View Full Version : Battery Talk
Pages : 1 [2] 3 4 5 6
  1. 6 cell VS 7 cell NIMH charging...
  2. Who has the best Lipo's
  3. run time
  4. Lipo's For Dummies....???
  5. just checking
  6. Turnigy lipo balance plug
  7. Turnigy Nano-Tech or Hyperion G3 EX
  8. Discharging lipo testing capacity ?
  9. Interesting info on parallel charging....
  10. Lets See If I Finally Get All This
  11. Dead Lipo's ?
  12. turnigy 5000 40c 2s packs in series charging?
  13. lipo nano-tech is the charger the same?
  14. volt meter?
  15. NEW Hyperion Super Duo
  16. Which RX battery pack to use?
  17. Deans and High Amp ?
  18. Fusion pro emperor .V. Bantam BC8DX
  19. HK Shipping
  20. New Venom 3S2P 6400mah ???
  21. Logview
  22. Y connector for parallel
  23. venom 5000 40c batteries
  24. What do you run your lvc at??
  25. mah formula?
  26. what's better for running 6s?
  27. Connectors
  28. Total Newbie Questions
  29. Thunder Power - are they high quality?
  30. quick safety question
  31. running 5s in series
  32. C rating
  33. lipo
  34. Gt duel charging leads
  35. Series vs Parallel for sport boating
  36. when does a LiPo take to puffing?
  37. Charging 4 batteries at once....
  38. Really cool battery setup from MAXAMPS
  39. parallell chargeing ??
  40. P-Spec Tunnel
  41. two battery questions
  42. Rewrapping batteries
  43. new 4000mah 4s 40c lipo why charger reads 3mah??
  44. Bullet connector covers
  45. Battery and Charger
  46. Battery options for Miss Geico
  47. Turnigy vs hyperion
  48. How do you us the c rating and the mah to calculate amp burst capability?
  49. No more Enerland LIPO cells
  50. anyone ever tryed this one ?
  51. Batteries dying after one cycle
  52. Balance Y adapters
  53. lifepo batteries
  54. battery voltage to high?
  55. Wired double run single?
  56. Actual Dimensions of Turnigy 5000 4S 40C Packs
  57. Lipo battery ?
  58. New batteries at hobbyking!
  59. hyperion
  60. 4s lipos in series
  61. hyperion
  62. nimh replacement cell
  63. How do you test nimh cell
  64. Battery series wiring ?
  65. International shipping of lipos???
  66. 5000 20c or 4000 40c???
  67. Interesting new battery choice
  68. Calculations Help Needed
  69. HK "B" Grade LiPo's
  70. Battery ?
  71. solder lipo cell cross over
  72. Turnigy 5000MA vs Duratrax 4600 vs Traxxas 4200MA
  73. disposing of lipos?
  74. connector questions
  75. Turnigy or Zippy's
  76. new with lipo batteries
  77. Turnigy jst balance lead problem
  78. New to electric Battery Help
  79. whats a good amp meter and will this work?
  80. Lipo disposal...
  81. Whats the max race cell count on a feigao 6XL?
  82. Possibler Lithium fire on UPS plan in news
  83. Sparking
  84. 1520 cc motor spartanboat 180 esc battery choice
  85. zippy
  86. Obsession with 6s
  87. Gens Ace Lipos
  88. HobbyKing Nano-Tech LiPos
  89. Generator Suggestons
  90. turnigy nano tech's
  91. Miss Geico mods. Should I use rx pack?
  92. how to charge two lipos at once
  93. Strange charger/battery problem.
  94. Venom Batteries
  95. 4S does this make sense ?
  96. Near Disaster - Chinese battery
  97. Near Disaster - Turnigy Batteries
  98. Hardcase or soft
  99. Lipo ?
  100. Rookie Battery Question
  101. LiPo shorting out???
  102. How many cells can I run with my Leopard?
  103. banana style lipos?
  104. 15s Anyone??
  105. Charge/discharge NiMh
  106. New Batt Technology?
  107. newbie battery question
  108. Help!
  109. A guy named Tom ordered some batteries?
  110. Hobbypartz vs. Hobbyking lipos
  111. Parallel vs. Series
  112. thunder power lipos ?
  113. LiPo Discharge
  114. Looking to buy new 4s lipos?
  115. What mah capacity 4s lipo req for Matrix ?
  116. Highest amps under 100 bucks
  117. GrimRacer Speed Packs
  118. nimh batterys
  119. Lack of battery power?
  120. Thunder Power the hottest now?
  121. Diesel Battery Testing:
  122. Good 4s 1p Lipo
  123. Nice link on Lipo usage A-Z
  124. Max Amps vs. hyperion vs. grim racer
  125. Low Cell - Saved???
  126. Battery Help
  127. Connectors on Turnigy Lipos
  128. GensAce Lipos got wet. Can I open and reseal them?
  129. Balance issues
  130. Battery lipo question
  131. Cycling new batteries
  132. Need help on 12s setup
  133. 4s lipo questions
  134. Genesis 5S batteries
  135. Nano tech lipo's, different batches different sizes
  136. Best Charger Today-Anything Changed?
  137. Turnigy 5000 3s...
  138. 6600 TP 65c's..??
