View Full Version : Prop Talk
Pages : 1 2 [3] 4 5
  1. Popeye 4074 2200kv prop
  2. plastic prop or metal prop?
  3. Prop shop needed??!!
  4. Grim Racer 42x55 on 6cells / 1600 Leopard
  5. genesis 900 prop
  6. Please help selecting props
  7. Wanting a little more from my Pickle
  8. Non stock revolt 30 prop slection
  9. I need to make an x437 into an x435
  10. vxperformance123 vs kintecracing props
  11. Prop recommendation for a 30" tunnel....
  12. Prop covers
  13. Drilling out "1/8 prop to "3/16
  14. who's the man for props?
  15. P Sport Hydro Prop
  16. Cf daytona prop advice??
  17. Traxxas Spartan Prop
  18. Aquacraft GP-1 hydro prop suggestions?
  19. prop for 1/4 shaft in 55mm?
  20. Triple 1717 Fantasm Prop Advice
  21. Teflon coated Props
  22. props
  23. Joysway prop change
  24. Prop prob
  25. What props should I order?
  26. Prop shop propellers
  27. "y" & "x" Props - What's The Diff??
  28. Prop Sox?
  29. Re-worked some pairs for livewire121
  30. damaged prop
  31. prop will not come off shaft
  32. prop work
  33. Metal Prop
  34. 45mm prop on mm on 7s
  35. Prop pitch vs diameter & amp load
  36. I need to be schooled
  37. Just ordered a mean machine need prop help please.
  38. What prop to run?!
  39. Need Prop Advise
  40. Prop failure at high speed
  41. Andy Brown
  42. x457 prop
  43. Props for CF Shocker w/twin TP 4060 3Y 1870kv, Swordfish 220A's & 6s per motor?
  44. Miss geico 29 stainless steel prop question
  45. Two blade in relation to three blade?
  46. Working over the CNC 1448/2 Props
  47. Can't find hardly any counter-rotating 3-blades for twin... 2-blades better?
  48. Turn a X642 into a M642
  49. 2 blade vs 3 blade
  50. Heat treating CNC props
  51. Searching for Octura x442 prop
  52. Pranther s215 or Octura x442
  53. Ideal prop for 29" Sprint Cat?
  54. Prob for Victory EP 70
  55. Can I use Y547 on the Zippkits JAE 21 rigger?
  56. Prop diameters
  57. prop help
  58. Prop for modded BJ29
  59. Can I prop with my currant set up for more speed?
  60. enforcer pro zenoha m5 mod prop help
  61. Done for?
  62. New to the boating seen... Blackjack 29 props
  63. Looking for a bit more speed
  64. cutting dia of props
  65. X435r for twin 1/8th outboards
  66. Need help for Quanum Relentless Prop
  67. Miss geico Build
  68. Distance prop/drive dog from strut on 3:16 flex shaft
  69. Which prop should I get for a Kyosho Jetstream 800?
  70. Got new prop but its to long? Need help
  71. Genesis prop recommendation
  72. CNC Props.....Looking for Reviews and your feedback
  73. FE VS-1 Prop Depth and angle
  74. Sharpen and balance propeller - what can I expect?
  75. prop shape help....
  76. Need a prop with a 1/8 shaft
  77. Need prop expert advice !
  78. im in need of a good prop guy. someone to make good sharpened and balanced props
  79. Why wouldn't you clean up the face of a prop?
  80. VooDoo props?
  81. Should I upgrade to a bigger prop?
  82. Prop shape help again...
  83. record holding prop..
  84. Mean machine 4s 180 seaking esc and leopard 2200kv
  85. Genesis Torque Roll Solutions ?
  86. prop help please
  87. M445 and X642 question
  88. Next prop to try Jae21
  89. Same but different
  90. l/f p-ltd or p-spec outrigger prop suggestions
  91. I wanna go fast!....Turnigy 2200 KO & MG29
  92. How does a cut down prop make you faster??
  93. CNC stainless Octura copies
  94. prop balancing and sharpeing for 5$
  95. prop pitch
  96. SV 27 Prop Recommendations
  97. Prop balancers - not accurate
  98. available pairs between 30 and 39mm dia, recommendations?
  99. Voodoo prop anvil for cupping
  100. Prop me
  101. Larger dia. or more pitch
  102. Will prop for 1/8" fit a 5/32 shaft size?
  103. Plastic prop compared to metal
  104. Balancing with Putty
  105. Du-Bro Tru Spin anyone use this balancer ?
  106. Who can make the BEST propeller ?
  107. Prop advice needed -please Cyber Storm 21
  108. Mean machine on 6s
  109. Prop installation question
  110. Octura X447/2 vs Propshop GP/4714/3
  111. Can Someone Explain This Propeller
  112. King of Shaves 34" Prop Help
  113. king of shaves c-1
  114. Prop shaft questions
  115. Andy Brown
  116. leopard 4092 prop sugestions for more speed
  117. Prop for Lucas Oil FE
  118. Pursuit Mono x445/Octura Prop ; de-tongue? or keep em' ?
  119. what prop should I start with?
