View Full Version : Battery Talk
Pages : 1 2 3 4 [5] 6
  1. What batteries?
  2. Help! Newbie Quesstion
  3. saw hydro
  4. Ok I'm lost!!!
  5. pulse batteries
  6. Bizarre Beeping?
  7. lipo battery discharge rating
  8. 2P Lipo set up ?
  9. Need help on battery set-up for my Genesis 900
  10. Battery help!
  11. Proper lipo disharge ?
  12. http://www.hobbyking.com/hobbyking/store/__38515__Turnigy_Heavy_Duty_Series_5000mAh_6
  13. Revolectrix HV 70C lipos
  14. Bought 2 lipo, one of them using many hours to balance
  15. Noob 6S battery question.
  16. breaking in batteries
  17. Help with picking lipo for racing setup
  18. Help Please new to LIPO and they are confusing!!!!
  19. Lipo discharge when its stored with full power?
  20. after deciding on batts and charger this happened 30sec into maiden voyage
  21. Will it fit
  22. Power?
  23. dinogy batteries
  24. Lipo wire loose
  25. QUICK DISCHARGE: Dumb Question of the Day!!
  26. Dumb thing of the day
  27. Can a Lipo short if it contacts marble?
  28. transmitter battery packs
  29. Electric Newbie
  30. New hobbyking 90c lipo
  31. Different capacity mah can use parallel plug together to play ?
  32. C rating Question
  33. is this battery balanced close enough
  34. Lipo run-in
  35. Nanotech 3s 65 c vs. Dinogy 3s 65 c.
  36. Two 6S 5000 mAh same as one 6S 10000 mAh?
  37. 3s to 2s capacity
  38. 4s, 5s, and 6s Battery Recommendations?
  39. SMC VS Dinogy lipo battery
  40. pulse batteries
  41. Any opinions on the Zippy 8000mah 30-40c ? Looks good...
  42. Advantage/Disadvantage of C ratings
  43. Now What Do We Do??
  44. Anyone tried these high voltage batts? 4s 15.2 v 65c
  45. 14.8V 5000 MAH 40C Lipo issue ?
  46. 2s 40c 5000mah vs 2s65c 6000mah
  47. oynx 245 charging 8200mah lipo
  48. Batteries and conections
  49. Lipo Melt Down
  50. Batteries hot?
  51. Over charging while in Parallel
  52. New to fe and not sure about battery mah
  53. Mean Machine 4s to 6s
  54. Longish battery leads, need caps? Swordfish 240/15271Y/6S Parallel
  55. Newbi battery/charger question
  56. Best 3s Battery for Traxxas Spartan
  57. battery comparison....
  58. prop spinning wrong way...
  59. Running 6S: 2 x 3S in series OR 2 x lower mAh 6S in parallel?
  60. parallel charging on three powerlab 8
  61. esc
  62. Soldering 5.5 mm bullet connectors- best way
  63. Revolectrix
  64. Turnigy Bolt LiHV batteries - what we know about
  65. Save weight?
  66. fully charged battery
  67. Hard case LiPo swells and then returns to normal??
  68. Hobby Kings Awesome Soldering Jig!!!
  69. wath means wen only the wires and bateries hot and the motor e esc continuous cold
  70. Trying 6s and props
  71. Nanotech 65C with a dead cell
  72. Fast Charge. 70% in two minutes.
  73. battery resistance
  74. charging in series
  75. Interesting observation.....
  76. Hyperion Battery Failure
  77. best way to put lipos to sleep
  78. Revolectrix Fedex shipping to Canada
  79. Batteries Storage
  80. Mean machine 6s parallel???
  81. Tunigy Nana Tech Batteries / Traxxas 3s Replacements
  82. Explosion! Fire!
  83. Can I use 3x2s lipos to run as 6s??
  84. Auto-disconnect discharger
  85. One Pack
  86. Puffed batts
  87. What is the lowest temp to store Lipos..... Your thoughts?
  88. Say it ain't so, PLEASE! Atomik Stupidity!
  89. Looking to purchase a good 4s 5000mah 50 c lipo
  90. P Sport Hydro 1P or 2P
  91. lipo cell voltage
  92. has anyone used lipo paraboards for charging ?
