View Full Version : Prop Talk
Pages : 1 2 3 [4] 5
  1. Prop Help
  2. Blackjack 29 V3
  3. Need help with prop size, and 3blade vs 2blade
  4. Do Drive Dogs Need to Be Balanced?
  5. Help with prop to upgraded Traxxas Spartan (2160kv)
  6. How do you change props without losing a digit?
  7. damaged m435 3 blade
  8. Octura x642 to CNC
  9. Distance between props on twin drive
  10. Need prop recommendation for HET 1170kv in Whip40
  11. Voracity 36 prop - Need some advice
  12. Pitch vs. Diameter?
  13. Octura X442 Lynx cut on an OPC VS1 tunnel
  14. New motor and prop set up. What prop do I pick??
  15. props for the twin motor Zonda
  16. fast props for twin motor Zondas
  17. prop and motor setup
  18. CNC 4414/3 prop on stock Genesis
  19. Heat treating props
  20. Snowman (Brian Buaas) is doing props! Record setting ABC blades available.
  21. Converted Cat from single to twins, now which prop?
  22. Where to buy ABC Props
  23. X646/3 for 29" Sprint Cat on 6s?
  24. H2O density vs prop choice
  25. CNC 4414/3 with SSS 3660 2070KV or SSS 3660/1620KV with 120A and 4s
  26. Any suggestions for what prop to start with?
  27. CNC vs. Beryllium
  28. Octura X655 versus 1655
  29. Finding the right prop size
  30. Impulse 31 prop
  31. Brushless Conversion
  32. Leo 4082, 1600kv, on 8s, and 48mm, 1.7 pitch, 3-blade prop?? (twin setup)
  33. Mean Machine
  34. Radtek 45 twin TP 4060 1950 kv
  35. prop nut.
  36. Dasboater and his attitude
  37. M445 Prop with Long Hub
  38. prop for 55" proboat shockwave
  39. Need Prop Advice.
  40. CNC props that match abc for my zelos 36
  41. Prop for 22inch cat?
  42. Cheetah twin
  43. Prop balancing and sharpening
  44. Cut/mod prop for less load?
  45. 1800kv 4s prop?
  46. doctorprops
  47. X460-3 to big for 1/8th scale hydro
  48. anyone need a set of 1615/17*
  49. Iso ABC 1815-17
  50. Differing between a clever and chopper a.b.c. prop
  51. A.b.c.
  52. CNC-4019250 high pitch prop
  53. Prop for 37” Shocker
  54. What prop to run?
  55. Traxxas M41 stock prop vs cnc props
  56. Prop to Rudder Placement
  57. V940/3 prop
  58. TFL Genesis 56” best Prop?
  59. 1715-19-38 cll,1815-19-38 cll
  60. Would a sharpened and balanced Prather 235 work for me?
  61. a question about prop longevity.
  62. Prop/Speed Question
  63. miss geico v3 strut upgrade question
  64. Very poor quality eBay prop
  65. 8mm Blue Connectors installing trouble.
