- What Esc for tp 1440 kv
- Motor fading at WFO
- intro - noob with a big empty hull and a lot of ideas
- Bye bye HPR Racing ?...
- Western mass Fe boats
- we are here
- Where can I get quality aluminum rod ends?
- no driving experience, & just about begin my 7 month build's maiden voyage...
- Graupner px1
- Traxxas Villain IV questions
- Tunnel hull identification and opinions ?.
- Carbon Fiber Mono Hull
- Motor
- Corrosion X and FrogLube
- Documenting Testing notes on spreadsheet?
- Help With Water Cooling Tubing ID and OD.
- small gps for speed test
- The first ARTR Cheetah arrived at OSE today.
- What solution for brown-outs?
- Cheetah Length Measurement Observations
- Program box
- Jet Pump
- 2-lap sprints
- Buoys for RC boat racing
- Promarine?
- Annual christmas/holiday giveaway!?
- What side to mount rudder on?
- NEW OSE Raider 150 ESC's
- Aprox. how many minutes in a race?
- Delta force 33 hardware question.
- Rudder question
- proper connecting of batteries, ESC and motor
- OMG moment
- What wax for boat hull?
- Winterizing your RC boats
- Way to go Darin Jordan ...
- 6s set-up for 32'' Wildthing mono?
- Mono Strut Angle
- Jae 12 rigger
- Seaking and RPM
- Hull Recommendation
- might have a problem
- Battery size JAE 45 FE
- Boat skipping, not porposing
- Tfl Genesis 55 in Carbon fiber
- Happy Thanksgiving OSE friends
- Motor runs when I turn off TX
- big 21 whiplash
- Soldering iron and 6ga wire?
- P rigger recommendations
- Suggestions for a twin 12000w 50K RPM Motor with 400amp ESC
- Genesis torque roll issue
- Wow, just in time for Christmas ...
- Converting to FE
- hydro center of gravity
- Any F E racing in Southern Ontario 2016?
- annybody have the new surge crusher
- Prop recommendations
- Insane FE30 hardware
- Flexi drive shaft
- Merry Christmas everyone!
- R2 hobbies swifter hydro question
- TFL Rocket New Paint Graphics
- Solar Powered It planes so is it FE?
- Hydro and Marine setup
- Should I buy from nitrorcx.com
- Is this fast for 4s?
- Black pool noodles, where to get?
- Speedmaster bushing video cad demonstration.
- Using wire drives
- Single or Dual?
- Canard Hydro.
- Aquacraft vs1 use stiletto outboard
- Floodchamber - Cheetah
- Transmitter choice
- Ideas for a portable setup board?
- Hulls/Classes for RC Car/Truck Electronics
- New "Spec" Motor Option
- Jet Pump Drive Boat Build
- 2016 Racing Fleet
- advice please
- New scratch built building tool
- First rigger build, have a couple questions
- Spektrum receiver in all carbon hull? Which one?
- Key West?
- What boat for +- $900?
- Insane fe 30
- T-mono build help
- Atomic Barbwire XL 24 vs Pro Boat Shockwave, Advise Needed
- Vintage Dumas Scarb 377 Brushless conversion will this work?
- Shimming a strut?
- Recovery Rig
- sooooo.... fightercat.....
- Anyone interested in castle green 8mm connectors?
- What do they actually do ??
- Gps
- power/prop for 24" outrigger boat
- Nikko conversion projects
- ML Wildthing
- Ever cut yourself badly on a rudder?
- Lets talk brass
- Thundercat 31. Good FE build???
- AM Avenger 36 + CC 2028 too much??
- Pursuit FE leaking
- Q class current draw?
- NEW Pro Boat Zelos Twin Cat!
- STS 250 problems
- SAW in River waters... Bad idea?
- Air dam lose speed?
- Zonda 41" stock boat on two 3 s packs in series.
- First Class shipping now availible to customers outside the USA
- KEP's FE-4SL - NE-Stuff Rigger
- Spectrum AVC
- 6.5mm bullet plug ?
- new to the board skunkworks 29" GEN1 CAT set-up....
- Shockwave 36 with twin tfl-p1 drives
- Twin 60in mti need advice
- Dual brushless cat nitro mounts
- Teflon Liner with .250" flex shaft
- Lobster boat ; tab on outrigger is bent, Why?
- More props from ABC..........
- Looking for club member advice
- Just got Dunlap 27 Tunnel Hull Electric ARTR
- capsizes with full throttle and hard turn from standing still
- Twin Outrunners mounted side by side
- looking for wire diagram
- RC expo
- CASTLE 2028 in a MHZ mystic 138
- Weight of a cat
- carbon fiber radio box lid
- Reliable boat for anyone.
- Wildcat ep
- Genesis setup questions
- New drivers stand & storage facility.
- Who sells the wider re - genisis hull ?
- Change flex shaft
- Who sells water cooling hose ?
