- How long will lipos last running the boat full out
- Faster than UL-1?
- turn fin tuning
- UL1 test with Hydra 240/ 1515 1y
- Just thought I would share...
- can i use 2 different batteries
- can i use these batteries?
- help with motor won't work
- Any one seen this boat
- UL-1 Video
- ESC help
- suggestions needed
- Enlarging the Water Pickup Hole on the Rudder...
- Waterproofing tip.
- UL-1 & lipo size ?.
- 3s on stock motor and ESC
- UL 1 Battery
- New UL-1 owner with a issue.
- UL-1 ESC Problems
- UL-1... Could not be happier
- what charger
- Can this be done?
- ul-1 took a crazy hop today and cut out. anyone else have this?
- Inside a Tactic Receiver & How to fix one that gets wet
- where can i get the set screws for my ul-1 rudder? anyone know the thread size?
- UL-1 available at LHS
- Adding Extra Capps
- Snapped flex shaft after 5 runs
- Charger setup
- UL-1 Motors?
- Confused: Running the Ul-1 below max speed
- Newbie needs advice
- Motor / ESC / 30c ?
- First Run Today On My UL1 ????
- Run dual batterys to make 5s?
- Turnigy 180 ESC Problems
- UL-1 back in stock soon?
- water lines
- Has anyone tried the 38X63 2 Blade ??
- UL-1 Runnin Hot
- keeps on shutting shutting off and on
- BIG UL-1 Battery Question
- First run and question
- UL-1 ESC improvements?
- How to make this setup happen?
- UL-1 Strut specs
- running 3s only
- 65 mph stock ul1
- Quick Question?
- Lipo Selection?
- UL-1 runnaway on first run!!! destroyed!!!
- replacement hull
- Turnigy nanotech for UL-1?
- In Stock???
- how the hell do i get the ul-1 motor cooling jacket back on?
- I got a good speed but need some more
- what kind of caps to add to older ul-1 speed control?
- prop
- Hull separating?
- strut angle
- UL-1 with seaking 120amp esc
- ok people, this is how you get cooling tube back thru the hull
- ul-1 ?
- anyone try any different motor mounts in their ul-1 successfully?
- Smoking motor?
- ul-1 prob- help?
- ul-1 motor -ESC
- mix matching batteries
- ESC question
- UL-1 paint and hull repair ????'s
- UL-1 air dam ???????
- what lipo and other mod's for my ul-1 should i buy
- UL-1Strut bushing question
- just the hull
- UL-1 set up
- Turnigynano-tech 4S in UL-1
- UL1 Boat Stand
- UL-1 cutting out
- stickers
- sealing system and without schotch...
- UL-1 Stress Cracks on the inside...fix with??
- feigao 8xl...
- Lipos UL-1 and prop
- More UL 1 questions
- UL-1 Vs Stiletto?
- Ul-1 upgrade ?
- Need some setup help
- bad fri night
- Max Amps Lipos
- ul1 esc
- First run on the UL-1
- Brand new to UL1 - Steering and twisting problem
- scale look miss superior ul 1
- Wot prop? messing about not racing
- new to ul1
- how do i fill two small drilled holes on ul1 superior transom?
- will these kintec jackets fit my stock ul1 motor?
- Scrubbing the bottom of UL1 hull?
- what is binding.
- can someone help a brother out por favor?
- Another UL 1 Runaway!!!!
- what would be some obvious signs of flex shaft problems?
- How many times
- can someone tell me why hasnt kintec responded to my emails?
- Alignment ?
- the ul1 superior. is there a real thing?
- UL1 CG? where is it?
- Closing in on 50 mph
- Ul-1
- ul 1 superior radio questions
- UL-1 nose diving on take off
- filing cracks ? hot lipo's
- Setting throttle trim ?
- newb ul1 questions
- Ul-1 on 5s
- air cooled ESC
- someone enlighten me please.
- FE boats and airplanes....
- new ul1....... wow!
- dual turn fins
- help
- New skin on my UL-1
- Ul1?
- can the seaking 180a handle 6s?
- Boat hauler bag?
- sv 27 and ul1 rudder. are they the same?
