View Full Version : Proboat Stiletto Tunnel Hull Brushless Q & A
  1. Steve, you need a new forum! Proboat Stiletto
  2. ProBoat Stiletto Videos
  3. Placed one on order
  4. So Darin, Did you package Arrive Yet?
  5. Stiletto Race Prep
  6. Stiletto "In Stock" Date...
  7. Stiletto First Run w/New Boat
  8. will it work?
  9. Props and Speed?
  10. fiber glass help
  11. Nitro Stiletto
  12. Stiletto steering
  13. fe verses nitro
  14. recommended C rating packs
  15. Crossing the brand name line
  16. leopard motor
  17. Stiletto ESC cooling question
  18. Stiletto fliping on take off
  19. stiletto on iphone
  20. Painting candy over the silver
  21. new stiletto dead in the water
  22. rek on stiletto
  23. Ni-MH vs. LiPo setting from the factory
  24. Diesel's Stiletto
  25. New Stiletto
  26. Stiletto Setup Feedback - Post Your Setups here, guys!
  27. Stiletto Battery and Charger Help
  28. What material is the Proboat Stilleto OB cover made of? Plastic or fibreglass?
  29. Tunnel lovers
  30. water comming in cover holes
  31. 5 cell lipo?
  32. Stilletto Mercury 225xs Outboard Decals
  33. center of gravity
  34. Do I Cut Them?
  35. help on my stiletto
  36. Stripping down the Stiletto for Paint!..Anyone else?
  37. stock timing on stiletto
  38. Stiletto with different brand tx rx?
  39. First Run - Stilleto
  40. 1st tunnel hull... -why the left sponson is wider then the right on stiletto?
  41. Turnigy 120A esc in stiletto?
  42. stiletto prop not spinning, wont run
  43. upgraded stiletto
  44. messing with stiletto
  45. Need stiletto flex shaft by this weekend!
  46. What c rating pacs are people using?
  47. What about an outrunner in the stiletto?
  48. pro boat stiletto l40 x 57 prop opinions
  49. Source for tools? (7mm & 8mm open end wrenches)
  50. Pb stiletto outboard efficiency
  51. Water problem
  52. flex shaft question
  53. What props?
  54. Pro Boat Stilleto + DX3s
  55. Batteries, Wires and Connectors Extremely Hot!!!
  56. Trip Outboard Steering Servo Question
  57. Stiletto Flex Shaft Length
  58. Anyone find a successful 3 blade prop for a stock stiletto?
  59. newbie
  60. Turnigy 120A marine esc fitted. What timing?
  61. what esc?
  62. New to the Pro Boat Stiletto..
  63. Advice please on the Stiletto..
  64. One dunk and Iím done?
  65. Eliminating that annoying cable on the stiletto...
  66. Run Times..
  67. Outboard cowl?
  68. "doh"
  69. Slower with x642 than x640?
  70. new decals on my Stiletto
  71. my new to me Stiletto
  72. Stub Shaft Pin..
  73. busting flex's
  74. Turnigy 120 ESC..
  75. cutting out
  76. Lipos..
  77. What upgraded motors are we using?
  78. Turnigy 120 ESC Programing..
  79. New Stiletto..Painting, propping and mods! (Let's race!)
  80. Just fitted a 4074 200kv to my stiletto!
  81. interference?
  82. Which prop now?
  83. whats the best way to.........
  84. drop in outboard on stiletto
  85. Throttle cuts off.
  86. New motor fitted. Turnigy xk-3665 2100kv
  87. Anyone sharpen the bottom area of the outboard?
  88. Outboard case screws
  89. servo
  90. Prop Nut size???
  91. Cooling lines???
  92. dead li po
  93. New Stilleto Owner
  94. What are the Best Upgrades to Stiletto?
  95. Stiletto stub shaft assembly in K&B 3.5 lower?
  96. motor bearings
  97. Is the Proboat Stiletto being discontinued?
  98. stiletto esc programming manual
  99. Pro Boat Stiletto Motor Quastion
  100. help!!!
  101. 5 cell vs 4 cell
  102. decals
  103. Antenna Mounting Question
  104. leaking Stiletto hull
  105. Seaking 120A ESC - what timing with Stiletto standard motor?
  106. Pro Boat Stilletto 29 transom cracked, help please
  107. stiletto esc question
  108. Can I replace waterproof servo in my stiletto ?
  109. Stiletto
  110. Proboat Stiletto
  111. Looking for upgraded flex liner maker
  112. stiletto
  113. Li Pos
  114. Stilleto info
  115. p class stiletto
  116. Proboat Stiletto: speed control and program card questions
  117. ESC troubles
  118. stilleto tunnel hull ?
  119. Batt. cover
  120. 4-40 link steering mod...
  121. Stiletto motor