  120. performance difference between 2 blade prop and 3 blade
  121. how are the CNC props from ose
  122. New style Prop saver
  123. Need help choosing prop for BJ 29 v3
  124. cutting props
  125. What prop should I use?
  126. Aquacraft UL-1 Superior stock prop
  127. Props4u
  128. 8s Rigger
  129. props????
  130. HobbyKing Princess Prop Upgrade
  131. Prop recommendations: Zonda 41 and Modded MG29
  132. M445 and M545
  133. New to boats, questions about my setup
  134. Just put my blackjack29 leopard engine need help with prop size
  135. Is a boat pushed or pulled by the prop.......that is the question
  136. Whiplash 20 FE
  137. Cupped S215 vs. X445 for 29" cat hulls?
  138. Help me choose a prop
  139. Mean machine
  140. prop question
  141. Normal to bend ABC props just running? MHz mystic
  142. Polished and Balanced Props
  143. OSE missing web page question
  144. Back to back prop swap test
  145. Prop Balancers????
  146. Dumas 55( 4 Bladed Props)
  147. Prop For Hobbyking Princess
  148. Where can I get a sharpened and balanced X642 Prop?
  149. prop ballancer
  150. Let's see your prop boxes
  151. Correct Prop Suggestions
  152. Propeller RPM
  153. x642 or M445
  154. Props for a tp 4060 3y
  155. new abc props
  156. Would you use this prop?
  157. Pursuit Prop recommendations
  158. Upgrade prop for atomik barbwire 17
  159. Prop recommendation for friend's surge crusher
  160. Help with my first twin boat, dont know the way they should spinn and who prop
  161. 3 blades prop, how can i calculate the speed?
  162. 57mm Prop Application
  163. Q from a newbe
  164. What prop for my setup on 3s?
  165. Prop recomendations for 92" HPR/RADTEK hull
  166. New abc props
  167. Prop suggestion for outrigger
  168. Prop holder homemade
  169. Question about prop to transom distance
  170. new ABC 17* props
  171. New left and right rotation prop choices!
  172. Need help to compare two props!!!
  173. Bullet nut on prop wobbles
  174. Prop question on Cat
  175. Prop chart
  176. Prop chart
  177. Flex shat upgrade and prop
  178. Prop nut for atomic barbwire
  179. Prop/Rudder Centering
  180. Question about props and torgue roll
  181. Prop for a Rico 31 using 6s
  182. Standard cup from X445
  183. Octura Prop size. Am I missing something here?
  184. ABC high pitch props
  185. prop cad files
  186. Atomik barbwire Xl motor upgrade with ??? Prop
  187. Pretty new to this stuff, advice on prop needed
  188. ProBoat Impulse prop
  189. Atomic cnc alloy prop
  190. HK genesis prop help
  191. Spartan Metal Prop
  192. Help choosing the right props!
  193. Stock HK Pursuit Prop ?
  194. Where to buy sharpened and balanced props
  195. need some help plz
  196. Flex Cable Saver
  197. Zonda want bigger props
  198. What prop should I get for my jae45 Outrigger?
  199. PB Arleigh Burke Prop brass replacements threaded props on non-threaded shaft?
  200. Prop for a Rico 31
  201. Pitch Block
  202. VooDoo Prop Pitch Gauge - Modification to make it "right"
  203. What prop should I get for my proboat rockstar
  204. Prop Rake angle
  205. New prop: Is this a crack?
  206. plastic or fibre prop for Blast with 3/16" shaft?
  207. Help!!!!!! Prather 46 prop/esc/motor combo??
  208. Got some New abc props of interest in today
  209. who wanted the m440 ?
  210. Need prop help
  211. Do I need a new collar?
  212. measuring pitch
  213. props ...... L @ R
  214. need info on this prop
  215. HK Relentless V2 Prop
  216. Cupped CNC V642 prop
  217. Trouble finding smaller 3/16" counter rotating props
  218. Octura-Prather rake angle???
  219. ı dont choose prop my boat
  220. prop size
  221. How to loctite 2mm (0.078) wire to shaft drilled for 4.75mm?
  222. Prop Rotation
  223. Counter rotating cat how too?
  224. 48" proboat zelos
  225. props for Kep's FE 4SL P limited outrigger
  226. Props and Chine Walking (My Specific Case)
  227. Need to slow down F1 Electric tunnel hull
  228. Prop required for a dumas hotshot 45 / running 4s
  229. need to find left side aluminum prop for venom segad electric
  230. Vortex 24" hydro prop?
  231. Stealthwake 23 prop
  232. Help understanding props...
  233. What is the difference...
  234. Correct prop sizing for b/l motors ?
  235. prop selection for oval master 26?
  236. Counter Rotating Prop Selection??
  237. Help with sizing a prop on a stealthwake 23"
  238. In search of CNC M645
  239. Cutting Down Prop Diameter
  240. 32" Deep V Prop Help
  241. What difference about De-Tongued Series or standard Propeller
  242. Prop size for converted 1/8 scale hydro
  243. Genesis help
  244. Prop Alternatives to ABC?
  245. Recommend me a prop.
  246. cnc props
  247. need new prop blackjack 24
  248. Impulse 31 prop
  249. Help with prop choice
  250. Looking to upgrade props on zelos twin
