View Full Version : WTB "Wanted to Buy"
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. WTB: 3.5 Lawless Lower
  2. Broken flex sahfts, stubs mainly, Hughey only!
  3. Castle 5.5mm and 5mm to 4mm flex coupler.
  4. Wanting to buy a velocity mono
  5. WTB 10/32 90 degree fitting
  6. Large mono hull
  7. wtb elom turn fin
  8. WTB Brushless ESC
  9. desperately need a good UL-1 water Jacket!
  10. lepard 5692 & Peter Z mount
  11. 1:10 scale WTB
  12. Genesis
  13. wtb 10xl
  14. ul 1 kintec upgrade turn fin
  15. WTB 1520 cooling jacket or trade for a 1518 jacket
  16. WTB: “Model Aircraft Aerodynamics”, by Martin Simons, pub. Argus, 1987
  17. looking for a 1527 1D (2300kv)
  18. looking for FE tunnel hull with outboard
  19. Water jackets 2230's
  20. P-1 king of shaves
  21. WTB Castle 2028
  22. WTB Grim Racer Prop 42X55
  23. WTB- X637 prop, S&B
  24. WTB 1/4" Stinger drive
  25. Graupner Prop
  26. WTB UL-1 nose
  27. WTB Proboat Miss Geico
  28. grimracer prop 42x55
  29. Need neu 1527 1y 8 mm shaft
  30. WTB 1512 OR 1515 WATER JACKET cc
  31. hyperion 2s
  32. G3 stickers
  33. WTB: speedmaster 21 uncut rudder blade and octura rudder blade
  34. WTB: Hull 31"-40"Cat. or Mono
  35. WTB Tactic 2.4 GHZ receiver only
  36. WTB 3S lipo Monitor & 3.5 bullets
  37. WTB 180a-200a esc
  38. WTB 28"-37" Catamaran hull/hardware
  39. 5.5 connectors
  40. WTB/WTT: Castle 2028
  41. WTB Gas King of Shave
  42. WTB: Swordfish 200 esc
  43. Large cowl locks
  44. Steerable outdrive
  45. K&B 3.5 OB prop shaft
  46. WTB Hyper Performance 3.5 Bullet Shaft Assembly
  47. looking for an HK Genesis cat
  48. 1800-1900kv motor
  49. 100a-120a esc
  50. WTB: 1/4" Drive Setup, 12mm - 1/4 coupler
  51. 36"-50" fiberglass RTR or hull w/ hardware
  52. wtb UL -1 motor
  53. WTB: 2x Turnigy T600 1400kv Outrunners
  54. NQD Jet Boat !!!
  55. wtb brushless speed controler
  56. WTB Proboat Fastech
  57. WTB Cellpro 4s Charger to Great Planes or Kokam Adapter
  58. WTB:aquacraft 1800 motor
  59. WTB:a/c 1800 motor
  60. WTB: Water Cooling Jacket for Leopard 4074 motor
  61. WTB: 3S Lipo & Charger
  62. Water cooler for 2028
  63. I need 6s Lipo please
  64. WTB Miss Geico cat,
  65. WTB .130 flex cable
  66. WTB 5mm to .130 flex coupler
  67. UL-1 motor bearings
  68. Looking For a Setup Vac-U-Pickle
  69. Wtb rudder
  70. WTB a NIB Sport 20/Limited Sport Hydro Kit
  71. WTB OS lower assembly 21XM
  72. WTT: 67" CT04 HPR-RTR for 351W Built
  73. WTB 4074 or 4082 2000-2200kv or 1515 1y
  74. Wtb Lipo charger 10amp or so
  75. Looking for 5mm to .187 coupler
  76. 180A Brushless ESC
  77. 32-36" Cat Hull
  78. pro boat 3630 1500 motor
  79. Servo water proof
  80. turnigy nano tech 4s 5000 45-90c
  81. WTB 40c or 30c 3s 5Ah Zippy Lipos
  82. motor & or esc for 10th scale
  83. Wtb: Himax 3630-1500
  84. Pro Boat Spektrum 2.4GHz DSM Radio MR3000 Transmitter
  85. 8 inches of 1/8 Teflon liner
  86. traxxas 2.4g 2218 reciver
  87. Looking for free hull
  88. WTB lawless 7.5 lower + more
  89. WTB 40" and bigger damaged hulls.
  90. ProBoat FastTech In $200 range
  91. WTT HP 2133 Mini-Note Netbook for hardware
  92. WTB .125 Assembled Cable and x442 prop
  93. Sharpened and balanced props
  94. Looking for....
  95. Wtb Nue 1515 Jacket
  96. Wtb Rudder
  97. WTB: Leopard extra long water jacket
  98. WTB Charger clamps with 4mm Banana plugs
  99. Need a CC 1520
  100. wtb aquarcraft speed controler
  101. Where Can You Buy a HPR010 Mono?
  102. WTB cooling jacket for 4082...
  103. WTB: Medium cat or vee
  104. WTB OS21XM lower assembly
  105. WTB Duo II Charger
  106. Wanted : 4074 Cooling Jacket Long
  107. Looking for 2 x 8/6mm-0.250 coupler
  108. WTB Clear Shrink for 4S and bigger packs
  109. Proboat Mini C or V
  110. WTB a MHZ Mystic C5000 114cm
  111. Feigao 380-9XL motor
  112. WTB RC-Hydros ESC
  113. Zippy 30C 5000mah 6s or 3s packs
  114. Rx Pack
  115. WTT- Proboat Stiletto HULL and Hardware
  116. looking for hulls
  117. CC 1518 1800 NIB ( or close )
  118. Jeti 600
  119. 55" segad or 55" ekos used for sale?
