View Full Version : Prop Talk
- Prop Suggestions for the Daytona/Genesis Cat
- Pre Balanced Props
- Prop Question
- Give me some prop balancing education
- 3 runs on plastic prop...need advice please
- 18'' Mono, 2848 3900kv on 2s LiPo, what prop size?
- prop foe supervee and 1500kv motor
- Is this too much prop for my boat
- Need prop help?
- Prop choices...
- Prop For Catamaran
- Twin cat props.. in or out ?
- Prop Logging
- Miss Geico prop question
- prop question
- Why a smaller prop for higher "s" battery?
- losing cable and prop
- 1/8th scale hydro prop
- Looking for L&R 642 props
- X445 vs M445 ???
- Octura x442r/x442
- New props to test on ekos cat
- Prop with less lift..
- Shockwave 26 Brushless prop question
- Welcome to the Butch and Hack show. ABC 17 series prop before and after.
- another genesis prop question
- B&S Of Props
- Twin Apparition -props spinning inwards or outwards??
- Resutls with new x442's on ekos cat
- aquacraft ul - 1 help please.
- Hydro boats
- Step up from X443, X642, M445 or X445?
- props
- Prop m445
- What Prop Single EKOS
- Does anyone have the hub length on Octura x450 & x452
- Prop for Capricorn 54
- Prop for my Jolly Cat
- Newbie question on prop installation
- Prop Hub Width
- 1/8 hydro
- effective blade area
- Amp load on opc tunnel
- Prop for miss. geico
- TT Outlaw Jr.
- 1/8 hydroplane
- Props for Titan 33
- Help: Looking for Pictures of a N940
- Counter-Rotating Props - Direction for Offshore??
- Any thoughts on a 1090kv 5692 leo/ 8s 40c (4x 4000mah) 41" Fantasm w/ x457/2?
- df25 prop question....
- TenShock Props
- X670 Castle 2028 10s need for speed
- Prop balancing...
- Prop pitch gauge ?
- Which prop? 12s mono
- Do streamlined prop nuts make any performance gains or it for looks?
- props for DF33
- Any Prop Balancing & Sharpening Services??
- Propellers 1.9
- meahn machine, possibly under propped??
- how to unload a prop in turns
- Description for ABC props
- Help with prop selection to spartan
- Prop choice for Miss Geico and Impulse 31
- Spartan w/40x52 3 blade
- big prop but want bigger for spartan
- hydro
- What's your take on carbon fiber shaft for a solid shaft?
- Newbie advice please..
- prop for joysway offshore warrior
- fightercat 3 blade props?
- H5 prop, what is it best for and what's the total pitch?
- Can someone please help me. Genesis twin, looking for props.
- You get what you pay for...
- River Cat twin props advise
- ABC props
- nata2run please email me
- Prop help for stock AQ Rio EP
- Which prop ???
- Dynamic high speed balancing services
- 73" Mystic...1/4" prop options
- Prop Suggestion!
- Need left and right 3.2mm props
- Q sport hydro prop suggestions
- 114cm mystic prop choices ?
- Prop advice
- what prop to use
- What prop is compatable to the octura x442
- Prop Suggestion
- Starting prop for Persuit?
- New to rc boats, Prop question
- CNC Props?
- Octura M440 versus X440
- Prop Installation tips
- Another newbee question ! Will this prop work on my UL1 ?
- Prop choice for a 29" TT Outlaw Jr OBL
- Jam nut and bullet nut fastening a prop?
- Tools of the Trade
- New boat
- Total pitch of this prop??
- UL-1 Prop
- proping my gensis
- Chine walk DF33
- Wich Props for my 41" Zonda/Carbon Cat ? (from Horracing)
- What do you think about CNC aluminium VXPerformance propellers?
- Stiletto with Leopard 3674 220 kv- prop size?
- Best prop...
- Revolt 30 how too hit 70mph
- Under propping?
- pursuit 32 lipo
- Prop Saver
- Prather Props
- mm and apparition prop suggestion
- Race prop...
- what prop
- next good prop for my spartan
- Proper Prop...
- Prop Hub Diameter
- UL-1 Prop
- Need help reducing lift please
- teflon liner replacement
- what prop? PT hydro 1515 1Y
- Biggest prop for a boat of specific size
- cnc prop flute tip breakage
- help with balancing props?
