- Ul-19 30
- Newbie AR 44 cat build
- Need beginner help
- Which project to start..
- Outboard Motors
- Strut adustment simplified
- M/l boatworks 1/10 scale hydroplane build 121
- Cleaned and updated the RTR forum
- Yep, here I go again with another Traxxas villain...
- OSE Raider M34 being Raffled off at this weekends Namba Winter Nats Race
- Main Voltage to EagleTree data logger with HiFei Isolated Ground ESC.
- Help with rudder placement
- Asking for a friend. Really.
- Mgm and lehner
- Boat Paint
- Call me dumb but not stupid please
- Where to begin as a newbie
- Delta cyber storm 33"
- Promarine MTR Setup
- Help.
- OPINION on broken shaft
- Looking for Top Custom RC Powerboat Builder\Company Help Appreciated.
- Amps Formula 357 SR1 54" Fiberglass or Carbon hull Bywoodrcboatkits.Any Feedback??
- tlc electric out board
- how to posts pics
- Fun with Futaba telemetry
- Vbox/crackerbox/zipp kits
- Need Help
- Maybe I can salvage the prop nut..
- Seeking advice on setup for a 45" mono
- Drag boat hull
- Visiting New York in July,which RC Boat shop is worth a visit?
- Baby Mystic 84
- Thai Long Tail Boats
- 1/10 scale m/l boatworks electric u 15 Vintage shovel nose
- Genesis 56†upgraded to TP 5680 800Kv + Swordfish X 300A ESCs
- Vintage 1/10 scale hydroplane question
- info on rc motor
- Proboat Jetstream
- Help $250 bet
- Winter tunnel build(s)
- HK Genesis - New to fast electric boats
- Bad day at the pond!
- Traxxas Villian EX
- 1/10 scale photo needed please
- carbon fiber vs fiberglass reinforcement
- any kids getting into the hobby with there dads help
- Zonda?
- Looking for a boat.
- Lipo fireproof bag?
- Upgrading props?
- More cooling?
- Traxxas Villian IV with Rocket motor mount
- Best flex lube with no liner
- Shaft seal / Stuffing tube?
- Rudder Pin?
- Battery?
- What size flex shaft do I need?
- which Motor?
- Anyone using a NiMH battery?
- Need Help. Screaming motor full throttle not possible
- Just curious
- Little insight as to what may have happened?
- Box stock mono for p limited?
- EC5's am I safe
- Setup for a 39'' - 1 meter catamaran ?
- Build in extra capasitors??
- Kyosho Jetstream 888 VE Readyset (upgrading TX e.t.c.) My First real RC MODEL!
- Two 6 mm connectors in place of one 8 mm?
- A time before BL and lipo
- MHZ/MMP Trident F1 experience?
- Motor size per kv question.
- Ok setup?
- Aquacraft 60 amp esc LVC cutting in way to early
- Helion Rivos XS brushless motor questions
- Help With Motor Sizing
- Valvryn tune-ups?
- FAST crew's new driver's stand.
- Want to race a simulated hydro for free?
- Prather cat II conversion to Electric
- Bullet plug diameter required for aq ul-1 2030 kv ?
- Max Diameter prop for Leopard 3674 2200 Kv onn 4s?
- Timothy Landauer has passed away
- Need Professional Help.
- Boat stand / transport stand / transport case?
- Big oops........ Help.
- Liftmaster Rigger proposed set-up
- OSE Bi-Drive Outdrive...anyone used one yet? I need feedback!
- Rebuild Segad 55” video 122 km/h
- best design and easiest retrieve
- Do I need Turn Fins & Trim Tabs?
- motor rating is 2300
- HK Genesis Build/Help
- What mah rating for lipo required for Leopard 2860 4050 KV ?
- Sss 5694 1200 kv / zipp kits easy vee question
- New boater to the electric boating community
- Jay Moffat contact info
- Super Strut for the GENESIS Twin Setup
- were can i find hulls
- 60 cm / 23" Catamaran setup
- Outboard Delta Force 26
- Nitro to fast electric
- Silly Me with wordage
- How to regulate FE power in the future?
- Help with motor for 1/8 scale hydro hull
- JAE 21 outboard electric conversion help needed
- Power Boat Modeling Magazine 1981
- 2 questions one post
- break away rudder question
- Help please. These motor Kv`s are really confusing me.
- How to set drives at zero degrees
- Coverting a nitro boat to brushless
- 51" victory cat setup?
- Strut on a Catamaran
- I AM RIGHT TO believe this online Boat part purchase opportunity is a scam?
- What are the popular 4s-6s mono hulls ?
- Teflon stuffing tube Question Help Pls
- Blackjack 29 hit by Sonicwave, can this Hull be repaired?
- Octura models ?
- safe motor temperature
- Dunlap 27'' O/B tunnel hull bow bouncing up and down ?
