- Roundnose hydro problems
- Best GPS speedometers?
- VS1 FE Conversion plans
- mono1 us hydro1
- Revived DPI 3.5
- Rudder set back on a mono
- Really pretty 30-40" mono/deep vee scale hull suggestions?
- Trim Tabs
- shochwave 36 nitro to elec. conversion
- Genesis cat center of gravity
- Newbie question
- Different boats for different places....
- wholts rc
- Laser Cut Tunnel Kits??????
- Soldering station.
- building reascue boat , help please
- Water Leak Help
- Pennsylvania hobby shop theft , need help
- Help needed problem with hot connectors
- Identical configuration on two different hull types...substantially different results
- Amico bullet connectors
- Gelcoat repair
- My new contraption
- 1st mono build 29 inch
- Ml boatworks tunnel kits???????
- Prather 40 setup help
- Bent speedmaster rudder bracket
- Next step for hornet.
- OSE FE outboard lower
- Can you identify this boat?
- What are the basic or best ajustments for HK Pursuit boat?
- Extended Mono Strut
- New boat options.
- Interstate batteries tunnel scheme?
- aero shark drives
- Bby electric racing hull thoughts.
- Where can I find a Gaupner GTX 800 outboard?
- Has someone already used the combo Tekin T8 / RX8 Gen2 in his boat?
- GPS Signal In Cabon Fiber Boats
- Flex cable whip at high rpm?
- Cyberstorm 32 inch question
- Anybody make a 4" rail T-Bar ?
- ML Boatworks website down for a week or more
- Stinger length for a twin Cat set up.
- Twin 42" SprintCat Questions
- CF Cloth Weight
- Has anyone used this device?
- Scotch Weld Black for Carbon?
- Twin electric SAW outrigger, looking for hull suggestions
- Tunnel Hull Setup ???
- Id like to welcome Danny, aka Diegoboy to the Super Moderator position.
- how to convert from 2 piece square flex drive to single flex drive
- How's this for a cap bank?
- Team Circus 1/10th scales on e-bay
- Who wants to build a endurance boat?
- Who makes the best flex cable?
- Trim Tabs
- Single VS Twin
- Running FE in cold weather ??
- whats a good 35 inch range fe mono hull
- Thoughts on conversion.
- FE experts Needed
- Formulating some ideas, need input
- Hi! New to Site!
- kind off new
- Water Proof
- Stinger Length
- How can I get one of these Water jackets!! We all need at least one!!
- Cap bank install tutorial
- Oh No, NOT AGAIN !!
- new hull options
- 10s twin saw outrigger forsale on ebay
- Joysway Wildcat Repower
- Sharpen sponson edges
- Phil Thomas bad hop
- Miss Budweiser FE Conversion 59.4mph 4s ** Ride Attitude Insight Needed**
- Horizon Hobbies lost a sale of 3 boats
- Wahoo, check this out ... 92" Stars + Bars cat .....
- Maiden Pursuit 32 : not good. ultra high amp draw. toasted lipos : Running too Wet?
- advantages and disadvantages of running ubec sbec
- Hull recommendation - Single or Twin Catamaran?
- mono hull options 3.5 Kw
- Turn Fin Placement on a Hydro
- New P-Limited Cat hull.....
- Old Classic Hydros 1/16 ABS round nose hydro kit
- Outboard on a Q mono, looking for advice
- Other options.
- Tower Hobbies showing the Revolt coming back spring 2015
- More boat speed
- burning money
- outerlimits high 60's setup?
- genesis vs daytona
- 28" H&M rigger help
- Octura flex hex OCFHE4MM13 wobble ?
- 38.5" delta force 45 - I I vee hull power setup.
- New to site and RC boating, Have simple question
- Cyberstorm33,Pursuit32,Pirate35
- Counter Rotation Collet?
- Hurzog Hurricane layed up by Aeromarine?
- Is the thickened 655 gflex epoxy easier for motor attachment?
- Help with beginning boater.
- Question on speed expectations.
- Mono hull center of gravity
- What other manufactuer's produce 4mm- .130'' flex hex connectors?
- Looking for a cheap boat
- Ballraced stinger
- transom trim tabs with water pickups
- flex cable?
- OS outboard leg bump in the road.
- Central marine 58 foutain
- GoPro Mount
- Merry Christmas to All
- 72" cat, thinking (12S) looking for some suggestions
- Setting up new boat
- Looking for plastic dummy 1/8scale V-8 engine for 1/8 scale crackerbox?
- 32" Pursuit upgrades vs. Hobbyking version. Kintec Racing?
- stuffing tube with or without teflon liner?