- Hub balance issue - best to correct?
- traxxas spartan 4082.180 esc 11/1 25c 3s upgrade prop sizes
- 3 blade prop for spartan?
- Custom prop work...
- Prop Suggestions - 22.5 Mono
- wich prop 20" mono
- x445 cut down to 41?
- Let's Talk Camber
- Need help with prop for genesis and Leo 4082
- Great propeller info and pictures in SweetAccord gallery
- JAE 21 prop help???
- Another prop question
- Prop speed????
- Smallest prop for 1/4" flex
- vanquish on 6s
- M verses X series Octura Props
- Whats a good prop for a UL-1
- 4s Cheetah prop options
- 3 blade prop questions
- prop suggestions
- New Miss Geico V2 on its way .
- Props for smaller boats
- 1/4 inch props any sources?
- Any one run or know these props
- Can't get a prop nut off.
- drill out 3/16 props to 1/4"?
- X440\3 leo 4074 seaking 180 impulse 31v2?
- Proboat Mystic 29 - upgrade prop?
- Prop Tongue
- Prop reccomendation for 26" mono with 700bb & 4s lipo
- cleaver prop 5518
- Mystic x645 any good?
- Prop info??
- how to de-lift a prop
- prop upgrade question
- King of shaves p1
- Octura small props Shaft Size: 1/8 "(help)
- What prop for bj26 stock
- Traxxas blast
- CNC vs octura?
- Prop lift for cats
- Prop ? on Genesis boat
- the right choice for geico
- prop help for wildcat ep
- Prop Info ....
- Genesis props
- Which way do u guys spin your props in a twin cat ?
- Rio EP prop help.
- Favorite Prop on the JAE
- 1st attempt at thinning/blueprinting
- Brass prop center hole needs reaming
- prop tachometer
- looking for some prop info
- Prop polishing?
- New To Forum, with Prop Question
- Polished prop.
- Magnetic Prop Balancer help
- Cnc prop modifications.
- 2 blades vs. 3 blades
- Thread a 1/8" prop shaft - which is the correct die to use
- Wanna go stainless
- World's Fastest EP Boat Propellers
- Prop for Genesis Offshore with stock motor and 6s
- Anyone out there sharpen and balance props
- Boat calculator
- Octura M or X
- Shockwave 26 V2 prop question
- hub inbalance
- Prop choice for 6 cell Pursuit 32.
- Any one use VPX Props?
- Supervee 27 prop
- Miss geico motor
- Prop Advice
- Hello Guys
- Pitch vs prop size
- Stock rio ep prop.
- prop advise
- Best Prop Advice
- carbon prop on a cheetah?
- Which would cause more amps?
- 6s Cheetah prop options
- Aquacraft Prop Material
- which octura prop??????
- Where to find M545 CnC equivalent?
- ABC H-7/10 Octura equivalent?????
- fastest way to thin props...
- ABC H6 Specs
- AquaCraft Lucas Oil Cat Prop?
- 1/8 scale prop.
- Which prop balancer do you use?
- Starting a new build soon, i need help with prop selection please!
- New Props
- 32" pursuit 1521 1y 1500kv prop choice?
- prop screw up
- My home made prop holde.
- 1/8 prop on 3mm shaft
- Starting point for props?
- which prop for the mg24
- X442 + small weed = nicked blade... is this normal?
- Need picture of pliers for bending prop blades
- What did I do????????
- Whip 20 Help me break 70mph
- Props of choice for PT Stealth?
- Prop School - From the Mercury Racing Site
- Latest Octura Prop Chart
- Genesis what prop
- quick question about stock UL-1 prop
- Prop help. 43" conquest 2028 castle
- Al CNC PROP MOD.
- Good prop for motley crew?
- m 445 prop
- props before and after harding
- how to cut down props ?
- Prop for rescue boat?
- Propeller Static and Dynamic balancing U-Tube
- BBY 30 inch 4s oval prop
- How do you determine what prop is best for your setup?
- Prop Rotation - Twin set up?
- counter rotating triples
- Is there any gain to cutting down a carbon filled prop ?
- props Jae 21
- Prop comparisons charts
- 56 inch cat prop advice
- 3 blade prop equivilent to a x450
