View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64
  1. F1 Style Tunnel Hull for a beginner...
  2. m34 raider trim tabs
  3. Graphene vs lipo
  4. Help on a home built tunnel
  5. Aquacraft UL-1
  6. experience with DYmotorshop 38" Zonda? Question re: motor selection?
  7. Veles 29 what?s the best upgrade motor/ESC?
  8. Batteries for Zonda CHNL 5200,6200 or 9500MAH?
  9. Swordfish 300a HV esc
  10. Re building 1/8 scale crackerbox !
  11. speed
  12. TFL Cheetah twin or single for oval racing? Advice sort?
  13. New Boat Genesis 56"
  14. Buoys
  15. Rcboatbiz.com
  16. Any York/Lancaster PA Guys in here??
  17. 100mph DF Explorer twin / 76mph MG 17
  18. sss 3656 motor question
  19. Hydro motor placement - need some insight
  20. how to lubricate outboard
  21. How to setup a proper speed trap on water?
  22. who's doing vacuum bagging
  23. Paint Jobs
  24. Is there a solid reason I shouldn't click "go" on this: TFL 900mm ARTR Genesis
  25. Need Help - Motor Placement 36" Hydroplane
  26. Salt water or not?
  27. Hooking up twins
  28. So I found one at my local hobby shop...
  29. Which TP motor should i buy !
  30. 50" TITUS Mono setup
  31. Mike's Pistix adapter Questions.
  32. reading a data Logging
  33. How soon?
  34. dealing with TP Motors
  35. Dragon Sailing out of business? Warranty issue
  36. Baby Bootlegger Surge or cavitation question
  37. Nexgen P-Limited Hydro
  38. Old Jae 21FE Tub lenght.
  39. RPM unload for a 1 meter cat.
  40. Cooling pump
  41. Advice on electronics
  42. Single motor cat strut/drive
  43. Is my rudder too small ? Rudder size for home built 24" wildthing mono hull
  44. P-spec mono !
  45. Lipo mounting !
  46. I really f'd up today! Totally cracked my rear stern
  47. Winston Eagle/Cellular One 1/8 scale ,How to apply West Ststems G-Force epoxy
  48. Prather 31" Deep Vee motor recommendations
  49. Delta Force DF45 Mark 2 roll.
  50. El yapımı rigger ağırlık ve setup yardım!!
  51. big problem with cavitation
  52. sonic wake motor upgrade
  53. What size esc do i require ?
  54. Water cooling for TPPower 4060 motors ?
  55. What do you think would happen if.........
  56. JAE .21 FE version #1 ?
  57. Struts &rudders for 4s & 6s monos ?
  58. motors recommended for single motor tfl mini zonda
  59. HPR C5008 build. "Valkyrie"
  60. Outboard Leg Machining
  61. 1/7th Scale vintage rules
  62. M41 shut down issues
  63. Lipo Brand for Sonic Wake
  64. Xmas giveaway??
  65. Zonda SSS 3674 2075 KV or TP3650 1700kv
  66. Aquacraft props ?
  67. 3M Dual Lock for lipos
  68. Proboat UL-19
  69. Vinyl Cutter Recommendations
  70. Rudder Break off bolt.. Copper or Nylon?
  71. Motor sizing
  72. 175 amps flycolor esc
  73. Paint carbon fiber Hull
  74. Hydropro Inception problem
  75. Radio antenna placement?
  76. Sonic Wake Strut Mod Replacement from Boat Biz
  77. Large size rudder for a deep vee mono
  78. Anyone want to help save an old gas Proboat 1/8th Miss Bud hydro? Oh, come on!
  79. Porposing
  80. Getting started
  81. 5 inch T Bar and Oiler Can
  82. New Guy, somewhat
  83. USPS shipping lousy service
  84. cheetah cat p-cat single setup
  85. Searching for DF Vortex 34 lid
  86. Ose 150 esc
  87. Mamba MonsterX8s
  88. radio box lid
  89. How to set up proboat sonicwake 36
  90. Leopard motor help
  91. Anybody have a RCBM Library?
  92. NexGen EP1 P-Hydro and P-Ltd Hydro
  93. P limited sport hydro flex cable size
  94. Rudder length question
  95. Old guy with an old Boat
  96. cheetah cat p-cat single complete !!!!
  97. cheetah cat p-cat single complete !!!!
  98. shovel nose hydroplane hull design question/thoughts?
  99. soldering
  100. Glueing Fiberglass battery trays ?
  101. Primer?
  102. Looking for Darin Jordan contact info.
  103. Which G-flex epoxy ?
  104. Wood mono hull deck ?
  105. Wood mono hull bottom ?
  106. Pro Boat UL-19 Porpoising
  107. To Bush or not
  108. Max capacity rule for racing?
  109. FOUNTAIN Bare hull
  110. 55inch fireboat mono deep V plywood hull
  111. Cobia sports pulling a mono-skier, scratch built outboard
  112. Info on wire drives!
  113. Motor size
  114. 55inch fireboat mono deep V plywood hull
  115. Use of a thrust bearing on prop shaft question - Why?
  116. P Class battery
  117. 55inch fireboat mono deep V plywood hull
  118. Sonicwake 36
  119. Tesla using nickel batteries
  120. RTR with 3mm shaft?
  121. Mounting futaba 2.4 GHZ R21O4GF antenna ?
  122. Maintaining and tinning the soldering tip ?
  123. Phil Thomas hydro ideas!
  124. Blackjack 42 trim tabs
  125. Twin CAT prop rotation
  126. Zeee Premium LiPo packs
  127. Pro Boat UL-19 4s Parallel
  128. a little help please.
