- DF Cyberstorm 33 or TFL Pursuit
- Racing or clubs in St. Augustine, Fla.
- Hyperformane TX45 Tunnel
- TFL or Kintec front plate for motor mount.
- Vs1 water cooling
- New question about prop installation and setup
- What diameter prop size should i start with for 6s mono ?
- New again
- Setup Opinions please
- Motor Beeps, Will Not Spin...
- Need Help... TP Power 40 series motor diameter
- M41 3/16 shaft upgrade installation questions
- Motor Cooling Jacket Water Flow
- Hello
- New to Flex Shafts
- Most Popular Inboard Tunnel Hull ?
- Trying to cool my esc
- who's running a 2028 Castle
- Another P-lim motor question
- Turnigy 3994 water jacket?
- What boat is this?
- Who makes good Rudder Blades?
- Vintage Dumas miss Thriftway Too. Hydro
- Saying good bye to one of the great OSE Moderators, JimClark
- Who sells top quality Carbon fiber cloth?
- Proboat blackjack 29. 4s.. 50mph
- How do i stop water entering stuffing box ?
- Most favoured Deltaforce mono ?
- Building a DF35, Looking for proper prop to rudder measurements.
- Where To Find Ball Joint Swivels Used In HPR Drives
- Motor runs when losing signal from controller
- Dual brushless motor install Expresscraft Supercat
- Who resells Rear Motor Mounts Suitable for Cats?
- 39'' catamaran twin setup RPM ?
- What Diameter prop for 5S O/B tunnell hull ?
- Turnigy 180 v3 esc cooling ?
- Blackjack 29 v3. 6s 55mph comfortably.
- Someone need (2x) Schulze 40.160 (Old school) ?
- Contacting TPpowerusa
- ML Boatworks GP Series is coming back, but all brand new..The Special Edition Series
- Using the Flir Camera to view motor Temps, inside and out.
- First run on brushless
- Most Important Places to Reinforce on a 45"+ SAW Cat?
- Self Righting Riggers
- Need sugestions
- Offshore Electrics Shipping and Store Schedule
- Flex shaft collet
- How creative sometimes the mind works
- Wire drives for bigger set ups.
- Advice needed 54" seamaid electric drive scale performance
- 45" - 60" Twin Catamaran Weight
- Beautiful boat
- International Waters site, not secure, etc...
- Blackjack 29 v3 6s runnin hot
- Power output does not reflect to power input.
- Playing with the big boys!
- props
- RC Raceboats stingers for a Twin Genesis
- Turnigy 160 esc
- Radtek 92" hpr 233
- Soldering-
- Turnigy receiver relay swicth
- need electric motor size help
- Changing between 5s & 6s with flycolor 150
- Water pickup location
- Need some advice on big boat with big electronics
- Smaller mono choice for windy day water
- Genesis 56” Twin Cat Discolouration of One Motors Wires!
- Deep V
- COG on a 33" P mono Seaducet
- Genesis 56” Twin with 12S.
- Tunnel project ( Test Mule)
- Bad day at the pond today.
- Good for a rescue boat?
- Gel coat or paint?
- Why do i not see s bends in fast electric often?
- Voracity discontinued?
- Which direction on a scuffed bottom?
- Only 63kph on 4s!!?
- PX-300 Tunnel Hull Kit (Instructions)...???...???
- Need help with a Prop Problem
- Transmitter on first, receiver second but what about a UBEC?
- NEW ! Beautiful Mono 39''
- Finally tested the Dunlap W.O.F. 30 on 5S and a big thanks for all the help .
- Praise for OSE service
- Looking to buy a stock s&b blackjack 29 prop
- Motor RPM
- capacitors
- cauldwell out drive
- Water cooling system
- Leopard 4082 2000 KV on 4S on 30'' tunnel hull ?
- TFL hull
- Newbe
- JAE 45FE Motor choose leopard 4082 or TP4070
- aeromarine meanmachine
- Tunnel hull outboard height
- Delta Force 33 won't get up on plane
- Turnigy batts?
- Prather lap cat Question
- Got a Cheetah Hull - Help with setup appreciated.
- New Best with the M41
- Flycolor 150 water inlet
- will this combo work out mathmaticaly
- II dual Outboard motors
- My TFL Zonda cronicals
- Say no to plastic
- escs and capacitors
- Parts question for DIY Electric Surfboard using RC Motors
- OSE Zonda upgraded drive flex shafts
- Recommendations for p-limited offshore boat (NAMBA legal)
- 50 amp esc for shock wave
- Zeles 29 flex shaft
- H@M 1/10 Twin Wing Hydro
- Back in the game
- aquacraft ul-1 superior
- MRP EP Motor Setup
- Motor Timing, Can Someone Explain How It Works To Me?
- First Boat - TFL Rocket - New to RC Boats -
- How are MarineFE boats?
- Pulled the trigger...
- Battery load test very good info
- 8s build help
- Two motors & two ESC's and a WYE connector to receiver -something needs to be cut ??
