- Ose Products Site Will Be Down 4/9/2008
- Buyer/ Seller Rating System
- Hydra 120 programming info
- Propeller Torque
- Congrates to Mr. Bill S
- Any Comments
- Transom Doubler ?'s
- X-Power 100A Esc Trouble
- New boat at Minicat Racing
- Longer rudder needed...
- Solder Iron Temp Setting?
- 9XL in a SV
- newbie build.....
- Lipo setups
- I need prop help fast!!!!!!!!!!
- Medusa motors
- X power 70 lasted 1 minute!!!!
- Fecalc and an SV27 motor?
- Skeg Vs NonSkeg struts.
- Overheating ESC
- Can LiPos Be Damaged in ESC failure?
- Pete's boat retrieval
- R/C Graphics
- If someone wanted to make a bunch of rescue boats and sell them..
- What is the difference?
- Hex Esc
- I need Boat Racing Help!
- FE Calculator help please!
- kyosho mini-z gutted and rebuilt
- Store shut down times for vacation.
- 100 amp esc? reviews/info?
- Does this behavior sound right for my ESC?
- Has exploited my boat
- Bullet Connectors
- Need some prop advise please.
- Ammo 2300 connectors
- This is a break in the "Ozone" that Gore can't complain about.....
- motor shaft
- Hydra warranty change
- fun on the water
- Testing tomorrow
- Quick Q about sealing?
- Accidently walked into Aeromarine
- Got a new lipo need some help...
- Real boats today at Lake Washington
- Victory Is Mine!!!!
- Old Boat with a kewl new look
- 2 props 1 shaft?
- 2008 NAMBA FE Nationals - Get Signed UP!!
- New look for a Silver bullet
- polyquest, rc lipos
- 18650?'s
- what prop moves more water
- Water problems help please!
- Voldasta SAW Update
- Bad Day At The Pond
- polyquest 6000 mah
- x power esc gone?
- Cooling Jacket Help- won't go on
- Wire drive help please
- Attaching Videos?
- Turn Fin placement for Hydro Vortex? - help please
- AM controller v. FM controller
- diffrences in sensored and sensorless BL motors?
- charging question
- List of r/c hobby stores
- Anyone ever cracked a drive dog?
- Prop where to start.
- An Even Worse Day At The Pond
- Way To Go Doug S
- does anyone know how to get a johnson motor going?
- duel motors
- What a good HV boat?
- Supervee 7L , 220 prop, which batteries????
- Suggestions for Mono Build
- nebie brushless question
- Can Someone Identify These?
- Brushless power for Kyosho Bluestreak
- Have You Seen This?????????????
- Get well SJFE
- Quick newbie question about Stinger Sleeve Bearings
- H&M no step 3. What setup?
- alittle more speed
- What props to use
- toysport jollycatamaran with hardware
- Speed Junkies
- vater and lipo batteries
- newbee? Problem with Hydra 120
- Poblem with hydra 120
- Flex shaft fit in the strut.
- Lipo question for SV ESC, coupe other questions too
- Pro Boat Hydro Set Up
- Insulating the gold bullet connectors?
- 1000 Members
- Cat Boat Phantom
- Amp draw from neu motors?
- How do you fasten your hardware?
- Villain EX Help...anyone???
- Check This Out
- I want to run 6s
- To Upgrade or Not?
- What is this thing?
- high throttle cut-out
- anyone know whats wrong?
- where to get plettenberg brushes??
- Anyone have experience with these?
- micro hardware measurments
- Silicone water jackets for a Neu motor
- ARTR $178 Delta Force Knock Off?
- Setups page
- Center of Gravity for a 1/8th Hydro
- water cooling.
- Prop size on a 8XL and Hydra 240 ESC?
- Don't Order From Twisted Liquid
- New Traxxas Blast
- anybody delt with these?
- TX-- Carrolton Classic FE Race results!
- OSE Service
- Check It out....
- Check It out....
