View Full Version : Venom King of Shaves C1 34in Brushless Q & A
  1. King Of Shaves C1 Brushless!
  2. king of shaves
  3. Move over and make room for the new bad boy of rtr's
  4. Setups
  5. Props
  6. Project "Nuke the Motor" is about to hit the water..
  7. What is like to ride inside the KOS?
  8. timing for the venom motor.
  9. Cooling
  10. NiMh
  11. Replacemt motors for the E.K.O.S.???
  12. Twin Outrunners?
  13. Gas or electric KOS?
  14. ESC Troubleshooting
  15. ESC Troubleshooting
  16. KOS temporarily out of production
  17. Anybody up and running with the new lot?
  18. Flex Shaft Saver
  19. Venom pro charger
  20. Planetary gears
  21. Fiegao 380 XL motors
  22. Feigao motor install pics
  23. best battery size to get the most out of ekos
  24. New water pickups on the EKOS
  25. EKOS Motor Mounts
  26. EKOS Basics?
  27. EKOS C1 Dual Motor Upgrade!
  28. EKOS C1 Servo Mount Fail
  29. New EKOS C1 Pre-Use Checklist
  30. Turnigy ESC
  31. Parts list for an EKOS hull only project?
  32. Newbie here, can someone explain kv
  33. ESC setting Question
  34. King of Shaves paint fail...
  35. VENOM EKOS 4S 5000mah LIKE BUTTER
  36. Venom 2700kv and 2000kv Marine Brushless Outrunner Motors
  37. New Rudder and Water Pick-ups for EKOS...
  38. Longest running and smallest 3S Lipos for EKOS?
  39. Burned out stock motor and ESC last night!!
  40. Anyone have stock EKOS engines they want to donate?
  41. Turnigy 120A ESC????
  42. New to the brushless scene
  43. Ekis on 10xl duing 51mph
  44. motor removal
  45. New Prototype Design for EKOS Water Cooling
  46. Stuck in nimh
  47. EKOS C-1 wire drive install
  48. Stock King of Slaves, I mean Shaves.
  49. 60+ mph What's your set up :)
  50. Props
  51. Piano Wire Shafts
  52. www.bocabearings.com
  53. More Junk?
  54. Looking to buy EKOS
  55. Have a question about the props
  56. Running the EKOS in series
  57. Re-programming ESCs for 4Ss ?
  58. Which Motors For the EKOS?
  59. Another performance related question
  60. Two motors vs one
  61. Motors
  62. Ekos hull
  63. Metal props
  64. Motors
  65. Another burnt out motor!
  66. Finally got her back on the water!!
  67. EKOS Rudder- What to do?
  68. SeaKing 120 esc
  69. Wanted Venom EKOS ESC
  70. Another EKOS motor smoked on 4S
  71. Batteries
  72. Ready t oupgrade
  73. Motors for the EKOS for sale
  74. Leopard motors in the King?
  75. bearings vs bushings
  76. Hobbycity EKOS?
  77. Venom Outrunners
  78. EKOS clone and upgrade questions.
  79. wire drive upgrade questions
  80. 380-10xl timing
  81. Left & right rotation questions
  82. Outrunners in the EKOS?
  83. Programing of stock ESCs
  84. EKOS Video
  85. Dual drives & individual throttle option
  86. EKOS Sponson Repair Job
  87. The REAL EKOS Crashes
  88. EKOS Outrunner kit in the swap shop
  89. Looking to buy 32-34 inch cat hull
  90. EKOS vs. UL-1 Videos
  91. Battery dimensions?
  92. Still looking for EKOS replacement hull...
  93. castle 2200kv motors in ekos
  94. Venom 36mm props for sale
  95. 6S on Turnigy / Seaking 180A ESC?
  96. C1 props
  97. Scorpion HK's in EKOS
  98. Wiredrive install question
  99. Steering servo mount failure
  100. Ekos as a race boat
  101. kos will not plane
  102. MOTOR,ESC,PROP RECs FOR EKOS SINGLE MOTOR
  103. Rudder upgrade
  104. Break away rudder
  105. New EKOS owner here
  106. prop suggestions
  107. ekos in plano tx
  108. ekos single drive maiden
  109. ekos single drive maiden
  110. Leoard motors ?
  111. Just Bought The Ekos Need Some Advice
  112. Ekos or dragon saga?
  113. Fiegao motor shaft replacement??
  114. EKOS Flodded
  115. blew the ass end out
  116. Batteries For C1 EKOS
  117. Ekos quick questions
  118. Who has the fastest EKOS???
  119. EKOS props upgrade question
  120. Venom EKOS Picture Gallery
  121. EKOS with outrunners TINY?
  122. EKOS replacing the outrunners????
  123. New EKOS, i would like some help pls ;-)
  124. 50mph on 2 3 cells possible
  125. Outrunners?
  126. Leopard motors???
  127. Flex cable rotation terminology question
  128. 3s + 442
  129. MY EKOS Build
  130. custom genesis using my ekos esc and lippos
  131. Inrunner motor mount upgrade?
  132. EKOS warranty serial # ?
  133. EKOS - First run experience and question
  134. Need motor and mount upgrade for ekos??
  135. My Segad is on the Way!
  136. My new EKOS and GoPro HD cam
  137. what is the difference between the 1st batch and current version?
  138. programming the king of shaves for 6s
  139. Esc problem
  140. KOS burning up servo's
  141. 40 mm props
  142. Intermittant loss of top-end speed
  143. new kos owner here. how many of us are there?
  144. Miss Geico vs. King of shaves
  145. Bought a used EKOS off RCGroup
  146. Newbies - Venom has King of Shaves
  147. Venom EKOS RTR's on ebay for $319
  148. EKOS HULL $49 on EBAY
  149. First build need suggestions
  150. KOS upgrades
  151. Removing battery tray question
  152. Seagad handle 4s stock?
  153. Posting an ekos hull to the UK?
  154. Which KV ekos upgrade?
  155. What hardware for single drive?
  156. CC1512 in a kos???
  157. Help Please Flex shaft replacement.
  158. New KOS C1 w/ 50C 11.1V 5000mAh 3S LiPo
  159. King of shaves
  160. Some help with a propeller nut.
  161. i must be dumb ?
  162. New kos c1 on order!!!
  163. Ekos with single FC 3730 outrunner build
  164. Motor q
  165. Running temps
  166. Ekos motors
  167. Segad drive line options
  168. Best prop for racing,,, stock motor/esc's
  169. New venom (Atomic) v380 2200kv and 4s configs?
  170. diagram available with good detail on how the dual prop setup should look?
  171. How to make this thing decent when purchasing...
  172. EKOS Outrunner Connectors
  173. What hull to go for?
  174. Battery position for cg
  175. EKOS 34" rudder...now what?
  176. Is it a good upgrade idea ? (props)
  177. Esc problem
  178. EKOS w/Leopard 4074 2200 kv Seaking 180 ESC & 4s Batts
  179. EKOS C1 Hull drilling/building questions
  180. EKOS C1 build question
  181. kos 34" / atomik 34" same hull?
  182. piano wire shaft
  183. Looking for the v380 2700kv from Segad or EKOS
  184. New 34 inch KOS Value please
  185. Venom EKOS - I want specific motor, esc, prop, collets, etc for upgrade
  186. Flex shafts and bearings for stingers
  187. Stock Flex Shafts