- Genesis rudder question.
- Stepped Sponsons on Hydros and Angle of Attack?
- NZ Nats
- Help with amps
- FREE Dragon F1 Tunnel Hull plans
- Some Delta Force Hulls came in today.
- Pursuit or DF Cyberstorm 33
- Q class offshore
- Steerable Direct Drives on a Cat?
- Complete newb looking for advice.
- Recommendations for Central RC Marine CRC5000 53"
- New to boats ... couple questions!
- 1/6th wood crackerbox kits finally available again
- Atomik Segad C1 34in Brushless RC Boat
- How does the oiler 'gun' look like and where to buy it?
- Impulse V2 components into a 32 rivercat ?
- flex shaft getting longer or getting shorter?
- FPV install on HK C1 Flowmaster
- f1 hornet
- should i call horizon? what can i do better? newbie
- New Zonda full CF 980mm
- Your thoughts on this boat, and this power
- To much positive thrust ... 10mph slower?
- Is this a common break?
- Installing stuffing box in J.A.E .21 FE ?
- TFL's 2016 first RC boat NEW
- Advice on setup whiplash .20
- ESC location for J.A.E. .21 FE ?
- small amount of water coming in stuffing tube normal?
- J.A.E .21 FE rear ski ?
- Helping finding flex shafts for HK C1 Flowmaster
- Un-reinforced hull failure areas
- UL-1 Guts, want to transplant to a V-Hull... any suggestions?
- flex cable; oil, grease, or what?
- Pro Boat Miss Geico Electrical Help!!
- Prather electric conversion help please
- Stinger drive placement
- Congrats to Dave Hampton owner of HRC Manufacturing
- Uk saws
- Great Opening day at the Lake. Performance Model Boat Club
- Who made this boat?
- Drive dog gap
- What motor is best for Taxxas Spartan
- How do I Remove the Impulse 31 Teflon Liner??
- Plastic Hull Repair
- Windshield Decals? Monojeff? or someone else?
- PMBC (Perfomance Model Boat Club! Not a bad place to spend a Sunday!
- Contest for $20 OSE gift Certificate
- Help with prop size
- another OSE love fest
- What motor is in this 24" hydro??
- I need an other 50" FOUNTAIN hull
- MOTHER of all FE BOATS - AMG MERCEDES BATTERY ELECTRIC RACING CIGARETTE
- Recomendations for Currently Available Blackjack 26 Drive Upgrades
- Is there a not too pricey gps you guys use ?
- Prop conversion
- Yahoo a new Traxxas to buy and modify!
- motor upgrade project for twin pirate
- Looking for parallel connectors
- Arpro boat build
- 990mm Tunnel hull electric help???
- Is there any benefit to using a tapered prop nut?
- What PROP SHOULD I START WITH ?? HELP!!
- Offshore Electrics last minute bid to make it to the Michigan cup.
- What prop size for 2 AQ 2030 powered boats?
- Deep V slow speed turning
- Bad day at the lake.
- Dynamite 2000kv vs Leopard 2000kv
- P-Limited vs P OPC Tunnel
- Any Boating Clubs in North Bay, CA?
- TFL P1 Outdrives, Anyone Running Them Yet and How do they Run??
- T-180 went poof, r.i.p rivercat?
- Spektrum rx's going for a bath
- Calling for a favor Rafael Lopez and Andy Kunz......
- Imagine my frustration!!!
- What Hull for an Aquacraft EP-1 Outboard??
- Am I missing something?!!!
- Water pickup drag testing
- Next boat please help 😁
- Potential new fins
- Newbie with tunnel hull project
- supervee 27 overhaul?
- Carrying bag, protection jacket?
- Swordfish 240 Prol 2: works but wont program with the box or computer. Help?
- Anyone with a schultz 40/160 or 40/320 that wants to sell!!
- newbie questions..before i ruin a good boat
- skeg or not to skeg strut?
- This is why I epoxy coat all my electronics.....
- Recoil 26
- OSE will be Headed to Michigan Cup for some Racing
- adding a layer to cf cheetah necessary??
- Live video streaming of Michigan Cup.
- Stolen Trailer
- Anti spark leads ?
- Thrust washers and wire drive
- TFL P1 Outdrive
- daytona 37
- MMEU Michigan Cup wrap up.
- OSE Store is now open for orders
- New TFL Integrated Drive System
- Outdrive question
- TFL 2016 New Product Release Notice
- Anyone know why most Aquacraft are unavailable until late July?
- Ms Geico v2 TP4050 mamba monster esc
- Touble binding RC boat setup
- Recoil 26
- switching to bullet connectors
- Pursuit 32 ?
- how to set up a twin genesis
- Proboat Impulse V3 or Aquacraft Revolt
- 44 to 48 inch mono
- Anodizing parts
- Prize & Raffle for 2016 US NAMBA FE Nationals
