View Full Version : Battery Talk
- What amps can I charge at safely?
- Question about lipos
- Difference in Hyperion packs
- How do you flare ends of 3/32" brass rod when building 5.5 bullet parallel connectors
- Question regarding a lepard 4082 1500KV running 4S
- Blade CX3 Heli battery low and wont charge,
- i have a cell that charged to 5.4 volts ????
- What is your favorite "Cheap" packs
- 2200mah lipo's any good?
- Thunder Power Question
- battery is hot. should i get rid of it>
- Dead on arivial Nano Tech... Help with warranty clame.
- wattage verses amperage
- battery mah and amps in paralell
- Hyperion Super Duo 3?
- Hooking 4s together with 2s for 6s plus the soldering male and female connectors
- Where can i buy a leopard lpb 4068/2d 4390kv motor?
- Why does a cell swell up?
- Need Battery/Charger Recommendations
- Great hobbies G-3 LIPO ?
- lipo sheild for sv27
- New to elc.
- B- grade lipos?
- Lipo battery charging problem.
- Cut off voltage chart?
- How much charge should it take?
- Turnigy Nano-Tech VS. Thunder Power?
- Turnigy nano 6600mah new
- Lower C rating on 2p??
- HK nano tech or not?
- Win Max Lipos Any Good?
- Any one try these batteries?
- new hobbyking batt checker, up to 8S
- any one make a connector that will go from two 2s packs to a 4s pack connector
- lipo question...
- duratrax onyx 235 question
- Which is better 2S1P or 2S2P?
- Flightpower 4s 14.8V 7400mah 25c with Seaking 180A Esc, Will it work?
- Can I charge at 4S?
- Still any need for high capacity dischargers/cyclers?
- New Batteries
- Are Hyperion Lipos the best?
- Turnigy 4s 40c 5000
- needs some packs but who has best quality control?
- Is it really worth buying from china?
- Rhino pack/ accucel 6 being an S.O.B.
- 5S or 6S on a 1700kv?
- battery balancing
- Parallel Battery connection advice
- How to mesure lipo.
- Need a quality set of lipos. What do you run?
- My First Set of Lipo's!
- think my zippy is dead
- Best bargain for marine lipos.
- Battery connections - Mystic
- Wiring up 5.5mm Connections....need suggestions.
- Series Wiring with 5.5 Bullets.
- matched sets
- Puffed 3 S
- Here's another dumb question
- Need some quick help regarding batteries. Trying to place an order now!!!
- Can you really tell a difference?
- batteries?
- RX Battery purpose
- Storage Charging LiPo
- LiPo dunking and low voltage Q's.
- A little LIPO question...
- New nano-techs huge 40c
- Gens Ace Hard Pack
- coincidence?
- Lipo storage and disposal
- Magic lipos?
- Looking for a lipo battery...
- Would these be any good in a boat application?
- Aluminum Battery Cooling Plates
- OSE Lipo's
- What does it mean to run batteries "in parallel"?
- Transmitter lipo!
- Battery, ESC, motor question
- Neuenergy lipos vs hyperion lipos
- 5s lipos
- First boat. lipo battery qustion
- Hyperion 4s batteries + 2s to= 6s Any problems with this?
- C rating vs. mAh
- Lipo Salvageable?
- Need help to understand Parallel Deans Plug
- parallel or series
- lipo charging rate question
- Just charged a Lipo and Have a Question
- haiyinstore.com
- Quick question....
- Convert from NIMH to Lipoly- very confused- need help
- What is better A bec or Rx pack?
- You think my Lipo "fix" is OK?
- How to???? 2S + 4S balancing tap to make 6S tap
- Is there a real good write up on lipo?
- Anyone ordered from Leaderhobby? How's the service?
- Long and skinny 6s pack?
- parallel connections?
- Battery discharge verses wattage
- Battery continuous amps
- Information on Haiyin Batteries
- New! MaxAmps.com LiPo Battery Tester and Low Voltage Alarm
- New brand of Lipos to choose from!
- 2x2s lipos versus 4s lipo
- bullet connector de soldered when i plugged it in. Alternatives?
- First lipo charge. I just wanted to check things out before its too late.
- 4s and 2s
- Poly Rc 4s cells 5000mah lazzy ?
- Micro Hydro Lipo's
- Winmax 50-100c Lipos vs Hyperion 45-90c . Battery testing Review.
- Balancing the Lipo's
- Dreaming of the perfect battery ?
- Anyone know anything about this Battery???
- Looking for a way to charge multi AAA and AA batts w/ my turnigy charger. HELP!!
- 1 6000 mah pack or 2 3000 mah packs ?
- Break in lipos
- Battery vs. motor kv question.