  93. revolectrix
  94. HIGH "c" or HIGH amh.....
  95. Turnity Bolt LiHv better than other lipo?
  96. Upgrade to higher mah
  97. Hyperion lipos any good??
  98. Aero model 90c 2s shorty packs
  99. Using HV batts charged to 4.2V
  100. O snap! look what's coming!
  101. What charge is on the batteries when shipped
  102. Battery for receiver or BEC
  103. What batteries for my 1380mm cat?
  104. MEAN MACHINE Owners
  105. Changing cell count
  106. How I made a 3p battery harness.
  107. Internal Resistance limits for LiPo batteries
  108. Highest Quality LiPo Packs
  109. Battery storage-Fire Cabinet
  110. Lipo Battery Internal Resistence Test
  111. Revo questions
  112. Matching batteries question
  113. Would like some opinions....
  114. Glacier rc packs fail
  115. Anyone ever use these connectors?
  116. Best Battery Manufacturers
  117. revolectrix
  118. Thunder Power Lightning 55C batteries. Anyone tried them?
  119. Hyperion G6 HV
  120. Possible LiPo issue
  121. Charging new lipo batteries ?
  122. Running in new packs. Discharging them!
  123. Ever use hv AA batteries?
  124. Good lipo checker
  125. Need some cheap quality lipos!
  126. 6mm bullets vs 5.5mm bullets
  127. NIMH batteries with brushless setup, yes or no?
  128. Mah
  129. What connectors for 8s?
  130. Atomik Barbwire XL
  131. Are water cooled lipos necessary?
  132. Good LIPO Batteries that dont break the bank
  133. Boat Died....Need help
  134. lipo battery very hot and swell
  135. esc warmer than normal
  136. Can and will shorter wires reduce temperature of the batteries?
  137. Revoelectrix blown cell?
  138. Warning.
  139. Battery Puffing Issue
  140. Over charge battery
  141. unpluging leads from charger
  142. No Revolectrix to Australia / New Zealand. What is going on?
  143. Water Cooled Batteries
  144. TP Batteries
  145. dead lipo
  146. battery problem
  147. Puffed Lipo?
  148. Minimum required Mah for Limited Sport Hydro?
  149. Too hot to store lops
  150. HK Batteries never again
  151. Proper LiPo Storage...Take It Seriously
  152. After run, 3-cell LiPo checks cell 1 ~ 3v, 2 = 0.3v & 3 ~ 9v
  153. Something came in the mail today....
  154. How do you tell if you should ask for warranty on a nanotech?
  155. 3s in series vs 6s in parallel?
  156. VENOM BATTERY SALE @ Atomic RC
  157. "Safer" and Longer Lasting Battery Technology -- Coming soon!!!
  158. Revo 435 vs 427 ...
  159. 4s vs 4s
  160. Giant power lipo's ?
  161. Question about battery wiring
  162. Lithium dielectric grease on battery bullets?
  163. how to make lipos safe for disposal
  164. Lipo Load Bank for Discarging (moved from swap shop)
  165. storage in a ammo can
  166. looking for a good battery
  167. Floureon LiPo
  168. Q Sport 40: Turnigy Batteries & Neumotor
  169. Graphene Batteries
  170. Batteries for Pursuit FE
  171. Revolectrix guys, need advice please
  172. advice on best conection for batt
  173. Something new for safer charging?
  174. Lipos puffing on a conservative setup, what gives
  175. Thuderpower Magna series70 c lipo's ?
  176. At what point do i dispose my lipo packs?
  177. More old lipo ?
  178. Battery Storage Box.
  179. What are your thoughts here on these batteries?Anyone run these?
  180. Dualsky 70c packs
  181. Revolectrix 455!!
  182. are they toast?
  183. confused newbie..what's the best set up?
  184. Lipo discharge ?
  185. Anyone interested in a graphene battery test?
  186. Degassing a lipo (lol)
  187. Theory, doubling voltage, half the current draw?
  188. Are there new regulations on shipping voltage??
  189. lipo batterys
  190. Water Cooled Venom 50 c 7.4 lipos ?
  191. Puffy Lipos
  192. Graphene lipo review
  193. offshore Electrics is now carrying the Revolectrix Graphene Oxide Hard Carbon Cells
  194. Hyperion lipos
  195. am i on the right track?
  196. What is a good over all pack
  197. looking for opinions on lipos for my conversion
  198. need help with battery choice and configuration
  199. 8 cell long packs
  200. 1st time using lipo
  201. Can I use a 2 cell and a 4 cell to make 6s?
  202. Ambient temperature and lipo's
  203. Official Dinogy Lipos Graphen 2.0 Thread
  204. Good lipo options?
  205. Safe lowest voltage under load
  206. Lipo fire
  207. What lipo battery's to by ?
  208. Line your battery box with wonderbread
  209. Battery Storage Bunker
  210. Battery question
  211. different voltage to achieve 10s?
  212. Safer Lipos On the Way ?
  213. Lipo pack being sold "pre puffed" ? :-)
  214. Battery Testing
  215. Best way to get 12s
  216. Turnigy graphene
  217. Search for the Super Battery
  218. 3.5mm gold bullet connector ?
  219. Turnigy 2s 5000 mah 40c lipo ?
  220. Revolectrix will ship to Australia & New Zealand again
  221. 4s vs 2 2s packs
  222. Battery question (new guy)
  223. Battery trays for bby scat cat 26
  224. Power Hobby lipo
  225. 10s2p connections
  226. 8mm bulkhead fittings.
  227. Smc lipos
  228. fully charged lipo
  229. LiPo Test
  230. Newbie with first question......several more to come.
  231. 4.35 lipo s or not
  232. Best deal on batteries?
  233. External lipo balancers and balancing ?
  234. revolectrix balance jack
  235. revo graphene
  236. Where do you store your batteries?
  237. New lipo maintanance ?
  238. more millamps.
  239. mo Revo
  240. Restoring Lipo Battery, best way to do it?
  241. Graphene batteries...can they catch fire like LIPO's if punctured?
  242. New Revolectrix IR meter.
  243. What size or how many mAh
  244. Uneven voltage after running lipos in parallel
  245. Looks like the revolectrix are in
  246. Battery cables
  247. Lipo alternative ideas?
  248. Parallel Adapter Question
  249. best way to dispose a 6s
  250. Roaring top
