View Full Version : Battery Talk
Pages : [1] 2 3 4 5 6
  1. Good cheap battery packs?
  2. Battery question
  3. Attention Battery Experts: What is considered "Good" IR for a 6-cell NiMH pack???
  4. Battery Vents
  5. Battery Help Needed
  6. battery question
  7. Battery question
  8. Lipo battery connections ?
  9. battery amp draw ?
  10. Battery Problems
  11. battery question
  12. battery buying
  13. lipo reciever pack
  14. General NiMH Battery Information
  15. Battery Heat
  16. Battery recomendation?
  17. lipos for reciever?
  18. NiMh Battery Packs??
  19. A123 Racing Battery Packs
  20. battery question
  21. battery suggestions? a123, lipo, NiMH?
  22. traxxas battery
  23. battery mah draw question
  24. Lipo battery question, 20c enough?
  25. New Hyperion G3 Lipos!
  26. Anyone hotdogs out there try Hyperion GENERATION 3
  27. Battery Recommendations
  28. Flight Power and Hyperion G3
  29. Battery idiot !
  30. Help w/ battery please...
  31. Battery suggestion, what to choose?
  32. Hyperion G3
  33. battery charge amps
  34. quick battery disconnect
  35. zippy flightmax or turnigy ?
  36. battery question
  37. Battery test somethig of interest
  38. Bad Turnigy 3s ??
  39. Battery wire question
  40. brand new turnigy lipo failure!
  41. best non lipo battery
  42. HiTopMax 4500mAh 35C LiPo Battery
  43. Hyperion G3 LiPo
  44. Turnigy Cells Crush G3's
  45. HITOPMAX, TURNIGY or FLIGHTMAX
  46. Hyperion LiFePO4 TX&RX Packs
  47. Battery discharge rate
  48. Zippy and Turnigy Batteries?
  49. NeuEnergy Lipo ??
  50. Lipo Battery's- Price drop?
  51. Turnigy Battery
  52. Zippy Lightmax 5800mah lipo
  53. 3s1p with a DF Vortex??
  54. Large capacity lipo packs no longer?
  55. Lipo run time.
  56. Cycling
  57. Well... Boo
  58. Turnigy lipo problem
  59. Check this out
  60. This kind of news can't be good for lipo
  61. What lipos for my hpr 115
  62. Just Got a email Alert from Hobby City
  63. Can I do this???
  64. Battery combo's
  65. Balancer or Not when charging???
  66. Li-Po repair
  67. Lipo's in fridge? Doesn't that violate the 20 degree temperature change rule?
  68. venom battery question
  69. Arcing on battery connection
  70. Looking for battery meter?
  71. ..so i found a site that sells packs real cheap... intellect batteries and more
  72. How many days do you keep your lipos at full charge?
  73. Charging station
  74. 10ga wire w/ 6mm gold bullets/ thunder power 3s question
  75. Question - Charging Time
  76. nimh charge amps
  77. shortening in series set ups...
  78. The great connector debate
  79. Should charging AWG = Discharge wires AWG?
  80. Batery and esc recomendation
  81. Soldering on cap bank, can you get caps too hot?
  82. They are back in stock Turnigy 4500mAh 2S 30C
  83. Turnigy 10s Packs
  84. Lipo questions
  85. Having lipo problems
  86. Turnigy 40c 4000 mAHr 4 cell?
  87. Thunder Power 45C VS. XPS 30C packs
  88. New toys and battery issue
  89. is it ok to charge 5400 mah lipo packs at 5.0 amps?
  90. what battery to use?
  91. Hard case Lipos
  92. Can someone explain 2s2p to me please?
  93. Do what I say, not what I do
  94. Turnigy 5000mah 30C 2S in stock at hobby king
  95. Hyperion G3 Batts for sale
  96. FYI - HK and shipping Lipos
  97. Is this true when charging Batterys?
  98. Battery harness using 5mm bullet connectors?
  99. 6S from 3-2S packs?
  100. Did I fry my LiPos?
  101. Getting back in the loop. cheaper lipos
  102. lipo reciever battery
  103. Lehner 1920 battery sugestions.
  104. Charging lipos under capacity?
  105. soldering iron
  106. Battery selection
  107. Brand New Flightpower Battery Packs
  108. HPR 233 FE battery selections??
  109. Charge rate on zippy and turnigy lipos
  110. Regenerative Discharging
  111. Which One????
  112. lipo balancer help
  113. What voltage to charge at???
  114. Newbie ? How to charge lipos
  115. Help on battery choice for newby
  116. 11L motor timing
  117. Quad Lipo chargers
  118. Question on Storing Lipos
  119. Cell Voltage After Charging....
  120. Anyone ordered from this place?
  121. rx pack
  122. Turnigy Nano Tech is here!
  123. Lipo Para wiring??
  124. New cells
  125. turnigy nano-tech batteries
  126. 1 cell not registering
  127. Do lipos drain ??
  128. Lipo puffed when not used in storage?
  129. possible lipo fire situation??