- Freezing a Moderately Puffed Lipo
- 12V L.E.D. Battery
- Gen Ace & Sky Lipo 12 Gauge Wire
- Balancing problems
- 2S for 6v receiver
- Replacing nimh with Lipo
- Lipo Capacity
- Batteries hooked up in series
- Gens Ace Lipo Concern
- any new lipo brands out there??
- Don't get rid of your old nimh packs!!
- LiFe charging ????
- Newb needs help
- Mtronics-Viper Marine 25..
- Amp draw
- Gens Ace
- DYI battery connectors
- Sky Lipos?
- Lipo Connection Sparking
- LVC buzzer problems HELP
- 6S 5000mA pack fit in Genesis/FCDaytona sponson?
- Newby lipo questions
- Which side of velcro is glued to hull???
- hk genesis battery
- Lipo Question
- LiPo discharger
- lipos
- Hyperion or Thunder Power, whats better
- Genesis Power Lipo's
- dan hutchinson (cobra tunnel boats)
- How do you prefer to make parallel conectors for 2 lipos.
- Minimum capacity on a 8s boat?
- New! MaxAmps.com Internal Plug low-resistance packs
- Gens Ace c rating
- waisted lipos
- Battery damage
- Haiyin Batteries
- parellel vs series question....
- Soooo confused
- Looking for a 10c+ charge rate battery ~1200-1600 mah
- lipo c rating and amp question
- EC3 connector vs 5.5 bullet
- ATTN> Hyperion 1210i owners, replacement LCD screens!
- Lipo Question. Let me pick your brain!
- Batteries are getting hot and puffing
- Anyone used zippy flightmax lipos?
- 3x3
- 9s
- Where To Buy Batteries?
- Color Options for MaxAmps.com Race Edition LiPos
- Hobby King batteries
- Mixed lipos
- Which LiPo battery connectors are considered standard?
- Question
- lipos with female 4mm bullets built-in
- What size & make bullet plugs are best.
- do i need to upgrade from 5.5mm for 12s??
- New battery tech
- Ekos on 9.6V 500mah hump pack not getting on plane
- Battery daily storage and spark question
- LIPO storage: 3.7 Volts?
- battery
- How warm should lipos be after a run
- How to charge dead lipos.....sorry if this has been talked about already
- So I melted my radio tray yesterday.....
- 5000 mah 45c 10s batt
- LVC: What do you recommend for 2S, 4S, etc?
- 54 AMP Charging......
- Lipo placement in pursuit.
- Eagle Tree E-logger V4 w/ GPS
- Where to get quality bullets?
- Battery/ Charger?
- lipo connector question
- What brand of lipo battery do you run
- Secret Weapon
- Two charger and battery questions
- Converting a Hard Case Lipo to a Soft Pack
- Connecting 5.5mm bullets
- Over-Volting LiPos and SAW Racing
- LiPo Sack Question
- Battery mounting question
- Organized racing and LiPo fire safety precautions.
- Storage voltage?
- Understanding Lipo Cells
- What is the correct lipo storage voltage?
- Research on charging procedures continue
- Lipo sack scam alert
- Lipos Puffy
- Charging Protocal
- Gens ace warranty? Do they have one.
- Buying new lipos, like some input
- Turnigy nano tech problem
- Battery and Charger recommendation
- What battery configuration are you all using?
- What is more Efficient 3s or 4s
- soldering 8 gauge zippy difficulty
- Wet Lipos
- NiMH Heat Problem
- Batteries for a new stock Pro Boat "Blackjack 29"
- new battery charging system
- new batteries for Genesis
- voltage cutoff
- New better battery's just FYI
- Lipo battery issues
- spark
- 5.5 bullet connectors
- Lipo connector/wiring???
- Battery capacity question
- Will these Lipo's work.
- Ideal battery weight typically in a 30" mono? Racers thoughts appreciated!!
- Which ones would you choose?
- Lipo question
- Battery Boss - RC's first reality show
- LIPO What's Happening?
- two different types of 2s lipos
- Fully charged Lipos...
- Higher mAh vs Lower mAh- More mAh = More running time?
- Best way to discharge lipos quickly
- lipo batteries 5s
- new to the hobby
- mystic with nano 45-90 / 65-130c
- Lipo batteries ran in series with deans connectors
- battery advise on my KOS
- Best lipos for the money for sport running
- Lipo Charging?
- Has anyone taken apart the hard case batteries
- attatching cf lipo trays to df 29
- New lipo battery wont take a charge
- Batteries with diferentt mAh and discharge rates in parallel?
- Some interesting info from Safeco underwriter
- Different voltages in parallel
- Quick question regarding Lipo
