaCraft SuperVee 27 Brushless Q & A
Pages : 1 2 3 [4]
  1. new sv27
  2. New SV27 Coupler - Some Questions
  3. Painting SV27
  4. motor starts smoking on the bench help guys : (
  5. SV 27 upgrade motor is "coughing"?
  6. supervee 27 noob
  7. SV27 Motor Smoke
  8. got a few questions .
  9. Cooling
  10. Outrunner in a SV!!!
  11. SV27 New Setup
  12. motor/esc question
  13. SV27 42x55 Results
  14. rounding the rudder
  15. supervee 27 leopard 4074 high volt
  16. Crack in Back / Supervee Rudder Bracket
  17. My SV27 Rebuild
  18. Sv-27/Stiletto outboard
  19. Hull upgrade
  20. SV27 hull restoration
  21. Losing prop and locknut, need a new locknut.....
  22. V955/3 Prop
  23. motor bearings
  24. sv25-1/2 project
  25. SV27 strip down and rebuild
  26. Stuffing tube question
  27. First Run Today
  28. Polished the SV hardware
  29. trouble with futaba 2PL 2.4GHz Radio System
  30. New paint and some upgrades.
  31. A New Look for a Fav Boat
  32. super vee problems
  33. stock rx explode why
  34. Almost two yeas and i cant get the thing to go.
  35. First Supervee run on Lipo's and new 2.4GHz Radio- A couple of problems
  36. SV thrust bearing install
  37. Help needed with Nitro Conversion
  38. Boats running good now I want to start chaning things.
  39. Northern Beaches in OZ
  40. Brass Stuffing Tube
  41. MY SuperVee 27
  42. sealing holes in transom
  43. SV27 Water Jacket Need Help
  44. supervee 27 extreme leopard 4074 2000kv 6cell lipo
  45. super vee 27 water jacket
  46. Help with upgraded SV setup
  47. run today
  48. super 7 motor
  49. supervee 27
  50. SV27 strut
  51. SV 27 tell me what im doing wrong
  52. Luv my yellow supervee/superflip
  53. Super vee 27 battery trays
  54. Self righting SV27 - it works!
  55. just won a stock supervee 27 on ebay!
  56. just won a supervee 27 on ebay!
  57. supervee 27 newbie owner
  58. SV 27 strut
  59. Changing deans for 5.5 or 8mm bullet connectors on nimhs batteries?
  60. My first FE build
  61. setting up liposhield in sv27
  62. SV 27 motor upgrade to Leopard 3674,Does the esc need upgrading as well
  63. Still none the wiser..
  64. sv27 ......pics of your electrics layout please
  65. Ammo motor slower than stock?
  66. Strut will not come off...
  67. Prop Shaft Bushing (AQUB7884) doesn't fit over upgraded shaft
  68. Cold solder joints?
  69. Batteries way too hot!
  70. Think the motor seized up in my SV27
  71. Kintec Racing upgrade hatch w/sealing foam?
  72. Shortening leads motor to esc
  73. supervee27 in the uk
  74. sv27 my first run...few q's
  75. sv27...velcro wont stick!
  76. 40 mph, so far....
  77. Want to prop up without drawing too many amps, help?
  78. supervee 27 questions ( new guy )
  79. learned a valuable lesson about the tape....
  80. Back in the Scene - My 2007 Supervee 27
  81. sv27 upgrade
  82. Help with steering
  83. just a quick vid of my boat....
  84. sv27 hull crack
  85. sv27 rudder
  86. sv27 rudder
  87. Supervee 27 RECOMMENDATIONS for prop with 2200kv or 2600kv
  88. Test decals on my SV prior to my custom paint. "Badass Beer"
  89. Performance ?
  90. Quick video we took today of our SV27's
  91. Supervee battery question-2 batteries
  92. supervee 27 fast sucker =)
  93. Turnigy B3650-1500 Brushless motor
  94. Thinking of going to 5.5 bullets
  95. face lift / tune up for 27 to 27R have the I got the best bits ????
  96. Speed setup for SV27
  97. Super vee build proposal
  98. super vee 27 build proposal.
  99. Motor & ESC replacement
  100. Battery Straps, Removing Stock Plywood Battery Mounts in an SV-27
  101. problem with new ESC
  102. I know nothing.
  103. aquacraft L36/56 brushless
  104. Tunning friends SuperVee 27
  105. 60 amp ESC from tower
  106. Sv 27, Collet Losing Flexshaft, Pictures
  107. Supervee 27 with 2030kv Motor
  108. ESC Programing card
  109. sv 27
  110. Problems arming the turnigy aquastar 120a
  111. Problems w/ arming
  112. Brushed the cob webbs off the sv27
  113. SV 27 stock motor and controller Max voltage?
  114. new motor for supervee
  115. supervee take off problem
  116. SV27 Bare Hull Rebuild Questions
  117. supervee 27 6s lipo
  118. Smoked 60A AQ ESC - Questions.....
  119. SV27 rudder and stinger fitment problem on another hull
  120. SuperVee 27 battery question
  121. Supervee 27 hatch latch
  122. Supervee 27 rudder blade cooling pick up
  123. Check list to get back up and running
  124. Cooking 2 cells of my Nimh battery while running my SV27
  125. Hull strake stress cracks
  126. Electrical Box Smell like Ammonia
  127. 16.8v on a Supervee 27
  128. Supervee on single 4S = Superfun
  129. Cracking at the seams.. New haul recommendations??
  130. Help removing the SV27 rudder out of the bracket
  131. SV 27 Prop Recommendations
  132. Aquacraft 45amp esc question
  133. Lipo Shield/Lipo Saver Question
  134. Reverse on a SuperVee 27
  135. new boat owner supervee 27 got questions??
  136. supervee 27 ? bad rx?
  137. supervee perfect ?
  138. Supervee 27 4s video