  130. power supply what's good? IS THSI?
  131. "New" Lipos from turnigy
  132. Weird battery situation
  133. battery placement in outboard tunnel
  134. What?????
  135. Is this battery shot?
  136. Turnigy batteries - quality problems
  137. How to dispose of lipos
  138. Batteries Submurged in water- Any danger?
  139. Best site to order Lipo Batteries???
  140. 10,000 MaH ?!
  141. Lipo packs 35mm wide
  142. connectors pk 4mm
  143. cheap "Honk Kong" lipos
  144. Small packs or big packs.
  145. Quick lipo question
  146. Interesting Multi Voltage Packs....
  147. Anyone know who has Turnigy 3s1p 5000Mah 40c's in stock?
  148. Nimh batteries
  149. Where can I find aluminum battery trays ?
  150. Charging 2 2s1p packs at once?
  151. I got another Mah ?
  152. wiring series and parallel
  153. safe discharge for trash question
  154. New to lipo's. Is It overcharged?
  155. Any difference between Zippy vs Turnigy other than price?
  156. swollen packs?
  157. Newbie battery question
  158. BQY LiPo batteries ??
  159. Venom lipos discharge ability test
  160. Lipo's in parallel
  161. Win Force lipo
  162. Battery set up formula
  163. warming up lipos
  164. Small Couplers
  165. 2-3s in series????
  166. Can Equinox balancer keep up parallel charging?
  167. Lipo Wiring Question
  168. Puffed Lipo
  169. ni-mh batteries
  170. battery help
  171. 4 Battery EagleTree Comparison
  172. frockin five second rule
  173. Power Supply
  174. LiPo Cells Unbalanced
  175. Lipo Question?
  176. Super Duo
  177. charging lipos. warm or cold ?
  178. Open Connection
  179. proper disposal of lipos
  180. nimh cells slow at first on full charge
  181. Battery Problem question?
  182. Best Connectors
  183. Turnigy "nano-tech"
  184. Hyperion Duo II question
  185. is my 2s pack junk?
  186. have another 2s pack. one cell reads 4.10 and the other 3.30, any way to fix this?
  187. Spark when hooking up lipos?
  188. 2S pack swells after run
  189. 1p - 2p ?
  190. best lipos
  191. Lipo Care and Storage
  192. Question re: lipo capacity
  193. Sending lipos back to HK for warranty work
  194. Battery Heating Question
  195. Can batteries just catch fire sitting??
  196. lipos for the ul-1
  197. Hyperion Lipos
  198. Hyperion lipos 35c vs 45c
  199. Blue Lipo???? good or bad
  200. Turnigy 4s Nano-Tech 45-90c for Pursuit boat?
  201. Why is this new Lipo battery not recharging?
  202. HobbyKing now has a USA Warehouse?!?
  203. Battery check
  204. 2 Batts, 2 ESCs, 1 reciever
  205. 2s2p vs 2s1p
  206. Lipo Vs Ni-mh
  207. new to boating
  208. Are 20c 8000mah packs hard on the ESC?
  209. lipos in a fire safe.......
  210. Cold Storage of LiPo's
  211. Lipo mah size for a tenshock mono1
  212. Will an IOTA 90 amp supply run 2 Hyperion DUO 3 chargers together?
  213. Turnigy nano tech lipos
  214. Low Voltage cutoff devise
  215. battery wiring
  216. Does the c rating really make a difference?
  217. Hyperion G3 Battery ??
  218. just how important is it for the cells to be accurately balanced ?
  219. Damn turnigys (thick wires)
  220. what voltage do you charge your lipos to?
  221. hyperion G3-EX 5000 mah 45/90c 6s packs.. voltage seems off.
  222. Which batteries do I need?
  223. charging batteries together
  224. Serial config with different MAH
  225. Hard case LiPo's
  226. Bad LiPo?
  227. Charging in serial or parallel
  228. Eagle tree V3 bricked. How to bring back.
  229. Wiring lipos in //
  230. LiFe for receiver.....
  231. using hardcase packs in boats
  232. LiPo Storage ....
  233. these look new to me. anyone use them?
  234. Keeping Lipos outside in the cold
  235. Need help choosing batteries.
  236. hobbypartz lipos.... free shipping
  237. What is the difference 2s 1p or 2s 2p ?
  238. Bad cell?
  239. Hobby King Battery Sale
  240. Need info on how many mah's needed
  241. Puffed pack??
  242. Value Hobby lipos
  243. using 2p
  244. Battery discharge rate
  245. rx packs
  246. Another Great Site with great info...
  247. eos sentry battery checker
  248. Anyone use these batteries?
  249. Lipo junk?
  250. What are good mimh battereis?