  120. WTT For a 540 7S, 5L or Similar 2s Motor
  121. WTB good motor mount for 5692
  122. Spektrum MR3000 receiver
  123. 180+ esc
  124. WTB Insane FE 30 hull
  125. WTB 3/16 CR flex shafts
  126. sv27 1500 motor
  127. WTB 2028 or 2230
  128. WTB: Octura 3/16"ID - 1/4" od sleeve bearings.
  129. Looking for Xbox 360 with kinect in good cond. and nintendo 3DS
  130. Swordfish 200A ESC
  131. Wtb 380-400 sized motor for a minicat velocity
  132. WTB Leopard 4082 1500kv
  133. WTB UL-1 Motor
  134. WTB X640 prop sharpened and balanced
  135. WRB Grim 42x55 prop
  136. WTB: 3/16 Strut bracket only
  137. WTB 40x52/3, and x642
  138. wtb x447 s/b prop
  139. wtb traxxes 5 ch micro receiver
  140. WTB Grim 42 x 55 prop
  141. WTB: 1717 Cooling Cans x2
  142. Looking for new CAT Hull
  143. WTB Water jacket for 1515 for finned can
  144. WTB Seaking 180
  145. WTB: SV27(r) minus the hull.
  146. WTB Proboat Classic Runabout
  147. WTB:Miss Geico or Hobbyking Apparition
  148. WTB: Prather 215 SBP Prop
  149. WTB: Hyperion Duo Charger
  150. Looking for esc stock UL-1
  151. WTB: Matching set of x447r and x447 Props
  152. Wtb 150-200a esc
  153. WTB: Single turn fin for 27-29 inch Mono
  154. WTB; 1717 mount & cooler
  155. wtb x645 or prather 225 s/b/p
  156. WTB: 120A ESCs
  157. Wtb: MHz aquamania decal set for 114cm cat
  158. WTB: Sport 40 Hydro
  159. looking for a cheap blackjack 26 hull
  160. WTB: Scorpion 3026-10 brushless outrunner
  161. Graupner jet pump
  162. New motor for my t29
  163. Schulze 40.300/40.303wk
  164. WTB JAE FE Outrigger
  165. 2.3 to 130 collet
  166. WTB: Props
  167. WTB Octura x442 S/B
  168. nodd v180
  169. Looking for octura x457 L+R props
  170. WTB CC Hydra Ice HV 120
  171. WTB Brushless Boat
  172. WTB: Neu 1515 1.5y 1500 kv motor
  173. Need M445 or X442
  174. WTB Hydro hull
  175. WTB Octura collet 5MM to 130 flex.
  176. proboat 1500 motor
  177. WTB Mhz Gecko
  178. Cheap ESC
  179. Want to trade 4x4 Slash brushless for RC boat
  180. WTB Octura M445 props
  181. WTB: UL-1 black turn fin and bracket
  182. M445 needed.
  183. WTB: octura x460/3
  184. proboat program card
  185. WTT a nib expresscraft gtx 65" stepped offshore DV
  186. WTB 3/16 stinger, cable and rudder for a 40" mono
  187. Octura 5mm- .078 coupler
  188. Proboat Stock Water Jacket
  189. Wtb- neu 1527 1.5y
  190. Wtb or trade mg hull for deep v
