View Full Version : Prop Talk
- Usefull information about props
- Octura Props
- Octura M545 prop
- prather to octura props
- octura prop help
- Octura X431 vs Aquacraft stock Mini Rio prop?
- Octura P741/4
- 1742-3 Octura
- Octura V series props
- Octura prop size for 32" cat
- Delta Force 33" Prop
- Octura Aluminum Props
- what is the difference between a octura x series, y series and m series prop ?
- Octura balance and sharpen job
- Octura balanced and sharpened
- Anyone Run an Octura 1.25 prop???
- Anyone Use Octura P-Series Props?
- Octura catalog
- Grimracer and Octura
- Octura letters?
- octura prop ID
- Prop???
- Prop Diameter Size vs Pitch
- Octura 2140/3
- help me here
- Prop Diagram
- modded props ready to go...
- how to you measure a prop to determine it's diameter
- Propellers for 57" hull with twin t600
- Prop change? pitch vs diameter
- Prop service by dasboata
- Prop Selection for Mystic C5000 M
- the right prop..
- Is an Octura 1740/3 a good prop for....
- Traxxas Spartan Prop Selection?
- Help me
- L&R prop choices ?
- 3 blade prop balanc
- props for my UL-1
- Clarification: Prop Thinning
- propellers
- s/b props want to learn the ways
- Propellers
- L and R cable choices
- abc props type
- Andy Brown Props
- Correct prop for Traxxas Blast
- What props for Titan 29"?
- prop
- MRP Fountain Replacement Prop
- What's in YOUR prop box?
- Dark Horse Shovel prop suggestions
- Balancing and sharpening help
- how big can i go
- Prop Selection for Drambuie on Ice
- props
- Prop size for Genesis ?
- UL-1 props
- Prop shop props???
- Need help
- prop selection for HPR 115
- Question what causes cavitation and how do you slove it
- increasing prop size?
- Pro Boat Stiletto prop
- Help, x642 bending over??
- Brushless blackjack prop
- Another Balance/Sharpening Question
- Villain rescue boat prop help
- prop cupping pliers
- ugly tfl prop
- Prop For Sport 20 Whip FE
- detoungue?
- Prop for skidaddle
- prop selection question for mg
- 1521 1.5D SprintCat20 prop selection??
- looking to get a prop s/b
- Twin Cat, NON CR props
- Octura x642 same as Aquacraft 42mm
- Genesis, what prop?
- Where can I get a decend prop balancer
- Octura "V" series props
- Octura 1.6 and 1.8
- 2 or 3 blade
- TFL balancer...not very sensitive?
- Prop ? (DF Sniper 23)
- FE30 prop
- Carbon vs Metal
- Aussie prop work ???
- prop rec miss elam
- M-1 Supercat, 34" prop suggestions?
- Prop Identification for a Newbie
- prop help fore the rigger I built
- prop help
- dropped a prop.
- Prop Torque
- osprey 41in lepard 4082 1250kv
- Prop shop props suggestions?
- Best Prop advice please
- 45mm Props NEED HELP
- why are FE boats not using 4 or 5 blade prop?
- Does back cutting a prop work on a mono v
- Prop for old V
- 2 Props in 2 days
- Optimum prop size for this specific apllication?
- Question about the Venom 3-blade prop at OSE
- A Brain teaser on Prop pitch
- X444?
- Dragon jollymotor cat props
- 2 blade 3 blade whats the differance ????
- Prop Dimpling
- B&S Prop's - Dasboata
- received my props!!! excellent work
- Tapping M4 threads in Octura x4 series
- Prop removal
- prop modifying
- Hobbyking apparition props
- Prop recommendations?
- Dual Sniper Prop Questions
- Loading (ish) a 4 blade?
- shockwave 26 prop questions
- Prather 235
- Changing prop diameter
- Prop for a 12jae FE
- round prop vs. pointed?
- traxxas spartan prop recomendations?
- Conquest Prop suggestions
- 3 blade help please.
- Need MG replacement prop
- prop adjustment?
- How Proping Up Effects Motor/Esc Temps
- Octura props: "lifting" vs "pushing": X & other types
- need help selecting a prop
- what is optimum prop speed?
