View Full Version : AquaCraft SuperVee 27 Brushless Q & A
- Flood chamber for SV27
- SV motor and Speed control
- SV and Wire Drive
- How big of wakes?
- Steve, SV Hardware
- lipo advice
- Sv27 Backwards
- Hydra 120 Setup
- SV flex cable removal
- Newbie needed advise on SV27
- OSE Water Cooling Jacket
- Newbie and would like some Help
- Bath tub test
- How do you guys keep the stinkin' batteries in?
- aqua craft SV esc
- whats negative blue or yellow.
- Receiver packs.
- SV Rudder and turn fin position
- Cooling motors.
- finally got one!!!
- Whats the right battery for the job?
- Hatch mods.
- Can I install LiPo's with original equipment?
- a lil bit more power?
- racing in mazo tomorrow??
- will it handle?
- HELP, shipping damage on strut
- Newbie / Lipo / Esc Stuff...help !?
- Super Vee motor timing and frequency
- changing out speed control
- Is extreme cavitation and violent bouncing normal on a stock BL SV?
- My first summer with SV27
- Radio Advice
- Lipo Cutoff Voltage
- Best lipo for stock esc ?
- SV27 Prop Speeds
- Thrust bearings
- Lipo Temprature Monitor
- went under water
- How to Protect Your Electronic Components
- No Beep, ESC or motor
- Question about the engine
- Aquacraft SuperVee 27 Specifications
- Trimmin Tips for the SV27 Brushless
- A lot of water coming in, need advice
- Venom speed meter
- upgrading water jacket
- saws Valdosta
- OSE the life of boating
- Brass Bullet Nut
- NEW Aquacraft Motor & ESC!
- correct length for stuffing tube
- BEC red wire disconnection
- Ammo 2300 0r 2600?
- new sv
- Help needed on my SV27
- Ammo 2300 motor
- hull damage
- Qs from soon to be new Owner
- Aquacraft ESC Cooling Jacket
- more Qs... Batteries & Run Times
- SV motor Hydra 120 ESC
- Guys, Where can I buy a new radio box?
- New six pole aquacraft motor
- final prop question
- SV spending the night at the pond!!
- X Power 100 amp esc
- OSE .150 flex cable question
- front hatch pin
- speed brake
- Anyone take apart one of these motors yet?
- Why do you need a receiver pack when running 7 cells
- My SV 58.4mph GPS
- hatch tape?
- rudder bent
- Prop/motor will not turn.... HELP!!!
- 27" Fast Lovemachine on 6S smashed, need repair advice
- Motor Hard to Turn
- Stock stuffing tube size?
- prop ?
- bad battery s
- were is the water
- What happenes when you run the drive system without a teflon tube?
- SuperVee Problems
- Which prop for my setup?
- installing a water jacket
- parrallel or series
- Sv boat trailer
- Did some testing today, new best
- help again
- GrimRacer Props
- Pics of where we run.
- Prop Balancer
- Jet Drive Impeller Pitch
- 52.4 mph sv
- Hydra 120 & Feigao 8XL
- SV 27 Custom Paint Work
- Centre of Gravity & Set-up.
- X642 vrs X442 and M44
- Help with SV27 and Fast radio
- what class
- New Beginner versus SV Set Up
- AquaCraft Servo
- Battery ?
- whats the fastest speed
- Upgrading the SV27???
- water proof box for 120 HYDRA
- Best prop to use
- Preparing for my SV27BL
- Question about flex cable
- Mods to my SV
- Mash's SV27
- Cooling system exit port
- Need a reliable setup
- lost my prop shaft - will a normal 3/16 prop shaft work for a replacement?
- Supervee Transom mount
- UL-1 Motor in the SV?
- Sv27 coupler
- Port side turn fin
- Need help
- sv 27 pree first run info needed & prop help
- Maximum voltage for the stock SV esc?
- SV battery holder ?'s
- Newbe
- sv hopping badly in turns
- sv27 ques
- Quick LiPo Battery Question
- flood chamber?
- SV27 motor
- My Supervee's
- SV 27 Temps
- Second day with my sv27 not to happy
- How to go fast??
- how to make the hatch water proof
- supervee esc
- sv27
- lipo (2) 2s 5000mah battery place ment
- GrimRacer 40x52/3
- Upgrading my SV27
- my sv27
- 1st SV, anybody have handling issues?
- sv 27
- cf45 prop steering now different?
- 55mph SV27 SETUP?
- Scorpion ESC on SV
- Novice to RC boating
- My SV27
- Sv27 esc / motor question!!!!
- My new SV27 is on it's way!
- First outting today
- ul-1 motor/esc setup for the sv27
- Sv27 ? Lipo ?
- New sv27 has arrived!!!
- SV27 Upgrade Problems
- Boat died need help!!!!
- SV running sluggish!
- My first testing went bad!
- average size mah you guys run in your sv27
- Setting the esc?
- 40mph+rough water=torpedo
- New Boat
- Very high Amp draw in my SV
- Newbie - Stuffing tube leak?
- Very unstable!
- Tangled SV
- Supervee motor selection
- Help my motor doesn't turn after being wet
- Over propped W/42-55?
- Uggghhh another one.
- New Custom Turn Fin.
- Brand New SV27!
- Sv27 question
- SV Short vid.
- cheap batteries.com
- Wanna go faster
- Anyone trimming their radio boxes?
- Sweet ride! (newbie's maiden run :)
- CC Hydra 120 ESC
- My VERY Fast SV27!!!!
- My superve 27
- Prop Recommendations
- My freshly Painted SV27, Acura Pearl White, with a little extra blue/red flake
- Prop Question
- Tips for my modified SV...
- charging amps
- superve video !!!!!!!
- New to FE, suggestions
- Updated pics of my sv guys!
- How Bad does it Leak?
- Need help not sure what to do....
- SV 27 needs Rhynoplasty
- Sv27 esc
- SV27 Newbie Questions ....
- SV on 6s
- Is it me or is my SV sitting too low in the water??
- Ultimate father's Day Present
- Stock SV27 Surges Except At Full Throttle
- Correct prop for my setup?
- Are anyone using these batts?
- battery placement?
- Stripped
- Faulty Lipo shield?
- Leaking stock water Jacket
- How can you test a battery to see if its good?
- SV27 Motor shaft movement
- 56.4 mph GENERAL VEE
- Arm the speed control Dummy..
- Making a reliable boat...
- 7 cell hump packs fit in trays?
- BEC on stock receiver and 7 cell packs???
- Decals for supervee
- why my boat run backward
- just ordered new red sv27
- Questions about sv27 and issues....
- FE Turn Fin
- SV27 Battery Question?
- Supervee27 brushless:/
- why does my boat pull
- Do these LiPos have enough mAh?
- Servo Recommendation
- SV27 Righting Howl?
- SV27 Project Missile
- New SV27 user
- LiPo's in SV27? Water tight?
- setting up the esc
- My SuperVee Rehab
- Lipo Bat
- SV27 Cleaning Questions
- left or right
- single lipo
- To repair, or replace hull...
- Splashed her today .........
- battery and charger question
- first run stories and questions
- SV27 Reciever:
- Battery placement
- Hard case lipos
- those of you going so fast your flipping...
- Couple pictures of my Supervee
- need help!!! lots of smoke
- pics of new setup
- Flipped it today .....
- Upgraded from Traxxas Blast to SuperVee 27 and wow!
- Prop question
- Replacement/aftermarket motor/radio box mount
- first time run the sv27 need some help
- What happens when you go fast with a super vee
- SuperVee 8S?
- 2 blade prop question.
- Repair or replace?