- Need Advice OLD MRP Tunnel hull Electric Bud Light
- Serious Setup Question
- test
- RC Pro Boat - Black Jack 24 inch Catamaran Stock Run in (1080P)
- Motor temps Esc temps and Lipo temps
- ZTW Seal 200a ESC
- couple questions (motley crue and zonda)
- Need Help with the proper ESC for a F1 Tunnel Hull
- P cat setup?
- veles 29 vs zelos twin
- Michigan Cup Results?
- Converting from .67 nitro to fe
- 8s Rigger Build?
- Proboat UL19 and Sonic Wake reduced speed after one short lap
- 1/4 Scale Tunnel nitro convert to electric????
- GPS Reception in All Carbon Fiber or Carbon Fiber/Kevlar Reinforced Fiberglas Hulls
- Yaaaaay!
- Exceed Flowmaster catamaran was fun while it lasted!
- Help with Sonicwake proboat part.. Canopy screws
- Aeromarine mean machine
- What would cause Leopard 4082 1600 Kv motor to burn up?
- Proboat Sonicwake Canopy Fixing Problems
- External Ice water cooling system
- Whats the best Silicone to use on your new boat to seal EVERYTHING?
- Deltaforce 36" set up and rebuilding questions
- Help miss geico 29 broken shaft no replacement available.
- Toysport Triton Self-righting does not work
- Hotshot 45 fe build questions
- First SAW build.
- BSD.com boat hulls
- Internal Water Cooling system Pump for large Catamaran
- Outboards, again...
- Info on Bangarang Surf Boat
- TFL Genesis 56”/1420mm Hull only Asking $525
- Large Electric motors vs Smaller Electric motors
- What rigger for P hydro?
- Motor Position and Ride Attitude
- Are 7.6v batts safe to use on Miss Geico29 v1 ?
- zellos 48g issues
- 1/8 scale questions.
- Whats up with the Speedmaster SPDS-014-BSF 3/16'' strut bushings ?
- Sending pictures through private messages
- Clear shrinking tube to esc
- Sprintcat runs
- Got in my new Sonicwake36'' & going to be doing some Hop-ups
- Really Namba?
- Sonicwake antenna?
- In need of run times for big/huge electric hulls
- How to select motor kv value combined with prop size
- missing RPM's
- Need Help 1/4 Tunnel
- what the heck
- Simple 4s mono ?
- Important!! OSE Site Maintenance starting August
- ML boats thx305 anyone build and race one
- Silent Engines
- Why is Power cutting out at full throttle
- Help!!! Miss Geico 36 Paint Color Needed, PLEASE!!!
- ESC Recommendations ?
- Picked up working on my my Pirate again. Need help as usual. Rudder to servo linkage.
- Help Identifying This Boat: Cosmo UFO Tunnel (Hydro)
- Water jacket stuck on motor...
- Ose 8mm anti spark connectors
- why carbon for inlays
- runaway bj29v3
- info on 3674-B-2200kv
- Issues with boat continually cutting out???
- Boat turning problem
- Want to build a P limited hydro!....and race it!
- Noobie Setup Help???
- Ul-19!!
- Mystic running on snow?!?!
- Who makes these?
- stuff for my whiplash!
- Help Me Choose a motor and prop
- Need trim tab suggestions for 31'' monohull .
- Flex cable failure
- Boat keeps shutting down LVC?
- Need help selecting prop for Voracity w mods
- coyote conversion
- Paint!
- Sonicwake Up in smoke
- Strut adjustment
- Cad wanted - jet propulsion drive awake boards - free board offer
- Mounting trim tabs on a mono hull ?
- Strut bushes
- Dirt cheap 48" Rockstar gas boats, RTR
- dumb esc question, but........
- Giant Power Batteries
- Sprint cat 42, Stryker f41, or Stryker top gun II electric?
- End point adjustments?
- Hobbywing ubec
- I have a customer looking to get into 1/10th scale hydro and needs help
- Selling boat questions
- dumb question about tunnel hulls
- Delta Force 29 mono electronics upgrade
- Prop diameters and height
- V24
- self-righting with no flood chamber
- [B]MHz 138 boat weight information[/B]
- Steering rate for oval racing
- New forum section
- Considering new build: TFL?s 51? Ariane or the 50? RSV Raptor
- Location and flex shaft dia for 32'' 6s mono ?
- New Cat Build
- Getting back into boating - questions please.
- Castle XLX ESC question
- New TFL/FE Marine Cheetah
- Does anyone recognize this brushless cat?
- Sonic wake killing ESC's.
- Ideal setup for TFL Cheetah
- Prop suggestions 4082
- TFL Carbon Fiber Pursuit Motor Recommendations?
- Electric Surfboard
- Bad day at the lake😢
- Help in understanding FE?
- Valve or Petcock where?
- Americans can go Naviga Racing again!
- MHz c5000 Mystic 1140
- Veles 29 handling
- I did it!
- Turn fin location on transom for mono hull ?
- Help Identifying this boat
- Looking for a specific AM Mean Machine
- Esc overheating
- Christmas giveaway time!!
- Prop size
- Motor???
- Received new boat- 32 Skunkworks