  129. Namba Mah question
  130. Dumas miss circus circus conversion
  131. Help SR 80 pro 4s lipo battery
  132. planning new build
  133. Inflatable Kayak Recovery Boat
  134. TENSHOCK 64100 & 64130 Motor
  135. leopard 4082 1600kv 4s
  136. Sonicwake 36 holes in hull
  137. Gyro controlled canard on 1/8 scale hydros
  138. What TP engine is this ?
  139. Balance charger help
  140. Blackjack 42 Tuning
  141. Traxxas blast upgrade
  142. How could this happen?
  143. TP Motor choice
  144. XLX2 Question
  145. More weight or more canard angle
  146. Help! Vector Sr80 Throttle in reverse mode
  147. Areomarine 36 avenger single or twin?
  148. new style tabs?
  149. OSE has a opening for a full time employee
  150. Twin Tp 4070 KV, Esc And Prop Help
  151. Blackjack 42 glue not holding boat together
  152. Carbon Pursuit P mono issues
  153. Cap pack for Seaking 180a
  154. What cause slow speed?
  155. My first boat build. FE Sport Hydro
  156. Ecomaster Evgeniy
  157. Connectors (hydro1, mono1)
  158. Questions for a 1st P Class build
  159. Help determining kv
  160. P class monos - % hull in the water?
  161. Tp motors with finned cans and water cooling
  162. New to this site and hobby!
  163. Rigger kanat se?imi ve montaj
  164. Here's my SR80 Pro
  165. What cause 6s turn to 5s?
  166. On - off switch for ztw200
  167. Neu 2215 1Y....what to build
  168. Radio + esc programing ?
  169. MHZ Mystic 1380mm
  170. flex cable failure
  171. Dynamite Water Jacket Cooling Outlet Thread Size?
  172. ml gps v2
  173. 6s Spartan help
  174. ESC Cap bank: is it always necessary?
  175. Disconnecting OSE 8mm connectors
  176. Throttle calibration on ZTW 200 esc.....
  177. (MOVED TO ESC FORUM)Throttle calibration in ZTW 200.....
  178. ML Boat Works sport hydros - questions
  179. Proboat Shockwave 26....BARN FIND.. HELP
  180. Where to buy hull with hardware?
  181. ML Boatworks GSX380 long or short cowl differences?
  182. Anyone here buy from oxidean marine?
  183. Massachusetts south shore boaters
  184. Mamba XLX2 calibration problems
  185. Toucan DTRC E51 boat
  186. Fiberglass hull for Q hydro class
  187. Delta force mono speeds
  188. Why I keep losing prop?
  189. Dumas 1930 chris craft runabout
  190. SSS V2 brushless motors.
  191. old 1/8 rc fe boat stub shaft and strut bearing question
  192. JAE FE33 motor speed control recommend
  193. Jae 21 fe v2 33 fe ?
  194. Boy I hate the heat
  195. What cause the vibration?
  196. Average prop slip for well setup cats
  197. 57" cat setup help?
  198. Does ?c? rating make a real difference
  199. Did I burn my esc?
  200. Shark ESC & Intro
  201. Need help identifying this model.
  202. Does motor/esc connector size affect temp?
  203. Delta Force Still In Business??
  204. Anyone here know how to bind proboat stock transmitter?
  205. Mystic C5000-new build need some advice
  206. Where can I buy la large rudder?
  207. Insane Mono for P Mono class-any tips?
  208. How to fix massive leak?
  209. Cen Wave Shark-Brushless power questions
  210. 50" Mono Twin setup, I need help.
  211. Rough water capability
  212. Xt90 good to use or need bigger connector?
  213. Strange collet problem
  214. Anyone has a problem with skyrc gnss gsm020?
  215. Help with Tfl 29mm Jet
  216. Proboat Shockwave 26
  217. Help me pick a hull
  218. Help me choose the right catamaran
  219. is tfl still in business
  220. Problems with swordfish pro 220 a -6s esc ?
  221. Battery trey for M34 Raider
  222. Monojeff?
  223. Need a boat
  224. Scale engines.
  225. Phil Thomas you should be proud !!
  226. New guy
  227. Rudder placement and geometry type
  228. break away bolt
  229. Dumas Short Stuff Deep Vee Electric Conversion
  230. C5008, C5009 and HPR115.
  231. TP motors
  232. Shorty Lipos
  233. Need Recommendations for Q-Cat
  234. FE PTunnel
  235. Calculating current draw ?
  236. New to RC boating looking for suggestions for motor And Esc
  237. Which Speedmaster rudder ?
  238. which motor and esc on 6s for JAE 33 ?
  239. West systems G-flex 650 ?
  240. Which ABC props should i order ?
  241. UL-19 Proboat headache #69
  242. Proboat Veles Shuts down.
  243. Altamotive (Brent Byers) Wire Drives
  244. JAE 26FE ....twin?
  245. Cheetah xl - hull problem??
  246. P Class Opinion & Insight
  247. rigger turn fin lift?
  248. Boat tips when turning
  249. Help with choosing solder
  250. first outboard
