- Dumas DV 60 gets a new lease on life
- Tipping Sonicwake
- Traxxas Nitro Vee - A blast from the past?
- Electric conversion on a Miss Vegas Duece...Motor placement?
- storage racks, how much did you over buy or under buy
- TFL Zonda 41" Cat
- Questions about ESCs
- Need Advice Setting Up The Zonda!!
- Twin setup for a MMP TITUS ?
- H&M mono torque roll
- Blackjack24
- Twin mono ruder set back
- Backlash battery placement
- Torque steer solutions
- What?s better?
- 2020 Christmas gifting, wanna start a little early?
- Zonda struts
- Df explorer 36 cat question
- Prop hits rudder
- Looking for an hydro
- Dragon Hobby Mini Cat with OSE Upgrades
- Futaba telemetry
- Proboat Thundercat converstion
- Fine tuning DF Pirate 35 mono
- Motor SSS56104 Question
- SonicWake 36 ESC
- MHZ Mystic 114 Setup Question (?)
- TFL Cheetah Assembly
- Problem?
- Where are HRC Water Cooling Jackets ?
- Twin setup advice needed
- Stinger or strut?
- Who make this mono ?
- 1/8 scale hydro
- Modern electronics
- Baby SV43 running gear
- cooling question
- Beauty rings for Rigger sponsons
- Connector size
- First rigger - maybe jumping in the deep end?
- Large scale outboard design questions
- New Dumas Miller America; Brushless Help!
- proboat
- Wrench?
- One piece flex cable
- Beginner to RC boats
- Recovery boat
- HET Typhoon (39mm) water jacket?
- Motor mount
- Flex Shaft QUESTION
- Quick question for a rookie
- Veles 29 stuffing tube question
- Ceramic coatings - Hulls
- Prepping ML RSX380 for paint...
- Futaba and Ztw experts
- Tips on removing teflon/stuffing tube?
- New Mono 10s build.
- Recommendations for a recovery boat
- Looking for a big mono hull
- Miss geico 17" upgrades
- Plywood sheeting for ML Boats scale hydros?
- Thru hull water pickups
- Pros and Cons
- Stub shaft
- Veles 29 Maiden Voyage Speed
- KlassKote over West Systems on a wood rigger?
- New to electric boats . ML Boatworks GP310 SE / RSX 310 -Limited
- Antenna mount
- Needing answers on 1st Build, ML Boatworks GSX 380-V2
- HPR 115 "Atlantic Challenger"
- proboat
- TT Olympian mono upgrades
- proboat
- Twin outboard center console build
- TFL Osprey thoughts
- Electric Motor Mount Offset
- Advice to a newbie
- Motor Alignment
- effective cooling?
- Runtime?
- To solder or not?
- Worth it?
- Looking for a good quality flex hex .
- Leopard 2845 2230 KV.
- Powering a new build
- Motor choice for Ml rsx380
- Gas conversion
- ZTW 200 esc. vs. seaking 130 high voltage
- Dynamite 1500kv motors
- Need help with new miss Geico 36!
- Help
- Help
- Pacer finishing resin PT-40
- Prop shaft lubrication oiler VS grease
- Lipo cooling plate.
- Beginner help
- Batteries in series
- input requested = MHZ Mystic 840mm or 1140 vs Proboat 36 Miss Geico
- Question about esc
- Flex cable
- KV versus prop size.
- Rudder help.
- Stuffing box holder
- Pushrod size
- boat hulls
- Rudder throw
- Q-hydro 200a esc?
- Prop Rotation and Spin-out in the Turns. Oval racing / Running.
- Delta Force 41 mono.
- Miss Geico 36 flex shaft issues
- ML GSX480 electric
- Backlash equiptment
- CRC 50" mono hull
- New Flowmaster Twin 920 offshore cat
- Linkage rod/thru transom grommet
- OSE Raider 90amp ESC question
- Miss Geico twin 36 battery tray loose
- Hobbywing Seaking 180 amp V3 ESC Surges
- Veles 29 DX2E end point adjustment?
- Veles 29 prop angle
- TFL Hobbies Company - Customer Service?
- RCM Telemetry app no longer working?
- New to RC! Purchased Zonda TFL 1133
- RSX 380 from 8s to 6s.. what kv?
- 200w soldering iron?
- Glueing carbon fiber motor mount .
- P limited cat speeds?
- Possible Pursuit jet boat mod
- What is up with the Traxxas 2080 servo
- KEPs Riggers
- ML Boatworks 48" FE and Gas race mono design-developemnt- now in the testing phase!