  139. LiFePo?
  140. How to charge two 2S batteries simultanously with Accucel-8?
  141. Miss geico stock 5s setup
  142. Battery test very interesting
  143. Lipo Question
  144. Diesel....I need your help???? Connector questions....
  145. 5S
  146. discharge amps calculation
  147. Anti Spark brigde
  148. Bad 4S Packs ???
  149. Discharge rate and capacity
  150. new lipos break in?
  151. <$10 card to check lipo voltage: Total, each cell and & total number of cells
  152. Fixing Lipo battery...???
  153. Looking for opinions on FMA/Revlectrics LIPO's, I just got in a set
  154. sky lipos?
  155. Turnigy 2 cell 5000mah Battery will not charge
  156. Hot batterys
  157. PolyRc/Enerland ?s
  158. Hardcase vs normal lipo
  159. Lipo Repairman
  160. Venom P1 Battery Selection
  161. Batteries melting Hook & Loop adhesive
  162. 1300mah on .08A
  163. 32" pursuit battery setup
  164. Will gen,s 4s 30c 5300mah lipos fit in a 37" Daytona
  165. Aquacraft UL1 Batteries
  166. Run times
  167. MY Connection keep melting (ec5 and 6mm CC bullets) HELP!!!!!
  168. anyone recognize these connectors
  169. NIMH question
  170. connector questions
  171. help with lipos
  172. Just two different LiPos in subsequential order
  173. "Deep Cycle" or "Starting" battery for lakeside charging; which is better ?
  174. Lipo help needed
  175. discharge rating need determination
  176. What the?? 7.4volt 250mAh 2s lipo's went bang on first plug in
  177. Mixing Lipo Batteries to make 5s, Will these work together?
  178. Need lipo mounting help
  179. What is better 1P or 2P
  180. Which Li-Po battery can i use
  181. Charging 8s and 10s pack questions
  182. turnigy
  183. battery to esc connector heat??
  184. lipo puffed or not really?
  185. Overheat
  186. xpower 100amp esc help
  187. 4s 5000mah in parallel...to give 10000mah..is it possible in a supervee?
  188. Nano-Tech "glitch" during charging
  189. New to brushless
  190. data logger
  191. Need some help
  192. No spark resistor
  193. Check out this Turnigy Nano Tech lipo test
  194. How much battery would I need...
  195. 4s vs 6s
  196. lipo cutoff mod
  197. What r LIFE PO4 packs!
  198. THE BEST RC LIPO/WIRING INFO I'VE FOUND: Tjinguytech.com
  199. anyone tryed this one ?
  200. rate lipos
  201. need some good advice for setting up my ul1
  202. Ebay 6.5 bullets?
  203. Castle Link Quick Connect
  204. just got the ul-1
  205. castle hydra 240 ,lv cut off
  206. Turnigy nano tech's any good?
  207. Proper stages of a LiPo battery charge
  208. Need help
  209. new lithium Jelly battery
  210. Gens Ace Lipo
  211. has anybody ever heard about these lipos
  212. lipo discharge
  213. 4mm Bananas or 5.5mm Bullet Connectors. Which is better?
  214. Lipos : which vendor ?
  215. Wiring 12AWG to 8AWG is this OK?
  216. Maxamp batteries... are they worth the extra cost?
  217. lipo C rating ?
  218. Who's looking for water cooled Lipo packs?
  219. Hard case or shrink wraped
  220. Hobbypartz Research and Development? Let's just say sub par.
  221. 6s split to 3s what do you do with balance plug ?
  222. Testing some budget lipos
  223. Voltage verses discharge
  224. Important lipo info govt regulations
  225. Thunder power lacking power.
  226. need help choosing lipo battery
  227. Series or Paralell?
  228. How to charge 2 2s battereis as a 4s
  229. 2S packs not discharging equally
  230. Choosing a Deep cycle battery field charging
  231. Hot batteries
  232. What charger can I use?
  233. need advice on charger
  234. Lipo Balancing or just charging?
  235. Look at what I found on hobbyking
  236. 8s 3800mah on SALE!!!!
  237. Motor size/lipo config for this shovelnose
  238. Now what packs do I need?
  239. Help ! Shipping lipos from Canada to USA.
  240. Battery Pack Volts
  241. Turnigy NANO"S now available from USA warehouse.
  242. Fantastic Site Explaining All Things About Batteries, Chargers, Wiring and More !
  243. Just an Idea
  244. Best LiPo single cells
  245. Charge up to 6 LiPo's per charge port
  246. Battery charging error tp610
  247. Build Your Own Receiver Packs Video
  248. Is it bad to charge at less than 1C?
  249. Lowest safe storage temperature
  250. LIpo bag
