- 55" shockwave monohull swordfish x 300 -hv problems
- Team JAG almost broke 200MPH in Munich
- epoxy inside wood hydros
- Hobbyking Libero mods
- Your boat wish list?
- My TFL Genesis Chronicles
- Cheetah Wraps
- rudder setup
- Ferrite ring
- bad motor?
- Aerial placement
- Looking for a good quality strut for sport hydro ?
- Motor timing "D" wind
- New project 41 inch mono
- Stinger or strut?
- Motor amp draw
- Twin rudder setup on a 41" mono
- Polishing flexshaft?
- Well.......she's all done !!
- White vinegar and epoxy resin
- Initial setting up/installation of the rudder servo
- Battery capacity
- The same boat, different name thread
- Tools for boats?
- RCM Telemetry
- Lead Acid Battery Question
- 2s racing?
- Salt water boat build question?
- Sorry for another "what to buy" thread...
- Custom Battery packs? Anyone make them?
- Old Steve Muck Mono, FE set up???
- 480 Amp ESC
- Miter gears for outboards and outdrives
- Stuffing tubing size for 3/16" flexshaft
- TFL (HK) Genesis upgrade question
- NAMBA Nationals video
- Twin motor mono
- Setting up a strut on a small catamaran single drive hull
- no more metal bearings?
- New goodie for the UL-19 coming
- TFL 1138 Caudwell F1 boat
- Is there a "dictionary" post on FE boat terminology?
- Gas Hulls that Fit the Nitro/FE IMPBA Specs
- Any place in the U.S. where I can get a MHZ hull.
- who made this outboard?
- Exploding Battery at Airport
- How to battle the infamous mono single torque roll?
- Stolen Sport Hydro
- Question about shipping Lipo's
- Where to Buy Cardboard Boxes for Shipping a Hull
- HobbyKing Program Card setting ?
- Long term project 51" mono proposal
- Electra cat hull
- Hobbywing turbo esc
- Semi Truck Boat Trailer
- Pacer Z-poxy finishing resin ?
- Y or D wind
- HK Apparition 2
- Christmas giveaway?
- Re-building a Dunlap W.O.F 30 O/B tunnell hull ?
- HK Smash Shark P1
- MRP Bud light 22'' tunnelhull set up ?
- Water cooling
- SV27 Rebirth
- Marinefe.com
- Questions/Interest in FE
- It's a sickness....I was OK for a while....but.....
- Racing for 2018
- Airbrushing
- Wanting Info on Racing
- power choices
- JAE fe33 motor choice.
- schulze fut-xxl-40.303WK pc software and usb drives
- First time doing this conversion
- Super vee 27r
- Organizing on a cold Christmas Eve.
- Merry christmas everyone
- Linker or programmer?
- Turnigy Aquastar 240 amp ESC
- Where can I find those through hull gromets used when passing
- converting nitro to electric
- Tunnel Hull setup
- Converting Kyosho heatwave
- On the Clock Podcast
- Kyocho RC Surfer 3
- ML Boatworks GP and SX Sport Hydro retirement and GSXv2 series release info
- prop treating
- My Apparition redo from Turbo Dan-O
- Turnigy Graphene batteries from HobbyK
- Leopard Hobby 4074 2200kv "D" or "Y" wind
- Has anyone else had the deck start separating on their Pro Boat UL-19?
- Motor choice for 6s jae 33
- How good is the quality of the stainless steel used on flexshaft stubshafts?
- Aquacraft (Hobbico) Files for Bankrupcy
- Central marine 58" fountain
- twin outboards on deep vhull advice
- We will soon have drives, rudders and other parts from kent at Custom CF Parts
- Very large outboard. X Cat's will love this design
- Water pickup locations?
- Tapatalk
- Delta Force Pirate TFL Drive and one other question.
- Thoughts on the Hobbywing Seaking 180A V3 ESC
- Cheetah Twin
- Delta Force Pirate 35" build before I hit the button. Did I forget anything?
- Repost ... Looking for help setting up a twin outboard V hull Fine design 32.
- Racing and how to increase attendance ??????
- powering a zipkits rigger
- What is the best hull to break 100MPH?
- jet boating with thrasher
- UL1 propshaft ?
- Got a new addition to my small fleet today
- What Prop and ESC for my 31' Hydro
- Scale 50" Popeye Cat with Twin M8 Outdrives
- Ac models boat
- H and M Dr. Evil Hydro 1
- Prop height....?
- Creating a steerable drive
- Pacer 5 minute +15 minute epoxy ?
- TFL Pursuit shaft upgrade
- Arowana 32" self righting hull
- 57" mono
- Soldering TP motor leads
- Another question. Hull material.
- Old member new interest
- Twin outboard install, Fine design 32.
- zipkits fe 33
- Anyone seen an RC Boat Hull Similar to this boat?
- Hardened Flex Cable vs. Regular Flex ? And Who Makes The Best Cable?
