View Full Version : Proboat Miss Geico 29 BL Catamaran Q & A
Pages : 1 [2] 3
  1. Best stock shot
  2. cc1515 in Gieco
  3. 4s (38.1mph) and 6s (54.7mph) video
  4. Miss Geico Run today
  5. grim racer prop balancer
  6. miss geico 55.6 mph 4s
  7. Do you really need the programming card?
  8. what size wire drive and collet
  9. newbee looking for best bang for $
  10. Stock motor timing
  11. Confused on what prop to start with?
  12. 5.5mm Bullet Connectors?
  13. Proboat Mis Geico PreOrder review
  14. failsafe
  15. smoke test
  16. Do Higher C lipos run cooler then lower C
  17. Kintec Flex and teflon
  18. More effiesient???
  19. props
  20. Lipos wont work in my MG....
  21. Stock MG cooling jacket
  22. side to side chine walking
  23. water in my MG. Where from?
  24. 6 cell prop help (stock motor)
  25. Castle 2200 - 6cell setup - Overheated and broke the shaft
  26. Strut bush
  27. where did you get your MG !!!
  28. stock esc
  29. Stock MG Lipo suggestion
  30. How to hook up 4s pack
  31. opinions please
  32. My Geico is too light - HELP!!!
  33. take a look
  34. First Run on Miss Geico!
  35. Best way to configure new esc and motor?
  36. My Geico, and how I got it.
  37. MG left fron damage
  38. new miss geico
  39. 2 Props in 2 days
  40. My Miss G.
  41. news
  42. 078 Wire Drive
  43. stock motor timing using SK180 ESC with 5 cells
  44. Custom Offset Bracket
  45. separate cooling lines
  46. Lipo Batteries Dead after two runs
  47. New Proboat Mystic 29 Cat BL PNP AKA Miss Geico
  48. How did YOU tune you're Geico? Coz I need help
  49. TURNIGY 180esc and Stock motor in MG
  50. Miss Geico Upgrades
  51. Different volts left after run
  52. Miss geico cross breed....?
  53. Remove Stock Strut Bushing from MG
  54. etrex h
  55. Is my hull from a bad casting, and what can I do?
  56. anyone using a Castle Creations ESC?
  57. Best battery option for MG
  58. Leopard 4074 2000kv vs. 2150kv?
  59. Brand New Geico, throttle not working???
  60. 1800kv motor results
  61. Geico question!?!?
  62. can anyone help me out with the lipo lingo
  63. LSO Geico makeover
  64. blow over at 48
  65. Ms Geico Rudder
  66. how do i run 4s in my mg
  67. 8XL in my Geico
  68. Miss Geico, Finland
  69. What is your best speed?
  70. Lipo Questions
  71. High temperature
  72. Motor Mount
  73. Who to contact
  74. Dx3e
  75. Carbon Fiber Hull, Miss Geico
  76. 4074 cut to fit???
  77. MG turning abilities
  78. modified geico
  79. M,iss geico+7040 200kv. What prop on 4s/5s ?
  80. Batteries?
  81. geico gone mad
  82. 2200 castle motor, what battery should i run?
  83. The bounce..
  84. MG Coming apart 8(
  85. Bad blow-over
  86. Water..in my boat??
  87. Flexshaft Liner: MG29 How does this come out and when do i know it need to be changed
  88. Water cooling problem
  89. Loosing prop power
  90. Brake on 45a proboat esc
  91. Straight up answer no boat builder bla bla
  92. New to forum and FE boats!!!
  93. Problems setting my esc with the PRB3311
  94. Lipo case removed
  95. MG Radio Issue?
  96. Miss Geico with 2200KV motor
  97. Stock MG ESC intermittently losing its lipo program and lipo puff
  98. Newbie ms geico esc question
  99. Sea King 180a ESC water resistance?
  100. Reversed cooling hookup?
  101. progress..
  102. leopard 4074 motor 2200kv
  103. A few lipo and nmh questions.
  104. Miss Geico rebuild, repair & destroy
  105. Which Eagle Tree to get?
  106. Geico updates from proboat?
  107. MG Strut
  108. looking to build the fastest mg out there
  109. Will my ESC hold up
  110. LIPO cells
  111. To Fix or replace my MG
  112. CC Hydra Ice 240, good chioce for MG w/ Leopard 4082--2200kv?
  113. Where to mount extra water pick up tube ?
  114. Kintec offset rudder v2 pics
  115. Esc glued to fuselage?
  116. Broken hatch!!!
  117. ESC cooling line
  118. Grimracer prop versus x642???
  119. Help with Miss GEICO that is stock want to make it go 40mph.....
  120. Stock MG motor timing?
  121. Which one M445, X445, X642,X645, S220......?
  122. Miss Geico Parallel???
  123. Horizon hobby A OK Please read
  124. turnigy T-180 programming
  125. Miss Geico as submarine and aircraft
  126. M Geico. m445/P220/42x55 and x442 on 5s
  127. 2 (4s) in parallel, will they fit???
