View Full Version : Battery Talk
- Turnigy Powerlab
- lipo cutoff's
- Soldering made easy with The Jigs Up by MaxAmps.com
- Higher c rating but slower & warmer
- New a spec nano techs
- cool lipo production video
- High C rating Nano's desoldering my wires.
- Low Voltage Warning on Thunder Power / Flightpower Lipos
- Solder Questions
- Difference between these two battery checkers ?
- Turnigy Lipo Battery Charging Bunker
- continuous C and burst C rates
- How does the C rating effect boat performance
- Lipo cells unbalanced
- Haiyin batteries
- 5.5mm vs 6.0mm Bullets
- Cheetah on 12s
- Unsure if my lipo is puffy or not
- LiPo Battery error.
- Sky Lipo 40C 2cell batteries vs Thunder Power 5400mAh 2-CELL/2S 7.4V SPORT RACE 25C
- Help a newbie pick a battery and good charger
- Turnigy boat spec lipos
- lipo help for new guy please
- Asymmetrical battey placement
- Can I use 4S Lipo in my Futaba transmitter?
- Wiring Harness to Convert From 2P to 2S
- Question about lipos in paralell
- Long term lipo storage
- Newbee question
- Dont leave your Lipos plugged in
- 2S series charging.
- Shipping Batteries To Canada
- Will it blend?
- Battery choice for Blackjack 29
- OK another new guy battery question for an Impulse 31boat
- Battery Recommendations
- Battery Requirements Delta Force Pirate 35"
- Battery requirement
- High Perfromance Charging what took me so long.
- What type of connectors for Blackjack 29?
- Flight power 10s
- 4 lipo parallel wiring diagram help
- Battery to ESC extension
- C rating
- Battery info needed.
- Puffed up lipos
- Any pics of this high power parallel harness??
- venom lipo questions...
- A123 bankruptcy
- NiMH batteries
- 4s versus 6s and runtime
- Turnigy nano-tec, Zippi Flightmax???
- 6s 5200 mah 45c-85c high discharge to much for 180 turnigy esc
- 10s bec
- parallel charge board. A question
- How to keep batteries dry?
- Best Nimh
- Charging 2 - 2s Lipos as 4s - Wiring Diagram Discussion
- Hyperion g3 lipo
- Voltage drop
- Has Anyone ever used these watercooled battery coolers
- Battery plug cover
- Ec-5 connector assembly question??
- 6S or 8S? I need some help deciding which way to go.
- Capacitor and Antispark terminal banks
- Castle Hydra 240A or HV 200A?
- Wiring Question
- Lipo help...or ooops!
- 5 s setup question
- Buying New Lipos
- how to wire sf300 esc with 4 6s 5000 mah to get 12s 10000 mah correctly
- Thunder Power batteries
- Fighercat Cheetah 6s2p
- 11.1v to 14.8v system - different mah?
- Is 12s uncommon?
- battery selection
- 4 x 4S packs for a 8S2P setup - Dos and Donts
- A123 Bought by Chinese company after bankruptcy
- Can't Decide Between Batterys
- tips for storing NiMH batteries for a couple of months??
- Battery questions
- Battery Temps to High. ?
- How to determine what "C" rating to buy?
- Balance charging question
- how to seperate lipos?
- Where to buy Lipos in the United Kingdom (not hobby king!)
- Before I smoke something....
- Need help with new battery please!!!
- Battery placement for 1/12 LLumar help
- 22.2v 2500mAh 25C Lipo Batteries in a Proboat Mystic
- zippy lipo balance plug desoldered, help needed
- batts is too hot! please help!
- Long battery wires
- Duel charger vs. parallel charging - help pls
- P-Spec minimum discharge rate
- New safer Lithium battery on the horizon.
- Battery recommendations
- Antispark Connectors
- 8s2p 30c vs 8s2p 65c - Is it worth saving some money here?
- Hobby King Batteries
- can you charge 2 batteries in parallel from 1 output
- Battery Draw-Down Rate?
- onyx 245 any good
- LiPo Cell Inflation
- Lipo Cell Replacement Question
- Good Battery Offer
- My New Lipo's
- Great Deal on rx packs
- Battery/ Charger needs/wants HELP PLEASE!!!!!
- Jumped my suburban with a gens 4s 5300
- just got the blackjack 29 pro boat/charger and battery ideas
- what battery would all of you recommend
- Lipo or not to Lipo! that is the Question!!!
- Lipo charging amps
- Best Lipos for the buck ??
- Mean Machine v3 running a single 6s 5100mAh Pack?
- quick question about mah on lipo
- seperating lipo cells, weird thermal glue help needed
- 2028 voltage is 11-12s possible?
