- OSE Raider M34 ?
- I need some help getting contact information with a battery seller?
- 600 ABC xxxx-17-45 Props Just came in.
- Props to try on a P sport Hydro....
- nickel strips
- Newest addition to my small fleet!
- Flex shaft help
- Converting a gas outrigger to electric
- Swimming Pool Racing?
- What to use?
- Suggestions for Aeromarine Titan 29
- Can SSS 3674 2075Kv Motor run 6s?
- Using different radio for the UL 19 and the Villas 29?
- Aquacraft Revolt 30?
- Merry Christmas Everyone
- Motor kv
- Crackerbox
- Max amps
- 33" carbon fiber mono
- Prop help
- #ProBoat #Sonicwake 36 speed boat 2nd run on YouTube (90kms)
- Powerhobby batteries
- Scale Evinrude Lower Unit Greasing
- 50" scale jet boat engines
- Atomic 58 RTR Upgrades
- swoop waterline grommet question
- larger id water tubing ,does it really help?
- Power Setup Questions
- Delta force / pirate 35
- Weight
- Legitimate records or no?
- ESC options
- Slow delta force Pathfinder
- Banggood online store for RC Boats
- Looking for advice on RC Boats
- Wiring Diagram
- Slow Neu 1521
- Speedcraft P mono hull
- Silly 'SAW' rules - UK
- A couple of questions about my first Build
- Gas to electric conversion project....
- Miss Budweiser nitro to electric?
- 6S motor install in 32'' monohull ?
- Need help choosing a new charger
- Build Thread: 36" 3d Printed miss geico catamaran
- Build Thread: 3d Printed 33" Mono Speed Boat
- water proofing
- Extending ESC to motor leads?
- ML boat works THX 305 tunnel hull kit ?
- Water line grommet
- flexshaft advice
- seaking 180 lvc question
- Water cooling issue ?
- H&M No step 4
- Tp 3630 1950kv
- couplers
- Best ESC
- Little help on wiring
- M34 Raider 4S oval setup help
- TFL Zonda Maiden Voyage
- Skunkwork's 32 Cat
- I made a mistake with epoxy
- New Motor For Feilun FT011
- Mini Outboard Motor
- Can I run 6S or Only 5S?
- ABC super hawaii powertrain options
- Build an outboard boat?
- Cutting Out
- Outboard cut out to mount electric motor to leg without adapter?
- Cavitation Issues
- Water jacket
- Bigger boat recommendations
- Help sourcing fuel tanks
- Large mono - Mhz study 7700
- Newb Looking to Purchase First Boat
- Brand new Veles 29 - Noisy!!
- motor mounts for crew
- Prop ideas
- Prop damage
- Help with Motor Size
- Promarine Skater
- ordered a new esc for my veils 29
- Kulz 150
- New member
- 2 brushless motor setup??
- Zonda Prop Selection
- Miss Pepsi U99 1952
- Flex Shaft Wire Lay and Prop Rotation
- new to fe
- Zonda new prop performance
- CG for 44" 13 lb. Hydroplane
- Monohull Balancing (CG)
- Toy sport Syncron Titan
- esc and motor combinations
- Twin12s expresscraft mti 60?
- Motley crue problems
- MHZ ocean spray
- Getting back in to r/c boats- NEED SOME HELP
- ....any Vermont RC boat clubs or meets ?
- Shortening wire leads on esc question
- ProMarine RC - Good or Bad...and, are they even still in business?
- Advise for fist run
- 1/10 Shovelnose Racers - What speeds with 1500kv 4s ?
- Esc was replace now seems slower
- vxp racing motors and parts?
- Pros and cons going from gas to electric
- Breakaway screw on 36 Miss Geico ProBoat
- Voracity needs some help.
- Adding lipo
- New Zonda 980mm (39-1/2") Carbon Fiber Cat
- Jersey Speed Skiff....any recommendations ?
- Miss Gieco 36 Maiden Voyage at Grand Lake
- Total Noob - Intro + Zonda questions
- Proboat Miss Bud Bent Prop Shaft Help
- 187 (3/16") cable, drive dog, bullet nut : 3/16" prop shaft : 2.75" long
- Bullet size vrs amp draw
- brushed motors- wire size
- ProMarine RC Skater X2 Setup Assistance Needed
- Delta Force 28 P-Limited Cat
- Whos making these wire drive coupling systems?
- Aquacraft EP1 Outboard gears
- Rigger Angle of Atack (AOA)
- Need cooling advice
- Proboat Veles 29 blinking/beeping green light--help please
- looking for a 48-52" rough water mono (more modern Apache)
- motor ?