- Traxxas M41 with Max amps 8000mah 3s
- J.A.E. .21 rudder length ?
- Drive cable
- Jacking plate
- UL19 Setup
- Painting aluminum?
- Considering another build and wanted your opinion on a hull...
- How to clean out smoke smell?
- Found Great New Course in Tulsa, OK!
- Motor upgrade Impluse 31
- First attempt
- 4mm thread pitch
- What to get...?
- Which brushless ?
- Looking for opions on 2 boats
- Dumas boats ?
- Expired Loctite 648 for Shaft and Flex?
- Veles vs verosity
- Power plant for 21" Off Shore
- swordfish x+ 300 amp
- Revolt 30" or?
- revo batteries
- Who is useing a Garmin Forerunner 101 GPS?
- TFL gear driven Merc Outboard
- WLtoys WL912 Upgrades Mod
- dynamite 2000kv upgrade
- Identifying turn fin bracket
- gsx 310 motor?
- Recovery boat.. What does everyone use
- MTC drive systems
- Proboat UL-19 twin drive
- Just your average, everyday Zelos 48 QUAD
- Silent Engines
- Lakes in Miami ?
- Toucan Hobby, be careful dealing with this site
- Sprint Cat .21 to FE, new project...
- Hobbyking Pursuit self-righting
- Self-righting hull deck inlet holes
- avenger
- Shortening motorand battery wires on esc ?
- robbe sea jet evolution help
- Best Way Solder Additional Lead or Connector to Lipo?
- looking to push an old white heat 43" single step hydro
- GP400 O'berto tuning
- Suitable prop size suggestion
- Toucan Hobby DT51E 1300 mm catamaran
- where I can find some similar carbon fiber hose/tubing
- Cooling Ideas For Those Running Brushed or ROAR Motors
- ProMarine MTR Setup Questions and Help???
- Strut for ML Boatworks GSX380
- TFL Pursuit or Kyosho Jetstream?
- Legg Lake Closed Up ; Now a Crime Scene
- ML Boatworks GP-335 S/Hydro set up info?
- Pro Boat Shockwave 26 V3
- TP 4050 1950kv on 6s
- Toledo. Weak Signals Show who is going?
- Wind dam on cats
- N-1 mono and hydro ?
- 36" vintage glass mono
- can you adjust timing on a TP 4050 1700kv motor?. Mean Machine2. T180. To 4050. 6s.
- Finding good quality boat hulls
- Which hulls are these?
- Aeromarine... another fine design?
- Osprey CofG issue
- Virginia turnfin
- New Here, Need some advice on my ZONDA
- 75+MPH Traxxas Spartan
- batteries for racing in p limited sport hydro class
- Whats a very reliable ESC
- TFL 39” cat help
- programming Orion esc help
- Kyosho Jetstream 888
- Volantex Atomic motor upgrade.?
- 90 threaded water fittings needed.
- ESC voltage input
- Carbon fiber for inlays, recommendations?
- 36" carbon fiber v hull setup
- 33 inch sport hydro motor size ?
- 30" hydro
- Twin XLX Zonda what TP Motor and props ????
- RCM telemetry issue
- latch rc boat hold downs for a round nose
- Turnigy 5 amp (7.5 amp) UBEC
- Proboat shockwave 26 arrival
- Just can't get enough of these Traxxas Villain boats ...
- 48" Tunnell Hull
- Thoughts on Delta Force 28 cat hull?
- Fibreglass 1/10 scale drag boat
- Help! Broken canopy latch!!
- TFL CAUDWELL F1-H2o
- HELP NEW BOATER, out of the box and wont work
- X in a black box
- I thought that RC boats were just toys!!!!!
- ISO a competitive mono hull preferably cf. 33 to 36 inch hull
- Finding CG
- 51” victory cat
- Buyer interest in MHZ Mystic 114
- KBB Keith Bradley
- Speedmaster Sport 20 hydro strut
- Anyone running F E in the Buffalo ny area?
- Has anyone used or seen this CF hull
- Plugging in lipo's into esc ?
- Sport Boaters: Choosing the Right Volt/Amp Setup for Your Speed and Runtime Desires
- Keith bradley boats
- Initial setting of strut height on a hydro
- Mystic ARTR 1140mm 44" from Germany, how good is it.
- Proboat river jet..?
- Hitec HS-5646WP Digtal servo not centering ?
- Would like to make a deal, sale hinges on Shipping.....
- abc props are now back in stock at OSE
- Name this boat contest.....Winner gets a $50 to $100 OSE gift cert
- Central RC Marine 44" Unlimited 44
- Brainstorming exercise twin motor Pursuit
- Miss Geico 29 compatability query
- placing ot water pickup and rudder placement
- Anyone ever sunk a boat and lost it?
- Installing twins where it shouldn't be done.
- Proboat shockwave vibration problem?
- Swoop
- Castle B•Link
- Floating strut bushing
- Miss geico 29 v3 query