- Carbon fiber epoxy?
- Opinions on this cat
- New years resolution
- What to do??? Need help BIG TIME!
- finished paint on delta force mono
- ml boat works tunnel hulls
- How does this sound for a set up.
- Genesis 900 build
- best flex shaft lube?
- Titainium stuffing box -Thoughts
- How's this sound
- New JAE Rigger Question
- Mono hull motor mount attachment.
- KB motor mount for OS leg.
- Looking for 5 pictures, if I use them you will recieve a $25 gift cert to OSE
- building a electric boat questions
- MHZ 114 Power suggestions
- balanced motor coupler
- OSE links page update
- Cost Cuttimg Hits A New Low
- Hardener for west marine system
- MHZ cat info
- data logging
- adding weight to left sponson Hydro
- Gimme your input
- Rudder question for cat
- push button hatch locks - sealing
- To Skeg or not to Skeg,that is the question
- Advice for my sons first boat
- Circus Circus Offshore
- Need a second boat with some speed.........
- Help identify
- Need more speed from 2s mono set-up ?
- Don't run too much at half throttle???.?
- Thoughts and proposal on width of battery tray
- S power Rigger
- BEC Circuit
- Has anyone ran this hull?
- Need your help CF with scratches
- Nitro engines
- Delta Force Mini Storm
- From the Crazy File - (or is it ?) - anti-flip device
- Auto Bailer??
- What maintanace is required for a brushed outboard motor ?
- New OSE Store
- Old time stinkboater needs help
- Aeromarine Srint Cat 36"
- New OSE Store
- Different KB Leg designs.
- How do you "dial in" a 50 inch mono?
- waterproofing electronics
- Help me buy my first boat!
- 1S boat
- Pursuit from hobby king
- Delta force 35 vs pirate 35
- Aloha!
- Pursuit
- cyberstorm spinning out
- Flex shaft resistance.
- MBP Couplers in stock
- Carbon fiber or fiberglass
- Long run time drive system . Should I go oiler or Teflon ?
- Angle drive
- Kbb34 hull
- TP Power 3630 Motors
- Back in business...Finally
- Annodized aluminum and Titanium screws
- OSE flex shafts
- Modern soldering stations.
- Article: The wild weird world of carbon fiber
- BBY cutdown KB outboard
- Hobby King princess flex shaft replace parts
- aftermarket collet motor coupler that fits proboat impulse 31 v2?
- Inline STS-187 Shaft Tube Seals- Greasing
- Pop-up survey on OSE?
- Reinforcing a mono under the bow suggestions
- Help me plan my build
- Twin drive Mean Machine CAT
- West Coast Custom Boats
- Bullet Connector Ratings
- Anyone Going to the Toledo Weak Signal Show?
- tester decal maker
- Rcracing events????
- Inline vs Offset Rudder in Catamarans at High Speed
- Apparition strut adjustment?
- ESC and Motor question
- Toysport Syncron setup advice.
- Stub shaft end play ?
- maxrevolutionsrcboats.com, and FDM
- Pursuit 1 piece flex too short
- begginer build - WASABI 600 + 450
- problems using speed calculator
- Fighter cat rocket and New Mean machine single
- TFL Zonda question
- Carbon hull vs fiberglass?
- Hatch hold down screws?
- The Atomik Barbwire's big brother.......the XL
- Thank you members of offshore.
- genesis twin? Is the stock flex shaft to thin? calculate top speed
- To the administrators -HELP-
- Strut upgrade for Jae.21 fe and Matrix ultimate rigger.?
- To turn fin or Not turn fin?
- Bonnie garcia
- Blue printing a cat hull
- Does the Pursuit hull need reinforcement for 55mph?
- Sponson angle on a cat hull??
- Whats happened to Hor Racing
- Mill Timer
- stepped catamaran hull info
- Twin coolers
- water outlet and water transom
- Speed master strut install ?
- Kyosho's Hurricane 900VE is listed on TowerHobbies
- MBP Outerlimits 96 - First Look
- ose mini outboard esc
- Conley Problem Child RC Drag Boat
- You all saved my life :) DONT SWIM after your boat.
- Set up
- Flex or solid shaft
- radar
- Dumb idea? Or worth talking about?
- New paint scheme from TFL for Genesis and Pursuit
- speed master rudder
- Pursuit trim tab setting?
- Need rigger advice
- RC Boat new guy - looking for a little first boat advice.
- Swordfish 120 Question
- Teflon tubing
- Mean Machine Deck delaminating. Need Glue advice
- Steve?
- Does somebody knows if Kintec racing is still in buisness?
- Jolly sport drive
- JAE .21FE racers
