- Water Tubing Q.
- Catamaran Water Pickup
- Rudderless twin cat
- HI everybody. New to R/c boating and OSE.
- Flexi help
- Rudder length
- Jet boat?
- Toronto Canada Area Fast Electric and rc boat group
- Is it possible to put bearing on pursuit prop shaft?
- Need to fix clear on Aquacraft Lucas Oil, is OEM paint Acrylic or Enamel?
- Another reason why all your electronics should be waterproof
- Shocker First Maiden Run -- ESC Literally BLOWS through Hull
- Insane Fe30
- 2S power?
- traxxas blast problems
- my favorite pond is full of weeds!
- Need some help
- Rescue Boats
- Want to build my first NAMBA race boat- a few questions
- Swap Shop Prices!?!?!?!?!?!?!?!?
- P-Spec Mono
- Rek flex shaft
- New Guy New Boat So Lost
- Name my project boat.
- Can anyone identify this boat?
- DF33 vs DF Cyber Storm 33
- New Here !
- Need insight on large Outer Limits build
- Need some painting advice
- Scale 50" Apache - Electric - Aeromarine
- Italian Wood kits
- Just joined the 100 mph+ club
- sport hydro recommendation
- Adventures in FE Boating (Sea Trials)
- Kbb34 repower, unbelievable!
- Help a Dummy out LOL
- Well built vs flimsy
- Rc show
- 1/6 scale crackerbox help
- Garmin 201 accuracy experiment
- Help on motor and esc choice
- 1S racing
- r2 hobbies
- Aeromarine collet style coupler. brass insert keeps breaking
- RC Racing Events Web Site
- Paint for Spartan...
- Looking for advice - Leo 2399kv and AQ 60 amp on 3s - will it work?
- Help! what is wrong with my setup???
- Woodstuff 28 cowl
- melting connectors
- Building RC Recovery Machine
- Looking for a mono 30-40"
- torque
- Help me out a little...making my own flex shafts
- so I was thinking...
- Hobbyking Flowmaster
- How to replace Pursuit 2-piece driveline
- Itching to get back into boats
- Kyosho Viper 2 Help with a new Motor and ESC set up
- Can i fix this?
- 43 inch Challenger pro advice
- How to repair CF cat hull coming apart at the seam in bow area
- Additional Water Pickup Question
- what flex or wire drive setup to use?
- Break away bolt
- Beginner in brushless
- Boat hauling Bag?
- How to: cutting, shortening, chopping rudders for more speed.
- "Easy-Move" Battery Trays - USA Availability??
- Buoy paint
- F1 Tunnel boat hooks and spins out.
- newbie looking for best info miss duce connverted electric
- H45 Thunderbolt Hydro
- 32 Bling Rocket
- no more mbp collets?????
- FPV racing
- Motley Crew or Impulse 31
- Drive dog slipping?
- Hughey or H&M flex cable, where to buy?
- In southern Germany, any ideas where to go for races here?
- Why we test
- 2-blade props for twins...?
- Impulse 31 or Blackjack 29
- Hardware suggestions for NQD arrow jet rigger
- So darn mad right now, need soldering help!
- Ose 6mm red connectors
- Help wanted
- Which drive dog should I use?
- My Rivercat sank :(
- first real boat - traxxas spartan vs hk genesis
- New DF Cyber Storm 33 need advise for hardware
- destroyed my daytona- DF Explorer??
- Blackjack 29 vs Motley Crew
- New TFL i/o drive unit
- flex shaft slips in driveshaft on a new twin genesis, reverse driveshaft?
- .062" Wire Drive
- Sad and near my house. Rule #1. It's a toy boat and not worth dying for.
- Problem with my little FT009 rc boat, please help!
- New to the "Electric Stuff"
- 36" HobbyKing Flowmaster C1 cat came today...
- Bottom comparison
- Anyone interested in a fiberglass shocker hatch?
- Flex Cable
- Alright..Who wants to build me a boat? 35-45" Mono
- Power Fluctuation Situation
- F1 options
- What to KEEP and What to SELL!!
- Twin Jet Drive Cat
- O.S. leg (vs) OSE leg
- Global Forum Users: Who Can Identify This Water Jacket?
- Apparition Cat setup and discussion
- Joysway Surge Crusher is bouncy, bouncy, bouncy.....
- Dual pickup rudder
- Upgrade flex shaft for atomic barbwire
- HOR racing
- can someone please id my rudder/strut assembly?
- The ultimate rescue boat: flip the boat around
- TFL F1 Caudwell-Available!!!
- help with explanation please
- New item TFL Outdrive and motor assembly.
- Meet the Voracity. New boat coming from Proboat. A real contender with 4082 motor!!!