- Thrust bearing between dog and strut
- How much is a Venom King Of Shaves P1 worth?
- Anyone ever use this Traxxas 2200kv. Sure looks like a castle.
- Garmin fortrex 301 gps reading's ?
- 6s/Q cat for IMPBA
- prather 46
- Top Performing Sport Hydro
- WHats next for ProBoat and when??
- Good News Banggood.
- Does anyone use Heat sink compound?
- 1/4 flex shaft glue or solder?
- TP vrs, Neu motor
- R.C. clubs
- leopard 4082 1600kv replacement
- New Toy Tunnel
- 2600mah 4s lipo
- Prop Signature? Who's is it?
- The white Zonda carbon/kevlar cracking to?
- Aquacraft Vs1 Brushless Conversion
- Bad Luck !!
- Bare hull weight for JAE .21 FE ?
- Proboat new sonic wake self righting mono
- replacing my leopard 4082
- Good ESC for Genesis 1045 Stock Motor
- Transom hardware set up questions DF 26 Mono
- Prop spacing
- 60 cm / 23'' Catamaran, setup question
- Recomended RPM range explained
- Motor upgrade for J.A.E. .21 on 4s ?
- Leopard 3674 2200 KV vs TP 3640 3Y/ V1 2600 KV for JAE 21 ?
- Trim tab less w/ stinger on mono?
- FSR mono with twin surface drive...Would it work ?
- Sea king 180 v3 ESC
- TFL Zonda twin cat
- Testing W.O.F 30'' O/B tunnel ON 6S POWER.
- Difference between Speedmaster 20, 40, & 60 rudders.
- WARNING, possible spoof/spam email rcRacingevents
- Noobie questions
- battery trays
- New guy from SE Idaho
- Twin setups
- Do radar guns work for accurate speed?
- Sad! Sad! Sad!
- Time limit
- Proboat Recoil 17" motor shaft drive shaft issues
- phil thomas ss45
- prather 46
- Namba #1895
- TAMIYA Thrust Ball Bearing
- Cheetah CG
- How do you handle this?
- What maintenance to do if a motor and esc has been sitting for a long time?
- Inlet tube locations
- Hydro tuning questions
- What’s the average age of racers at everyone’s pond, lake, ocean
- TFL Stern Drives
- What’s up fellas?
- prather 46 before
- Bonzi does electrics better than anyone.
- ...ANYONE doing anything with outboards? Brushless ??
- new boat over the winter
- Coupling
- ? for wood boat builders !
- China outrigger
- Mono with battery puffing problems
- How much power is enough power?
- H@M Miss Bud
- one radio for all your rc toys
- STS shaft seals
- Turn fin for GSX 480
- Genesis Rudder
- Castle 2028 800KV Amps
- EP650 outboard
- watercooling and cap bank for mamba xlx
- Thrust washers
- Prather 31'' Deep vee conversion to 4s bl power ?
- Greasing up for winter
- Neu 1515 2y/f/h
- A 3-blade prop is faster then a 2- blade ?
- Mini rigger setup
- Is there a Popular budget waterproof servo for FE? How many oz Torque are required?
- ETTI 60V 250A Power Analyzer ???
- Any problems with Aeromarine Orders?
- Reservoir Frozen November 15th_What's you're puddle look like now?
- 55” Hull
- proboat 26 recoiil ecm wiring controller problem
- JAE 33FE Electric Outrigger Help
- CA Glue Alternative
- Minicat Racing USA Boats and Parts Closeout! We are closing shop so I can retire!!
- Annual Christmas Giveaway!!
- 50" AeroMarine Apache Deep V Conversion from Gas to Electric Help Needed
- Cyber monday sale, Revo Lipo Packs 20% off
- Can I reverse the “Rotation” of my motor?
- Pistol Grip Radio with GPS Speed readout?
- Good economical esc recommendations for Castle 1717 (x-maxx)
- My JAE33 FE
- Electric Outboard
- Fe tunnel
- brushed mod
- Guess who's back. Back again.
- Electric twin motors for a Central rc marine 51" Victory cat
- newbee to electrics
- Waterproof radio box
- Northside of Chicago
- Seaking 180 V3
- Looking for this cowl
- Want to convert my nitro tunnel to electric (need advice)
- T29 wake board conversion implement idea 💡
- One motor vs. two motors
- 25mm and 40mm Jet Drives
- What Next?
- P limited mono question
- AquaCraft 60 amp ESC questions
- IYO best for offshore
- Newbie in Raleigh,NC needs help
- Electronics anti-corrosion treatment
- newbie question
- New To FE - What’s The Diff Aquacraft 1800 KV vs 2030?
- Outboards...
- Getting back in to RC Boating - new outrigger build
- How to program steering vs throttle ratio
- For P-Limited - Why Would Anyone Run A 1600KV Motor vs. 1800 or 2040?
- Temperature Guidance
- What do you think need advise
- Help with motor choice for 12s setup
