- 28" Rigger Build
- Hobby king genesis build, need help on parts!
- OSE 6mm Plugs - Help
- futaba question
- ProMarine MTR servo replacement suggestions
- Adding extra leads to Revo lipo's
- ESC Recommendation.
- Would anyone be interested in carbon fiber zelos motor mounts?
- Genesis upgrade to 5s
- Has anyone tried this setup?
- Paint Work? - Cincinnati area 45039
- Flex cable wear?
- Spectrum recivers 2 ch waterproof
- Cooling ?
- c.g. fightercat daytona
- How is the Patron Saint II
- TFL Pursuit
- Vietnamese Mean Machine knock offs.
- Lehner Motor Order-Anyone need anything?
- Problem with Wire drive and Thrust bearing
- T mono
- High quality self righting 25-30" options?
- Few Questions.
- Need help finding a outboard cat hull
- Speed
- New To The Hobby
- no power....
- Floatation foam test!
- Aero marine laminates?
- New boat and in need of help
- What overall length 2.5mm (.098) wire drives would you like to see?
- Q-Sport 40 Rudder Length & General Setup Info.
- Central Marine RC vs MHZ help needed with purchase please
- promarine MTR x2 (twins)
- My Proboat Blackjack 24 project progress
- Titan 40 with twin proboat outboards
- Another setback for my JAE 21FE
- First race tips.
- Mystery Claud 200a 2-6 cell
- Tweaking Miss Geico 29 v3
- Leopard 4082 mounts
- Trouble programming ESC
- changing connectors - do you just cut and solder?
- New to this.... Need some advise on a build.
- Installing the water jacket
- Fuse 160a zelos esc
- ProMarine MTR Flex shaft cable unwinding
- Need New ESC for Q-Hydro - Help & Recommendations
- Genesis single vs twin
- Collet - Are you supposed to tighten the tiny bolts circled?
- New to boats, no to RC
- Rudder Water Pickup - How to get more water flow?
- Ose and rc boaters to support Louisiana.
- Converting Nitro outboard to Electric outboard
- Electric Jet Surf Board
- What Hull is this?
- Anyone Ever Bought This?
- New site member
- Pursuit 32 Build re-build
- Genesis question
- Help me pick a boat...
- Zelos 36 prop upgrade
- Ariane 2 and carbon fiber hulls in general
- Club Membership.
- Motor upgrade
- Impulse 31 repair and questions
- New to RC boats. What's next?
- Dusting Off a Fine Design 32 w/ Graupner Z-drive
- TFL Genesis - what to reinforce
- First time trying FE
- Genesis Torque Steer
- Motor timing
- Proboat pushrod linkage - set screw size?
- With or without flex saver
- Strut for a catamaran ?
- promarine MTR x2 (twins)prop suggestions for p cat
- JAE motor height
- TFL Ariane 2
- Proboat Gelcoat Chips - Is this normal?
- Twin outboard mono bouncing problem
- What min and max diameter prop for 32'' Finch Wild Thing ?
- Prather 31 deep vee flex shaft
- water proofing a Wildcat brushless EP
- Flex shaft question
- Stability Management for Boats ?? Huh ???
- Slow top speed
- Zonda twin
- What should my Zonda be running?
- My esc is overloading with my conversion. Help me pick a new motor
- Impulse 31 running
- Hull Directory?
- Motor timing
- Need help finding a good gps?
- VS1 outboard set up
- New rescue rig!!
- Motor/ESC/Battery Combination for 46" Mono (WH Enforcer) - Thoughts???
- waterproofing receiver
- Mono Setup: Will this work?
- Universal Joint problems
- ShapeShifter Builds a Twin Outboard Skater
- Having difficultly programming swordfish 300esc with programming card
- esc and timing issues
- T-180 cutting out on 4S
- 4mm Flex Drive with 4mm Drive Shaft
- Throwing blades
- Soldering Iron
- Twin motor setup on my 46" mono - what do you think
- Looking for Mercury Outboard Decals
- Scratch built 26in hydro
- What to do when you deep six the boat?
- Wiring help BEC to RX
- Flex shaft questions for my JAE21FE
- Turtle, debris, Mechanical failure or driver error??
- Stock Pursuit with 3660 1620kv 4S = 42.4mph?
- Kintec
- How do I contact offshoreelectrics?
- esc and timing issues for twin motor Zonda
- programmingf issues with the seaking 180A on my zonda
- Whiplash motor /esc options
- more timing issues
- Cajun Commander porpoise - a way to fix?
- Motor ESC
- Big cat idea's
- Carbon Fiber
- VXP rc racing motors
- Winter Project, TFL P1 Drive-Old Dumas Mono...
- Did i burn my pursuit's motor out?