- NAMBA 2015 FE Nationals
- Delta Snipper45 question
- Q Hydro (outrigger) manufacturers
- Barbwire XL
- Collet for twin cat... which one?
- experimental thoughts on a 26" shallow V
- Tunnel Hull advice
- Watercooling and flow: is there such a thing as too much flow??
- Upgrade or New Boat?
- Trim tabs and turn fins
- Set up and Rudder Length for Mean Machine/Sprint Cat 29"
- mean machine question, prop, motor setup.
- Has anyone seen this Mean Machine?
- Outboard specific shaft lube?
- MHz mystic help
- Stinger bushing failures.. Any Aquacraft guys?
- Fightercat Fantasm
- A Picture of 2015 Beijing Hobby Expo
- HobbyKing Relentless
- BBY Micro Scat Cat - How to keep it on the water?
- Outboard vs inboard turning propellers on a catamaran... What are the benefits?
- MHZ Lizard Extreme/ Delta Force/ Rio Racing - NAMBA P Mono
- Need info on Deep-V tunnel hull.
- Things I've learned about the Genesis
- 4s wild thing goes up in smoke why ?
- Help! Looking for odd size collets
- Ul-1 power for 32'' wildthing ?
- Help make sense of my collected data
- HK genesis help
- Help blueprint my sponsons
- How crazy would this be....
- Help, my boat won't stop bouncing
- UK Nationals
- motor collet worn out???
- Genesis upgrade HELP
- web-site
- Antique electric outboard Identification?
- atomik barbwire XL bottom legality for namba.
- Rudder water inlet hole on right or left?
- Something everyone here should know....
- is this clearcoat that fall of from taping the hatch? How to repair?
- Pursuit users chime in please!
- RC Boat Bitz
- Sneak Peek!
- San Diego Cup
- Joysway madflow f1 brushless
- NAMBA and IMPBA Rules question.
- Hull drains
- Dumas Deep Vee Brushless
- Just an FYI
- Help
- Arneson drive gap question
- Split seam on HK genesis
- Kinitdick Racing
- Damaged sponson tips in crash... Best way to repair it?
- Twin Pirate
- Great day at the lake ,need to figure out torque roll
- Recommendation for stable rough water boat
- Is fightercat racing still open?? I wanted a cheetah hull.
- Hull choices.... River Cat or ?
- Flex shaft between 12mm to 9mm shaft
- Soldering a flex cable
- Renegade rigger
- Gps recommendations...?
- GF is quizzing for Christmas Ideas already
- HK Princess Review
- Extended MC to 38" / 910K Beer can MTR / to much Torque - Extreme Torque 360 de help
- Flex Cable
- Bby radio box
- Zonda help
- Finding a lost boat with a Fish Finder.
- Phil Thomas P-Lmtd Turn Fin Source?
- Fly over problems
- Shark skin effect?
- two plus four equals six
- Need help to identify tunnel, nitro 3.5 K&B leg
- Graduation day
- Cracked her up good. Fixable?
- P-Limited race speeds?
- HK rigger hardware??
- VS1 prop height
- Drain plug?
- Zonda parts hrlp
- Big JAE rigger
- Water cooling question
- Nasty PM From Worlds Fastest Cheetah Guy
- HK genesis transom repair
- Need assistance on set up
- Volts -kv - and RPM
- Hydro & Marine no step 4
- looking for advie on next phyro
- Who makes connectors?
- Outboard setup
- H&M maritimo hull thoughts?
- Outboard alignment help plez
- ordering from OSE ?
- Kinda glitching ?
- 8s 1500 kv in a Genesis?
- Anyone have an etti demon rigger?
- Epoxy won't stick
- Teflon tubing yes or no?
- Mean machine
- Temp gun for boats
- Spec class boat racing
- New 48" Brushless cat from ProBoat!
- Turn fin on rigger for straight line speed?
- adding a clear window for scale look on 30"+ cat
- HK genesis more speed
- Need a new Catamaran <25"
- need advice for this type of boat plz
- Thunder Tiger Bandit OBL F1 Tunnel Hull
- Cajun rescue boat
- Crazy boat: 26" Scarab porpoising (???)
- Drive Line Lube & Removal or Not?
- Cracked carbon fiber hull
- 2.5 mm on a flex shaft
- P-Sport Hydro Width (Beam)
- Ntn-600 Modification and several questions
- Will a 4mm flex fit in a .150 collet?
- Zonda now lifting
- Genesis off set rudder
- 4mm Motor shaft to 5mm adapter??
- Genesis Set up help
- trim tabs position
- Left-right couplers
- Hk Fun Cruiser Luxury Yacht
- Race tuning question
- First run with my 6s rigger and NEU 1527
- 850mm (33.5") Carbon Fiber Mono Deep V Hull setup help