  66. Any ABC props with 23 Rake / 38 Bar for Twins?
  67. New prop box
  68. Heat treating Octura props
  69. Prop recomendation
  70. Suggested prop size for an Osprey
  71. Looking for ABC 2216 for a twin cat
  72. 2 vs. 3 blade
  73. ProMarine MTR Prop Help
  74. ABC or other prop reccomendations for P mono
  75. prop
  76. CNC or ABC Prop
  77. Prop recommendation for Aeromarine Conquest
  78. P-Hydro prop recommandation
  79. Guys I think I'm back now
  80. how sharp is too sharp
  81. Looking for props for a proboat zelos 48
  82. ABC props bending
  83. TFL Smash Shark and patron saint 2 p1 drive prop
  84. Noob needs some help
  85. octura 457/3 B/S/Hardened tounge removed
  86. ABC contact
  87. Help choosing a larger prop for my impulse 31 (v3)
  88. What to mark props with for testing
  89. Best metal prop for Pro Boat Recoil 26
  90. Grimracer 42X55 ?
  91. Sharpening trailing edge
  92. Andy Brown 3857/3 CNC Prop
  93. Best Prop ?
  94. Need help picking a prop for a 30” tunnel hull with a tfl ourboard
  95. Brian Buaas props
  96. ABC prop
  97. X447 3 Blade Wanted
  98. Respirator for prop work
  99. Have you seen the new metal cobalt propellers ?
  100. X460/3 extreme mod used
  101. Prop suggestion Cheetah 4S ovals
  102. Starting point prop for DF 26" Mono
  103. Prop suggestions needed please.
  104. Proboat Prop Recommend for Veles 29
  105. FAST 6s setup prop help
  106. WTB H5 prop
  107. New guy needs help
  108. ProBoat prop sizing confusion
  109. Q Hydro Prop Recommendations
  110. Looking for a H7 prop
  111. Link for Octura 2017 Prop Catalog
  112. prop
  113. Prop for Aeromarine Challenger 31
  114. Prop tolerance
  115. Newbee needs a starter prop
  116. Vee Hull Prop Recommendations
  117. RSX310 FE Outrigger Prop recommendation
  118. Has anyone. Tried this?
  119. ABC SK Series
  120. Delta Force Pirate prop recommendations please.
  121. Large V Hull Prop ideas
  122. Microcat - 4s starting prop recommendation
  123. What prop to use
  124. Motor...
  125. Back after a few years, could use some guidance with prop sizes.
  126. Prop bore diameter !
  127. Pro Boat Prop Size's
  128. Looking for the right prop for an aqua craft ul 1
  129. Prop upgrade for Valvryn?
  130. Double engine catamaran propeller recommended
  131. Proboat Prop problem
  132. Octura vs CNC prop
  133. Proboat recoil 26 prop coupler and flexshaft upgrade
  134. Choosing the right prop.... Help please
  135. Propeller talk post
  136. Do you know DOCTORPROPS ?
  137. Anyone have problems getting the flex shaft out of the proboat recoil 26
  138. nitro to FE
  139. sonicwake prop info help!!!!
  140. prop copy
  141. propeller help for speed - TFL 1106 Pursuit
  142. Prop size?
  143. L/F abc 1816-17
  144. Prop Help for Retrieval Boat
  145. 20k rpm and bigger prop the way to go?
  146. Prop choices for Gizmo-Motors GZ-4 Zenoah
  147. My Dasboata PROP just came in today!
  148. ABC Prop Rake
  149. No speed at full throttle / high RPMs
  150. prop issues... is this prop shaped right?
  151. Total Pitch
  152. Miss Geico 36
  153. Need Prop Info for 44" Hydro
  154. What The??
  155. Prop for ul-1
  156. cnc prop
  157. not exactly a prop question...
  158. zelos36 good prop
  159. Very shallow prop?
  160. Props for 72 skater
  161. Need help finding a RTR hydro prop replacement.
  162. Q mono prop size and pitch?
  163. Prop Suggestion
  164. prop for impluse with 4082 2200
  165. P-Limited Mono Prop recommendations
  166. racent atomic 792-4
  167. Do I detongue?
  168. Tested a M645 and y547, I need help choosing my next prop
  169. Prop recomendation
  170. Prop fitment issue on Sonicwake
  171. Biggest prop available?
  172. Proboat Shockwave 26"
  173. Miss Geico 36 /Poseidon
  174. Prop recommendations - Different pitches & diameters, plus 2-blade vs 3-blade
  175. I need a few ABC props
  176. ABC pros
  177. prop for depron outrigger
  178. New Bright Fountain - prop needed
  179. good prop for the traxxas m41 widebody
  180. 3 blade 1.4 pitch prop
  181. prop shaft
  182. Raider 24" V Hull - Prop Recommendations
  183. Drive Dog
  184. Prop recommendation
  185. Prop suggestions for a scratch built boat
  186. Prop help
  187. Thoughts/experience with newest ABC 19-23 props for monos?
  188. TFL cheetah CF Props?
  189. Where can I get these props???
  190. DF Pirate 35" prop range
  191. Prop Recos for 36? AC Cat
  192. Counter Rotation Props Configuration
  193. ABC 1817/3 23-50 for Q sport?
  194. MBP "Smart Drive" Flex shaft ?
  195. R-42 12s prop selection + strut depth..
  196. FE Build Rio 51z
  197. Prop for P mono
  198. Water pickups....which side is best ?
  199. What causes a prop to ?lift??
  200. Prop for Kyosho Jetstream 888 VE
  201. Maine Downeast Lobster Boat
  202. Prop recommendations for neu 2230
  203. Prop selection question for newbie to f/e
  204. Prop for ProBoat Impulse 31 V3
  205. Unexpected prop testing results
  206. Looking into SonicWake prop upgrade
  207. Leopard 4074 1650kv prop size
  208. Prop Help Quick
  209. Volantex SR80 pro prop change issues
  210. In need of remembering prop number conversions.
  211. needed 447 right hand
  212. 2bld to 3bld Q
  213. MHZ Ocean spray prop recommendation
  214. Genesis abc 1914
  215. P Limited JAE Prop Help
  216. How to remove prop?
  217. Need 1717-17-45
  218. Proboat blackjack 42 prop suggestions
  219. how deep should prop be
  220. Prather S225, S230 low lift??
  221. Basic prop info
  222. T mono props??
  223. Sonicwake 36
  224. Sonic Wake prop recommendations
  225. New to group
  226. RC Retrieve Boat Propeller Size Recommendation
  227. Octura vs cnc
  228. Stock Prop for BlackJack 42?
  229. Help me double trouble
  230. prop suggestions for newbie
  231. new props and shafts
  232. Dasboata
  233. Another Newbie Request for Prop Suggestions
  234. P lim pursuit prop suggestions
  235. Need prop suggestions
  236. Best prop balancer
  237. looking for octura 447 right hand
  238. prop help
  239. cnc prop difference
  240. stringer help
  241. Prop for a StealthWake w/12t motor
  242. Prop too short
  243. ABC H-13 pitch???
  244. Lehner 3060/10 in hurricane on 10s prop recommendation
  245. ABC prop suggestions please.. Help..
  246. Cooling heat treated props?
  247. Prop sizes
  248. PB 1716 prop vs ABC 1716 prop, what exactly is the difference.....
  249. Looking for Prop Suggestions for an MHZ Majestic 5000 44.88 inch boat
  250. Looking for info on how different props designs affect different types of hulls