- motors and boat speed
- TFL Scaled Caudwell F1 Boat
- electric rigger.
- Wow, a vintage Aristo-Craft mono, but what is it ? .
- Traxxas M41 - Real Speed & Porpoise????
- genesis upgrade ideas?
- retrieval system
- Hi everyone !!
- proboat 26 recoil or atomic barbwire 24.
- 28" Poseidon rigger - bad choice?
- Battery Storage Bunker
- Proper "X" Demension (drive height) for TFL P1 Outdrive
- Ariane 51"
- REVIEWS? TFL Integrated Drive
- Outerlimits SV43 - Project help
- ProMarine Wrap Removal
- Strut bushing replacement ?
- 78 inch silverhook setup advice
- 2016 ose annual gifting!!! Whos in this year??!!
- hobbyking pursuit motor
- homemade prop balancer
- Forum is back up and running well. I added a Gallery tab. See the attached picture.
- Itrader installed during the upgrade.
- I would like to introduce our newest Moderator............
- Delta Force Vortex 24 Hydro Setup Help
- AB Marine Q Cat
- pursuit or revolt? different levels of pursuit ,help !!
- 70 mph saw runs promarine mtr
- 56 mph hk relentless v2
- lets talk about fiberglass or abs and why?
- promarine mtr true plimited setup 4s
- Atomic RC
- YAHOO, we just got clearance from google
- Andriod and Apple APP for Forums, pictures and more.........
- Fiberglass Scat Cat 33
- offset stuffing tube
- FYI, TP Motor news......Changes to face plate!
- 41" Zonda Carbon Fiber Catamaran New V3
- 72" mystic power
- Lipos ? 4.20 or 4.35
- Graphite
- TFL Gear Driven outboard- Quick review
- My grand daughter wants you for Christmas
- TP power 4070CM 2200KV motor
- Cleaning out stuffing tubes ?
- 90 mph promarine mtr build
- Christmas lights lets see them!
- Hyperformace outboard lower leg
- Transom doublers
- logging in
- Need some input b4 i spend the money
- New 2s-3s Rigger
- Proboat Zelos 36 or Zonda 41?
- Strut brushings
- Hi , new to boats and looking to build an MHZ Cougar wharf boat 51" ie 70" fountain
- Zelos 36 repower setup
- Hydro&Marine T4 1/10
- square drive
- Whos "Pumped" for the Jetboat from ProBoat???
- Input needed - Outerlimits 1,7m - Carbon
- Ready to buy again
- Rudder standoff, short
- Dumas Hot Shot resurrection
- First boat build - Delta Force 45 - Help much appreciated
- Whiplash 40 FE Conversions??
- Forum down time....
- lehner 2240/5 help
- Chat function Pole
- cap banks
- DF Pathfinder 28 cat
- Please share your tips on fitting a jacket
- Your recommendations for a prop please
- MHZ 1140 cat motors.
- TFL Princess Yacht
- Cleaning out ESC smoke smell from hull
- Lightest way to build a 1:8th scale hydro?
- Power advice please
- Genesis hooks a right
- Swordfish pro 300 input wire
- E51 Ebay
- Cool - Warm - Hot - Whaaaat?
- Paper thin hull
- Cutting a flex cable
- mah
- Shaft tube
- Question on TFL Pursuit motor/ESC upgrade
- "No Load" current draw?
- battery requirement for rc boat motor
- How is TP on there warrenty
- COG, vs prop angle, vs trim tabs?
- my first f/g boat
- Australian fe boat racing
- Miss Geico Battery Trays
- Motor cooler spacer
- Props for fighter cat
- Would CCTV work for model boat racing
- catamaran choices
- What did you do to your boat today?
- Getting the atomic barbwire XL to run a little bit faster
- Programing An ETTI Navy Race 150a ESC???
- Future - 88Fo water cooled speed controller
- Hobby king
- charging 10s2p
- Phil Thomas sport 45
- Lmt 2250/ 7lk
- spektrum
- Revos 70C Silver Label GOPACKS - Graphene Oxide special Edition
- esc and motor on the Zelos 36" twin catamaran
- J.A.E. .21 FE set up with Leopard 3674 2200 KV motor ?
- Motor and prop set up
- Twin sea kings in Zonda
- aeromarine apache 50 motor/ esc?
- converting vintage MRP hydro to brushless
- 49" Aeromarine twin cat
- looking for upgrade ideas for Freya Cat
- 72" Twin Electric Motor Cat Build Need Help
- twin electric rigger
- Tactic TTX300 Won't Bind??
- Who has shipped a boat to Hong Kong?
- $800 RTR...which one?
- what servo for a mini rio?
- 2S Dark Horse 27 set up help
- separate battery for RX