- Can anyone identify this tunnel hull?
- Cat tunnel angles
- SAWs boat Brakes?
- Teflon liner length
- Stuffing tube
- Sonicwake 36 porpoising Like crazy
- TFL 56" Genesis ?
- Need advice on LiPo 3s 5000mAh battery charger and Sonicwake36
- Propeller design
- my first boat
- Counterrotating twin prop outbordmotor
- need help programming twin!!!
- Fusing
- Costs for a Davette 46 hull
- Motor test
- Flex shaft whip and liner length
- want a new boat
- New here need help
- big cat beam: wide vs narrow ?
- Dual water intake
- Adjustable propeller pitch for surface pising propeller
- rcm telemetry
- Adding LED to ProBoat Jet Jam -
- Plettenberg motors and compatible ESC's?
- MG Zelos 36 Battery Question
- What are you using for gps and datalogging
- 2014 ElectraCraft Boat 14 LSR
- Water entering boat !
- Bonzi Sports - sharpened and balance option
- 33 inch rigger handling very twitchy
- Boat for 3s 2200mah
- Sonicwake 36 esc/motor upgrade
- Miss Geico 36 Flip Over???
- TFL sacle outboard, anyone run them ?
- Graupner Key West
- O-Rings
- Pro Boat 1/8 Bud
- Miss Geico 36 porpoise starting at low speed
- Converting old aeomarine hull from weedwacker 26cc to electric
- Proboat blackjack 24
- Wild Thing (2000 issue RC Boat Modeller)
- help!! can't bind my graupner radio.
- Motor and collet getting super hot!!
- 42" Tunnel
- Where to mount rudder on delta force 29
- motor sise
- torque roll
- New addition to the collection .
- Z.T.W. Or SordFish 300a E.S.C
- Carbon fiber outrigger
- Kyosho Jetstream 888ve stinger mods
- Understanding battery pack selection in relation to motor and ESC??
- sea clear boats revolt 36
- Heat issues
- Prop help
- CG conversation, whats a good starting point for 36 Catamaran?
- New (used) boat won?t plane.
- aeromarine 36 sprint cat twin drive suggestions
- Cheetah low profile (110mm) replacement upgrades ??
- Tfl popeye vs Proboat Ul-19
- Best P Limited Motor
- Measuring speed, RPM, prop slip via Doppler shift
- New to Boating 🛶
- Mystery Boat
- Gieco 36 breakaway ruder
- Mystery Boat Part 2
- Miss geico 29 motor coupling hex screw
- What glue to use to mount the motor mounts to hull
- Esc advice
- prop shaft assembly K/B outboard
- New to fast electrics
- 41 Zonda rc boat (need help)
- Proboat delivery delays
- ESC Help needed
- Do not trust user mcjohnscott
- Oil mixture
- Hobby star
- Scale caluculator fo scale truck, trailer and boat!
- Old boat upgrade
- Smart lipo 3700-7.4
- Moderator please
- Scratch built cat - Size recommendation
- Set up help for 26" play mono
- Two AC Cats need prop recommendations
- Model testing Cat hull designs
- Hyperion Batteries
- Why just have a starboard turn don?t?
- Thread size and pitch?
- 3 flex shafts w/props gone...
- This wiring is messsssed up. Please teach me how to fix it!
- Rescue Boat ideas..
- Wanted sts
- Outboard questions
- Cheetah struts are pigeon toed - Normal? Fix?
- TFL Cheetah Carbon Fiber
- Reducing hull length of Blazer .21 Whip lash hydro for a mini bl hydro !
- Anyone in Las Vegas?
- Flex shafts breaking. I must be doing something wrong. Help.
- Sonicwake prop tags rudder
- Help with finding a part.
- Ding in rudder
- Sponson depth for mini hydro
- Motor Identification
- Sprint 36 prop selections
- TFL Cheetah Carbon Fiber vs TFL Cheetah XL
- Sprint 36 race motor
- Sprint 36 on 8s
- Small hole in my hull
- New Build Issue - Twin TP Motors Won?t Arm
- Keith Kirchen
- Motor Losing Signal
- Aerotech tunnel converting to electric
- Antenna mounting
- Who still uses a RX external switch on their boats?
- ESC telemetry
- Tp 5680
- Aluminum stuffing tube?
- ?S? bend in stuffing tube?
- My boat lost connection in the water!!
- mx4000 reicver
- SuperVee27r still worth buying?
- Tale of 3 Swordfish
- New to electric boats
- Challenger 48 motor position?