  128. Mg all out no limits upgrade advise needed
  129. How do I make a parallel 5.5" bullet adapter?
  130. Spektrum Mr3000 2.4 RX and mr200
  131. question with stock flex cable vs. OSE MG flex cable.
  132. Geico Help please
  133. Gps ?
  134. Water cooling question for all
  135. Miss Geico 4s2p/5s m445 video. With water issue
  136. Ultimate Miss Geico setup.
  137. Miss Geico motor
  138. Will it explode!!!
  139. 5.5mm covers ?
  140. kintec offset
  141. Could you look at this drive setup pic, broke a driveshaft and need advice
  142. Cracked my Miss Geico Hull.Repair advise
  143. Motor wieght help
  144. fightercat
  145. Rudder bushing size or place to buy????
  146. Just bought a Miss Geico with UL1 motor/esc!!!
  147. Ok verdict in on the prop and speed
  148. teflon liner?
  149. HELP: miss geico not working right after being flipped.
  150. 4s Battery that FITS without modifying
  151. Problem with esc or motor
  152. Rudder replacement
  153. to thrust bearing or not to thrusrt bearing
  154. Flushing or cooling system!
  155. Miss Geico rough start up on 5S
  156. Best Aquacraft metal prop for MG
  157. Servo Twitching
  158. Miss Geico. Rerouting hardware?
  159. Lost the little coller on the back end of the strut...darn!!
  160. Am I missing anything?
  161. Any idea what this boat should do?
  162. Looking for mod ideas for MG 29
  163. Ran the Miss Geico today for the first time!!!!
  164. Help??????
  165. Im melting help
  166. Lost this part of the ruder
  167. geico ul1 motor question
  168. miss geico ul1 motor 5cell x440 3 blade video
  169. Saltwater???
  170. How to improve performances
  171. MG Tiqueman Edition
  172. Ul-1 motor 60A esc question
  173. Ice 240 in MG
  174. Miss Geico with CC1515 2200 and t180A first run!!!!
  175. Transom fix
  176. Motor questions - Novak?
  177. Miss Geico ESC Programming Info
  178. motor and hatch
  179. mamba monster
  180. Miss Geico, no more. Now she's "green with envy" :P
  181. Batteries question
  182. Proboat miss geico sponson seam are spliting open
  183. Which TACON
  184. Best setup ?
  185. Your MG that started off as a hull
  186. Battery charger
  187. Guess you can run all year long
  188. Replacing teflon liner
  189. Looking to purchase a Miss Geico/Mystic
  190. Miss G mods question
  191. prop?
  192. anyone know the width of the Kintec offset rudder bracket for the Miss geico.
  193. Who says you cant drive a boat in the snow
  194. Sky lipo
  195. question with adjustments on the strut
  196. Motor Problem
  197. ESC advice needed
  198. Miss geico prop.
  199. Motor Suggestion
  200. My Geico runnin strong
  201. extra caps seaking 180
  202. Maiden run:)
  203. timeing esc
  204. Miss geico and Mystic parts
  205. battery placement and strut positioning
  206. What mods.first
  207. PB miss Geico
  208. 5s Run results
  209. Paint?
  210. Miss Geico Set up???
  211. Newb has questions
  212. New to boating, need some tips fine tuning
  213. programing esc
  214. What prob best for stock motor with 6s lipo?
  215. New MG Owner and Have a Few Questions
  216. Problem with new Seaking 180/4074 Leopard2200kv . . . need help!
  217. Battery question
  218. Best prop for 4s?
  219. OSE flex cablecable question.
  220. Setup
  221. I Give Up on this thing!! Please Help!!
  222. MG hard mode timing
  223. First run on the Geico a disaster
  224. First Run on friends MG
  225. miss geico is a winner
  226. Max stock motor speeds.
  227. Just a little more for my Miss Geico
  228. MIss Geico with Tacon 3674
  229. geico paint
  230. Leo motor help in mg
  231. Miss Geico on 6S
  232. leapard 4074
  233. New newbie questions!
  234. How to pressure test the water lines?
  235. Stupid Question? Strut Adjustment?
  236. New Miss Geico Setup.
  237. Just got into boating and have a question. moreso advise
  238. Near crash and burn - need help
  239. Stuck on full throttle!
  240. What esc with reverse will work
  241. Help Me! Please!
  242. miss geico reborn
  243. Calculating unloaded Motor RPM with Lipo's
  244. Mg strut bushings help please
  245. Up in smoke
  246. Fried new aquacraft 60 amp esc and 2030 kv motor
  247. Geico set up
  248. Leopard 4082 2200kv....newbie
  249. Mod Time
  250. Turnigy 2700kv 3660?