- Please help me pick a new prop for stock Genesis on 4S
- ProBoat Blackjack 26 BL Catamaran prop question
- model prop engin
- This might be dumb but what the he!!
- Need a new prop!
- higher rpm vs bigger prop
- Counter rotating props
- prop's for my df33 help
- Pitch questions...
- DF33 prop help with 4082 leopard and swordfish 200 esc
- MHZ mystic C5000 44 props
- Help with prop size...
- HPR C5008 185cm prop size dilemma... Any suggestion???
- CNC prop's
- Understanding final prop pitch
- In a twin motor setup, prop spins
- 1450 Mod prop - anyone use one ?
- Need someone to balance and polish
- Found list of prop descriptions somewhere.......
- Prop size questip
- help to chose prop please
- I have a prop problem
- detongued grimracer 42x55
- Correct prop size??
- Impulse 31 and 42x 55 prop
- Need Egneg but can't find him
- First time cupping
- Rotational speed for magnetic prop balancing
- octura m545
- Top pick for prop balancers OSE ETTI etc. your thoughts please.
- titan 29 prop ?
- lost prop size
- Impulse 26 Upgrade Prop
- Need prop sugg 4 Genesis\cc1717 :)
- prop question
- Holy Meat Cleavers Propman!
- Building up/Reparing Props??
- Next props to try? (Stock ProBoat Mystic 29)
- Optimum size props for twin drive cat?? DF Explorer.
- Best prop question????
- Prop up my Titan 29?
- R2hobbies Al CNC x445/3
- prop question???
- Pitch is Pitch correct ?
- Mysteries of prop pitch
- X632/X432 Big enough to Push a DF26?
- Three blade vs two
- what prop next?
- Which prop for genesis?
- props for twin t600's
- Octura X460's
- Best prop for my current tunnel project
- Bought new prop for new boat and need help PLEASE!
- "STILL" having problem finding prop I need
- Does it matter what you prop is made of?
- Size prop for 32" cat using Leopard 4082 1500KV with 6S?
- UL-1 stock prop breakin
- Lifter props
- counter rotating props
- Octura Prop Types
- Prop for this shovelnose config
- my third attempt x640
- Ebay props ??
- 13090 kv motor on 6s prop ?
- H&M Xzess Krabs outrigger propeller?
- How much power for x646
- Counter Rotating Propellers sets 3/16" shaft ??
- Prather props
- Looking for a 1/4" bore x457/3 prop. Any ideas?
- 5 Blade Cleavers?
- prop work
- Propellers available for a twin setup counter rotating ??
- P limited prop size
- twin prop direction
- 642 props on a twin Genesis???
- propping up
- Question
- Golden Eye ???
- Prop reccomendations for my P/Spec Timex
- Dasboata props, T29, 1515 = My new record speeds
- prop nut help?
- Bending pitch into props
- Prop table pleeeeaaaasssseeeeee. !!!!
- metal prop
- Arrowshark props for f/e
- which props??
- Is it good a mirror like polish on a prop?
- traxxas spartan prop?
- Specific prop type/style.
- HELP! Need Excel Spreadsheet for Octura and Others
- Prop options on a 33" DF
- What Size prop should I be using?
- Prop for Aquacraft Vegas Duece FE conv. 2200kv 6S
- spartan prop shaft size
- Octura Prop Shapes
- Prop size question.
- ABC props, what are the differences??
- small CR props?
- UL-1 with Leopard 4082 Prop ?
- 2 blade and 3 blade prop?
- Twin cat prop suggestion
- recommendations of the propeller (46 'v-hull, leopard 5692)
- Aquacraft FiberFilled Prop pitch?
- 1/12 (?) miss budweiser prop recomendation
- New to boats want a metal prop any suggestions?
- Speed 3 Blade Over 2. How to work out?
- hk rc princess boat prop
- You think these props would be to big.
- Prop pitch vs diameter
- Right props 44" mystic??
- hydro talk
- Need P-Mono Pursuit 4082 2180KV Prop Advice
- H&M hydro
- barr cut amp reduction.
- Octura x442 vs Octura 442 Backcut
- VX Performance CNC propellers