- low voltage cut off
- Unstable on slightly choppy water...
- Sharpen Rudder?
- Non-RTR V-hull?s
- true or false?
- Prevent Batteries from Puffing?
- Stock setup on 40C...anyone using this?
- UL-1 air dam
- new bare hull
- UL-1 esc ?
- PLEASE HELP ME get in the water
- First UL1 to the beginning fleet
- waterflow testing
- Servo linkage help
- Ul1 motor problem
- Turnigy lipo assist
- spektrum?
- installing cooling jacket in ul-1
- ul 1 /60amp in sv27
- 6 pole timing selection
- Ul1 question
- UL1 All around play toy.
- Motor Issue?
- UL-1 cutting off issues?
- ul-1 prop problem
- wire glue?
- 2200kv drop in?
- another air dam question
- waterproofing receiver?
- Stock Strut Position
- Esc question
- ul-1 lipos
- Problem
- Little help for a begineer from Argentina
- UL-1 Straight Turn Fin Made from .090 thick 7075 High strength aluminum.
- Stripped rudder mount holes
- Won't get up to speed!
- soldering and charging question
- I just don;t get it / Whats up
- wanting to replace ESC
- Octura X637 in a Aquacraft UL-1
- Wet Motor
- ski on ul1?
- ESC Question
- First run... success... very pleased with the boat.
- UL-1 ESC and FlySky GT3B... anyone tried it... im having issues.
- Are GPS:S that accurate
- ul 1 rudder adjustment
- UL1 Videos
- temp on motor/esc
- UL-1 Superior Driveshaft liner substitute ??
- UL1-Superior driveshaft liner
- my take on down force
- Making my ul-1 faster….
- Cant see water coming out the tube ???
- UL-1 Need Help
- Air dam
- 2-3S 11.1 5000c lipos can you use them in a UL-1 Stock set up
- My latest UL-1 Mod's. Its never enough!
- nitro ul-1
- Aquacraft UL-1
- Feigao motors
- Bench test
- Overheating!!!
- My UL-1 mods
- kintec 3 piece collet ?
- Proboat 1500kv in UL-1
- Need help
- Need input on a wierd esc issue - Thanks
- my ul-1 keeps on submarineing
- Has anyone used a aftermarket radio system in the ul1
- Any advice on a reliable radio system ???
- Favorite UL-1 motor cooling jacket
- Flex Cable
- Aquacraft UL-1 Lipo question
- 62mph but!!!!
- ul-1 w/black jack 1500kv motor
- New UL1 will not get on a plane!!!
- Hit 51.6 today!!!
- Aquacraft ul-1 brushless rtr
- Castle 1512 1800kv 1.5Y motor in a ul-1
- lipos?
- ul1 new or old version
- UL1 question 1st or 2nd generation?
- prep before i launch
- Whats this, and want to convert to electric
- Just ordered my first FE.
- Tired of losing fins on my UL-1
- upgraded prop
- HELP my UL-1 please!!!
- Timing for UL-1
- Strut depth
- ul1 is rippin it!!! whats next?
- ul1 will not settle down now...
- Any good lakes in miami for fe boats
- Uploading a video
- UL-1 Connectors and solder problems
- UL-1 motor timing question
- Kintec upgraded flex cable
- lipos that fit ????
- UL-1 prop question
- UL-1 super cooling jacket
- UL-1 Prather B230 prop?
- Up in SMOKE
- UL-1, Steering
- Outrunner in a UL-1?
- turn-fin sponson beef up
- Lost strut,prop and flex shaft :(
- UL-1 Speed Control
- ul-1 sponson foam
- Replacement esc for UL-1
- Swordfish esc 120a Timing help
- Is there a plan for a faster bigger RTR style like AquaCraft UL-1 Superior FE Hydro ?
- Cooling pick-up
- Turn Fin
- Painting Help
- Leo 3674 2200kv timing ?
- not planing
- UL-1 Batteries
- UL1 Motor Question
- UL-1 'Muffler Pipe' Hollow?
- Building a boat for the first time, couple questions
- ESC wiring
- Version 1 boat, best prop for stock electrics