- TP G6 CloseOut
- Battery sizing and cell count configuration considerations for a Daytona on 4S?
- Affordable Lipos?
- Who makes these???
- lipo battery gets wet. what to do?
- Battery Tech Advancements...
- Battery question
- Lipo Damage
- Replacing balance plug?
- Thunderpower pro force G8 70C lipo batteries .
- hyperion 6s 5000mah charging problem
- Venom battery question
- ESC wiring opinion
- What to do with dead lipos?
- Battery transportation
- 5.5 plugs on batteries and harness's
- Lipo battery out of Balance question
- Newbie Battery Connector Question
- Need some 3S cells, have dinogy and am very happy,but I need some inexpensive cells.
- Trouble getting lipo to balance
- Thoughts on the icharger 4010?
- cell resistance
- Dunb people
- how close to stated capacity do your packs get?
- charger cuts out?
- Question on a balancing board
- running 2 2S lipo parllel
- Vant Battery
- Recommendations for portable charging
- 7S Lipo with 4S and 3S balancers
- Converting a 3S battery to 2S
- Lipo dropped below 3.2v :(
- GForce 25C 4000mAh 3S in Proboat Shockwave V3 BL
- Charging before a race?
- blackjack 29 batteries getting really hot
- Wet lipo battery?
- ? About batteries/balancing/storage
- What are mye battery options
- 58 Atomik batteries? Castle 2028
- Lipo cut off
- Best battery connectors...
- Quick Question about discharging Lipo
- Rx battery
- Hard case or soft
- charge day
- Deans adapter
- Can you run 2p using different C ratings?
- Grimracer Lipo battery swelling
- Storage voltage using store mode Hyperion 0615i
- NEW Batteries are here!
- battery question
- Some interesting observations
- "Hunger" Batteries?
- battery wiring
- Battery setup 1P or 2P same Mah Please share your opinion
- EOS 720i "C" settings
- Genesis cat twin 4s or 2s (Considering weight)
- Hor rocket
- Need some Help, Run time
- lipo softcase been under water, safe to use?
- charge 2250mh lipo, the computer charger only load 2200-2300mh?
- Parallel charging question
- My boat recomand 30c. Could i use 25? Rapicon lipo good choice?
- C question
- UGHH, did I by the wrong battery?
- Lipo Low voltage error
- Deans vs Traxxas connectors
- Cell Voltage Limits
- Hot to Hotter Batteries
- mah,C rating and current draw question
- Venmon 10000?
- Voltage drop under load
- Hyperion vs Hayin
- lipo vs. nano-tech
- 45c or 65c differences
- "New" Castle Creations 6.5mm Connector sets...
- Only Velcro for holding down your lipos??
- Battery's 2013 video
- 6s battery question.
- Question about what battery to use
- Battery storage temperature
- Advice please! (Genesis hull, 6S, T180 + 1600kv)
- Soldering, 8ga to 8mmthe bullet connector
- Lipo high C vs high volt
- battery question
- 2s1p os 2s2p?
- Dinogy red sport packs 30c
- Motion Unlimited / Magmum Energy
- lipos is it better to have a higer c rate
- 3S battery in Revolt 30
- 2 lipos in series vs parrallel....whats the c rating?
- Storing My Hyperion problem
- seeking advice- Thunder Power TP1527PS in parellel for TP820C- or other?
- Battery Question
- Battery type question
- charging lipos
- Battery configuration? Series's or Parallel?
- How to evaluate battery
- which dinogy packs for revolt and miss geico?
- Lippo battery mount
- Changes To IATA's Regulatons For Shipping Lithium Batteries On 1st Jan 2014
- New bullet connectors
- New guy with MG24 going brushless which battery?
- ESC Amps verses power of batteries and motor
- charging battery questions lipo
- PowerLab 8 + Li-Ion = Failure
- Which lipo ?
- Battery combo for 10s and 8s
- which lipo i need for this
- Lipo decision
- Generator Question
- nimh recommendation, lipos not allowed
- HELP! LiPo problems.
- DF mk45-38" hull powering
- Lipo Storage: Which way is the best?
- Battery VS Boat speed
- Lipo battery recommendation
- miss gico
- Hyperion vs Dinogy
- Wet lipos
- who has the best deal on 5s lipos
- Connecting batteries
- Series or Parallel?
- Efest IMR 18650 V2 2000mAh 3.7V Rechargeable LiMn High Drain
- Hobby King A-Spec G2 batteries
- Spc lipos.... Anyone use them?
- 14.8v lipo ?
- After 20+ Years, I'm back in... MRP Miss Budweiser, battery options/suggestions???
- pursuit battery placement
- Is this too much battery?
- turnigy 8000 5s
