- Turn fin
- SV Motor Mount?
- newbie in need of help please
- upgraded flex coupler
- self righting super-v kit
- Going Lipo need some help.
- Hobby king lipos
- ESC Interference
- Supervee rebuild
- My first lipo sv 27 run!!(Video)
- New driveshaft tube (stuffing tube??)
- Tape the Hatch
- Hello
- new SV27 owner...a couple quick questions.
- Fine tuning a SV27
- Broke a flex shaft
- Positive strut angle
- 30c lipos
- Finally Broke 40!!!!!
- What speed should i be getting?
- deans or what
- Few pictures of my old SV
- Strut Bushing
- SuperVee strut length
- epoxy or polyester
- Crashed my SuperVee
- Etti 150 With Feigao 540
- Want a GPS to record my speed
- Leaves getting caught on rudder
- motor getting really hot
- Dang Turtles!!!!!!
- Ready to take it up a notch
- hey guys! new member and soon to be sv27 bl owner with questions
- sv27 motor dimensions needed
- New Member- First rc boat-pics
- Stick it to 'em!
- A Noob's Setup/Handling Problems
- just getting serious with FE boats
- New to the Boating World have a few ????
- SV27 Questions?
- Strut angles for diff props.
- Lipo Question for a Rookie
- SV27 Motor Upgrade Questions
- Sv motor?
- New Motors?
- FE in Charlotte ?
- Motor beeping
- Turn Fin Question ?
- super vee motor failure
- My new SV
- Receiver box
- SuperVee 27 N or BL?
- SV27 stinger question
- cheap lipos
- Who has the best Lipos
- Stock Aquacraft ESC?
- leak through drive shaft tube
- Motor getting hot stationaire drive
- SV 27 drive shaft tube hits cable coupler
- Aquacraft SV 27 anodized hardware
- Conector ??
- Charge at field or home?
- Looking for Help
- Does the SV27 has a teflon liner in the stuffing tube?
- ammo motors
- SV27 ESC Won't Arm
- Setup questions for brand new SV27 brushless
- LiPo Question
- supervee on 8s lipo!
- Smoked a new SV 27 Motor!
- SV 27 Prop
- New Lipos
- Supervee27 ?
- Lipo length for SV27
- Question on flex shaft tube
- Servo Boot For Hull?
- LVC or NEW ESC
- speed
- Good Props??
- Stock SV27 ESC and 14 cell NiMH TROUBLES!!!????
- Grimracer propeller
- Hull reinforcement
- SV 27 brushless - No water appears at water outlet
- will this work
- SV27 Rebuilt
- Thanks for such an informative forum
- Fix-a-flat for flotation
- Re SV 27 Motor and Propshaft
- motor mount made of aluminium
- Relocating black water proof box and goods
- busted shaft
- Expected Run Time
- new sv owner, cooling problem right out of the box
- oops. hull cracked along seam
- supervee lipo's
- need tips to make boat more stable
- Wet Batteries
- exploded parts diagram
- Couple questions regarding SuperVee Brushless Motor/ESC
- Salt Water?
- Stainless Backplates
- Interference makes motor run
- SV27 - going lipo - what connectors are needed?
- Floatation Question for SV
- Radio comparisons 2.4 GHZ
- SV-27 Motor Bad ?
- battery position
- ABC Props
- My SV rebuild
- Set screw size help fast!!!
- ammo 2300
- transom water pickup
- Flex shaft/Stuffing tube: how much grease, how tight of a fit?
- prop question
- nimh vs lipo
- another newbie question
- Battery Chargers
- Sad to Say
- Sv27 on 6s
- Shouldn't my SV's rudder turn further (see video)?
- mint sv
- fried something?
- New Boat Pictures and Motor Upgrade Options
- supervee hull, elec and nitro
- How to waterproof servo rudder linkage??
- NiMH Battery Suggestions
- Paint and Waterproofing
- Problems arming ESC with a Spektrum DX3S SR300
- SV 27 motor pin
- New SV Stuff
- SV27 LiPO
- Bad Reef Racer Battery
- new sv 27 one the way!
- new sv 27 on the way!
- Drew's SV
- left turn
- New SV comming!
- Porpoising
- 45.6 mph sv27
- Hull reinforcment ????
- noob motor ques.
- Parts list
- sc27
- Futabu 3PM-X 3 channel Setup on SV27
- Speed Control issues with Ammo motor
- Adding caps to ESC
- Zippy lipo with dead cell can i fix it
- ECS/motor combatability please advise
- SV running slower than usually
- SV27 Scale Drivers
- SV27R here they come
- My brand new sv 27!
- What gives ???
- sealing wood
- Adjustable trim tabs - which should I get?
- hobbytown called
- sv27\ul1 drive
- motor end plate glue let go
- opps
- Best Batteries
- new user
- Water jacket?Which one do you guys prefer?
- Motor mount to transom length
- Battery location ?
- Grim 42X55
- Ul1 motor and sv esc ??
- new mottor yes or no?
- which motor
- battery plug in ?
- lvc proplem
- prop wash water p.u.
- Double Barrel Roll!!!
- extra antena
- stern drive
- Sv motor upgrade options ??
- New SV27 owner
- My video from the canopy of my sv27
- Mini Rio?
- ESC question
- First Post! Wondering if I bought the right LiPo batteries
- NiCd battery question in my new boat
- cooling tubes
- Removing battery tray - Is there a 'How To' or some tips?
- cooling jacket
- Trim Tab Upgrade
- ESC upgrades?
- Venom 5400 lipos in stock SV
- Size of allen wrenches for sv27
- receiver
- Bearing Replacement.
- Another New SV Owner
- Akku Battery WF?
- Check this out
- Broken prop
- OMG! LiPo's are incredible!
- Temps with new water jacket, new pickup and larger tubing
- 2nd time out on the water!!
- Max LiPo battery type with stock speed controller?
- Videos of my SV using 2S LiPos vs. 3S Lipos
- Pro Boat or Aquacraft...
- Bec
- Radio Box Mod
- A quick ?
- SV Drive Dog Stripped?
- Smoke!
- draggy out of the hole
- Help 2s 40c flight max batt.s
- buyers beware !!!!!
- Photos of my pond burner
- collet upgrade
- Rudder servo travel less than normal
- I broke 50 finally!
- need advice
- Motor fried out of the blue on me!!!!
- How to balance a new Prop?
- Motor help???!!
- Supervee Lovers
- sv27 OSE adjustable trim tab screw?
- Motor Mount Screws
- super vee super setup
- sv27 with36 \56 2030kv
- SV27 Stuffing Tube
- up in smoke!!!
- New UL-1 Motor and New Stickers!
- roll overs
- rescue boat
- Water pick up.
- prop shaft bushing
- ESC/Motor acting strange this weekend
- Radio box or not??
- Stock SV27 with LiPos
- TX anyone
- Hull Repair and upgrade
- Anyone in NYC?
- Cavitation
- New mottor
- First two runs with LiPos
- Which motor to upgrade to?
- fixing trim tabs
- Brass Bushing in Rudder Bracket - Size?
- turnigy or other cheapo replacement motors
- Hesitation
- Alternative hardware on SV27?
- Kintec Racing Water Cooling Jacket
- Kintec Upgrade Shaft Question
- Question re: Aquastar 90 amp ESC
- Octura "M" series props
- Bounded Flex Shaft
- top speed
- SV27 Couple won't come off