- Delta Force Hulls
- prop box and lipo carrier
- who make this?
- The Ultimate Drag Boat
- newbie question
- need help!!
- SOCAL Boat Races
- Setting up a HV Hydra
- check these out!
- 1/4 to 3/16th
- Lipo cutoff voltage
- Re deans ultra good enough for an SV27 setup?
- More speed
- DF 33 submarine impersonation
- New Jolly Layout
- Pro Tek lipos
- DF Sniper 45...Let's Talk!
- ACCELLERATOR Catamaran
- User Named "Jessie"
- Hydra 120 Bad Solder Joint!!!!
- Testing with Eagle Tree data logger
- wtf.
- Run Times
- Feigao and Hacker screw mounting size
- boat finish
- New Hobby Site
- LiPo Batteries Explained...
- Another NOT so great day at the lake
- need help on lipos..
- pro boat set up help
- Video of my SV 27
- A noob needs some help
- Spiders can fly.
- NAMBA VOTE - Official Results!!
- Non-electric hydro !!!!!!
- Shrink wrap
- Decals
- More Mystery Controllers
- lipo wiring question
- Which Order Motor Shaft Bearing Coupler Dog Prop Nut
- 30" Hull Setup configuration....
- New smilleys
- how to choose a motor
- NIMH Batteries. HELP!
- New camera Bent rudder
- Is anyone set up to do Metal etching?
- MRP Miss Budweiser Setup
- hydra 240 help with 6 lipo
- Hydroplane Race This Weekend
- rigger plans??
- some new stuff i just thought i show off :)
- does sanding the bottom of a hull help
- Does this stuffing tube angle look good?
- Homemade Graphics Options
- proboat 180 hydra elam suggestions
- Say Hello to JetSpeed-2 !!
- Hydra 240
- Rigger design question
- Redneck Vac-U-Pickle
- ESC - AMPS vs Volts
- Charging NIMH packs for 1st time?
- Reviving Dead Cells?
- FAST Shipping !!!
- 800 BBX Outboard...questions
- Miss Britan
- Ose stickers
- Flex coupler (2.5mm & 2.3mm)
- Optimal Cycling Rates for New NiMh's...
- Open Letter To SJFE
- 1/12 Llumar First Vid
- pro boat esc ?
- graupner motor confusion
- need some help
- Matched and Zapped Cells
- C ratings
- Sv 27 motor & CC 80 SC ??
- moment of silence
- Another fatal boat rescue attempt...
- titan 40 fun boat
- !!!!!!!!cottenwood Alert!!!!!!!!!!!!
- Lipo Help!
- Legg Lake Photos
- Drive system hardware...
- conversion
- pro boat esc?
- X-power question???
- Flex wire lubrication in teflon tube?
- Help with 120amp Hydra
- A Few Random Thoughs
- Mean Machine overkill!
- Need input on cat build (First timer)
- Upgrading to brushless
- the price of freedom
- Ammo motor choice
- micro drifter
- New Gasser
- What "C: rating for 2s 7.4 Lipos
- Twin brushed motors- what esc?
- sport hydro help set up
- Prop Recommendations : ????
- Dulling my boats bottoms up help needed
- Data Logger info.
- Testing today at lake Washington
- supervee 27 brushless
- Modified Mini-V Video
- ELF Hobby 100A ESC
- Current spike from elogger, is it accurate?
- micro drifter motor and esc ?
- DF 6s
- Avenger Pro FE,,,, Video..
- Novak lipo cut off
- Eagle Tree GPS expander
- Outrigger motor temps
- play time norther indiana
- 8s lipo MM vid
- Heading hold Gyro for a boat
- $ for 2250 lehner
- Photos from May 18th and June 1st
- Gps
- CG for Blizzard rigger?
- Motor Overheating or Over-Propping
- # of SAWs
- Big Thanks to Steve at OSE
- One tough cookie or what!!!
- Fun run @ Hygenics
- Wit or witout liner
- Lipos got wet.
- rum runner racing