- Cat Hull/Outboard Build
- Rest in peace my Friend: Michael paganelli. 1967-2021
- Building a 49" deep vee boat
- Stinger setup for initial tuning
- Pictures of steering set up on air boat
- Veneer on birch skins?
- Difference between rigger vs sport hydro turn fin?
- Krylon colormaxx spray paints !
- Large twin battery advice
- Tell me about ride pads and angle of attack
- P-limited or P mono hulls 4s set up
- H&M flex hex
- Zonda 41 suitable for oval racing? ? ?
- Replacement motor TFL "Princess"
- Blue receiver box
- Resurrecting the past
- HPR Outside disconnect plugs
- RTR weight of our boats?
- Bullet connectors
- Stuffing tube size for 1/4" flex shaft?
- What esc to choose?
- TFL Arneson outdrive
- wire connections
- Best 41-44? cat hull for 100mph
- Excalibur II scratch build help
- Steering
- new motors for twin zonda
- Any help appreciated!!!
- Anyone need a Lehner motor, cooling jackets, delta/star connections?
- Shorted?
- Graupner 500 repower
- Sonicwake with Leopard Motor
- Make me faster
- Installing battery connectors
- Prop Help
- Dow pink foam /fiberglass composite !
- TLF Pursuite w/ flood chamber
- 4082 2000kv 6 pole amps
- Artr
- Mystery Boat
- Delta Force 49 Setup for Racing
- Loadout for Custom Boat with Raspberry Pi Controller
- GrimRacer 42 x 55 Prop on Sonic Wake
- Anhedral on cat ride pads?
- Filling in Transom holes
- H&M lobster rigger set up issues
- RC Boat Bitz adjustable stinger for Sonicwake 36
- Zelos/Miss Geico motor swap question
- lipo's question in series
- PB Sonicwake Vinyl Wrap
- Loctite to use?
- K&B 7.5 lower leg
- What mm are bullet connects on PB Sonicwake?
- TP Power USA
- Diving Boat
- Mystic 29 strut strut setting
- Need some pointers: Location of electric motor and mounting of strut questions
- Another Traxxas M41 top speed thread
- Dynamite 1900kv/Seaking 180 wiring
- RC Pro plus ESC/Motor solderless connectors
- Flex shaft pro's and con's
- How long to wait for 2k clear over HOK aerosol?
- Best size ESC for TP 4060 motors?
- Rockers and hooks on monohull bottom!
- Motor for PB Sonicwake 36
- Flex Shaft for Pro Boat BlackJack 42
- prop choices
- Suitable oil for captive flexshaft lube
- Twin drive, Same motors, different shafts.
- Cheetah cat doesn?t like water! ZTW seal 200a issue
- ML boatworks 34 inch Wild thing mono !
- When it goes wrong!
- Anyone know a Charlie Rose that runs rc boats?
- Reversed thread collets on a cat?
- Hydro&Marine FireBee (25.5?) setup Q?s
- Flex shaft/collet issues
- Caution - Hifei capacitor board installation
- Antenna wire broke
- Connectors
- Power and Speed Mathmatics
- Stright shaft from OSE
- Sonicwake 36 seaking 180 esc no motor turn
- Timing on TP 3650 -1680kv 7D
- MHZ Alligator 1250mm 49" twin outboard build
- zonda twin with water leakage
- Why are battery trays glued in with silicone?
- Octura .187 Flex Shaft
- Seaducer S mono SAW build.
- JAE FE 33 P-limited Hydro prop?
- New Proboat RTR Larger Mono Hull Idea
- Need motor help
- Proboat Veles 29 being used for NAMBA P.LTD. Hydro racing, drawing too many amps
- CF boat
- Genesis talk
- esc problem
- JAE FE 33 P-Limited
- Timing
- Trim tab/turn fin adjustment
- is anyone using load banks
- OSE program card for OSE Raider 150A ESC
- Swordfish x300 timing degress
- RPM?s
- Dashware
- PLEASE Create an "Impulse 32" thread within the 'ProBoat Mono' section
- Zonda twin versions 41' vs 38' (calling all Zonda nerds)
- Parallel Battery Leads for Easier Charging on Large Connectors
- Prather fun cruiser shaft
- Odd battery behavior, cell mismatch
- Routing cooling water lines
- Mono build
- 55" segad cat
- Flex shaft issues..impulse 32
- HydroMarine Intruder MK2 performance/ questions?
- New Saw Carbon Rigger Issues
- Prather Prop ratio
- Rudder and prop shaft kit recommendations
- Still playing with ver 1_Miss G
- ZTW 200 amp esc
- Advice for a newbie. Which V hull should I buy? Sonicwake, Dominator