  191. looking for a Supervee 27 or miss geico
  192. Prop Strut with Mounting Bracket: MG29 PRB4105
  193. Wtb 3pk
  194. SeaKing 180
  195. Cc 1518
  196. WTB electric Rigger
  197. WTB 4mm to 1/8 coupler
  198. 0.150" Flex Cable long enough for the MC - anyone in the GTA have one
  199. Mamba 1/18th Brushless motor 5400kv or 6800kv
  200. WTB 32-36" mono- hull/hardware
  201. Looking for a hydraulic brake sytem
  202. WTB Mr200 or SR300 spektrum receivers
  203. WTB aquacraft sv27
  204. wtb Graupner HYDRO PLANE 3D Kit or already built
  205. wtb Aquacraft UL-1 hull with hardware.
  206. Need Leopard 4074 2150 Motor
  207. Wtt genesis for king of shaves c1
  208. Gps
  209. Lower cover for the "Mercury" electric outboard from the MRP Budweiser tunnel hull
  210. Wtb x632 sbp
  211. WTB: Traxxas 2056 Waterproof Servo
  212. WTB 30" area boat in the 1,000.00 range. please read on.
  213. WTB Leopard or Tacon 2000kv-2200KV Motors
  214. looking s or l motor
  215. mg rudder
  216. New Logo at the bottum of the page!!!
  217. WTT MG/Traxxas trucks for a Zenoah powered RTR boat
  218. WTT NEU 1527/1Y for NEU 1527/1.5Y
  219. wanted blackjack 26 hull
  220. wtb 4s 30c or 40c lipos 4000mah or higher
  221. WTB 540 motor to stuffing tube flange
  222. Aquacraft Pro bass fisherman EP
  223. WTB 300 size cooling jacket
  224. WTB: Lipo Charger/Balancer
  225. WTB: Strut Bushings
  226. WTB Leopard Tacon 2000kv-2200KV or Castle 2200KV Motors (I'm in UK)
  227. Looking for a 1800 KV Spec Motor; Aquacraft or Proboat(with cooling jacket)
  228. Wanting 2 Boat Hauler Transport Carrier Bags 35"
  229. Looking for a Seaking/Turnigy 80hv esc or similar
  230. WTB Dick Tyndall sport 20 turn fin
  231. WTB Graupner 45L, Octura 447R
  232. WTB sv27 motor and esc
  233. Needed Supervee parts: strut bushing, trim tabs and flex cable
  234. wtb octura x645 or x642
  235. Feigao 540XL Rotor
  236. WTB Seaking esc 60a or 120a
  237. Wtb
  238. WTB Boat Stands for Deep V and Cat
  239. Wtb 20-25" mono hull
  240. Wtb deep v hull & castle 1717
  241. WTB water jacket for a Castle 1515 ribbed motor
  242. Spektrum Mr3000 2.4 RX /tx
  243. Wtb turn fins for a 25" mono
  244. wtb brushed speed controler for rc surfer
  245. WTB fiegao 380 9XL
  246. WTB: 120 amp esc CHEAP
  247. WTB - Motley Crew
  248. WTB Micro Hydro ESC
  249. GPS Speedometer
  250. wtb mini eco or v-mono
