- Miss geico 24 slow and intermittant connectiviy? Help!
- Anyone know where to find graupner 40mm or KMB 40mm jet drive unit?
- How the Brass Insert in AeroMarine collet couplers goes???
- Porposing Badly on a Blackjack 29
- Front Wing in RC Boats
- Who has a Genesis and a Miss Geico 29 on hand?
- 4mm to 3mm coupler?
- Set up Ideas Welcome Big Cee Twin Shocker 88.0mph, want to get to 90mph!!!
- Revolt 30 Questions
- Lehner Motors Help
- Single stinger drive Villain IV suggestions ?
- whats a shockwave 55 worth?
- BJ 29 leaking
- South River RC Boats
- Race speeds?
- Doesn't everyone get tired of overpowering set-ups to zoom back and forth?
- Anybody use r2 hobbies boats?
- HELP with this 35" Catamaran (pro's & con's)
- 2 blade vs 3,4,5 or even 6 blade props. Advantage's vs. Dis-advantage's
- How do you determine run time in boats
- mah limits IMPBA and NAMBA?
- Hull width
- wire gauge.
- Aligator tours mini on 3s lipo?
- How to choose an ESC???
- 30c grim racer 4s packs vs 65c DINOUGY packs.
- Delta Force 35 Questions
- Whats wrong with this boaT?
- VXP ESCs
- Genesis build failing
- Cheetah help needed!!??
- Will my T120a ESC handle this set up?
- Anyone on My Garage App? Engine icon
- Old school outboard help
- How to shut off LVC on SF200 8S esc??? Help.
- MGM COMPRO ESC's
- NEEWER® Mystery 200A Cool Water Brushless ESC Speed Controller
- Waterproofing ESC- What are some methods
- Happy Birthday old friend
- Well lookie what I found.
- Speed wax?
- DHP marine esc 70a - how to calibrate throttle range
- Esc waterproofing
- What is motor shaft on ATOMIK Barbwire??
- 42" Prather brushless advice needed
- revolt prop choice and setup help
- TFL Hobbies New OPC OutDrive
- fantasm set ups?help
- 3.5 Outboard motor leg?
- Question about some setup advise for a Genisis
- 43 " Aeromarine conquest
- Just replaced the Cable Liner but have question.
- this can't be good
- Should I move my rudder forward?
- Putting hatch locks on a Genesis
- looking for .187 two piece flex shaft saver?
- FC Cheetah Fail....
- can I use 2 left turn props on a Zonda cat?
- The "Live and Learn" thread
- separate flex and prop shaft
- Wiring and connectors?
- Here's a lipo trick for you.....
- Motor getting hot after about 10 seconds of unloaded, full throttle...?
- Need help with a hull pick
- Sterndrives
- Rc jet boat custom pump
- Notorious FE'ers surface in July RC Boat Magazine
- Tenshock czII 2240
- What diameter prop for 32'' Finch wild thing mono?
- Recovering dead Optima red & yellow top batteries
- TFL Pursuit II
- TFL Hobbies.. New Boats
- Rc boating in St. Charles Missouri
- Fightercat River cat or Daytona?
- T180 Comparison
- Motor ESC combo 30" Scratch Built Cat I Want to heat race
- Setting up ProBoat ESC
- Silver Solder or Good Old 60/40 Rosin Core
- Kenetic Racing still in business???
- eastwood chemicals
- what should i put this power plant in.
- Newbe With HK Genesis Needs Opinions
- Which Rigger ?
- JAE 21 Question
- Carbon fiber layups - who does a second coat of epoxy?
- Braced or unbraced stingers
- Shockwave-M Rebuild - 26" FE
- Rio 51 Conversion
- Hardware anodizing/powdercoat/finishing options
- Who tested this P1 mono hull ??
- 1800 kv, 48mm prop, 60 a esc equals....thermal shut down
- Hydra 120
- Solder failure?
- Is there a low cost Rx / Tx that has decent range?
- Custom Painters
- Rocketcityracing pull the plug?
- motor lead soldering question
- Atomik Barbwire stock motor timing
- zonda cat stinger position. hull riding to flat.
- Need a boat built
- Want feedback on attitude.....Twin Shocker 88.0mph up to 92.2mph, Need 100mph!!!
- Help picking a cat
- looking for a pair of NEU motors for zonda catamaran. im am still looking for a 90mph
- new to fe boating..impulse 31 or black jack29
- are neu motors worth the extra cash...
- Hobby King Genesis Cat Opinions
- Looking for a paricular collet
- Electronix 101?
- What's the top speed record for a Titan 29 ???
- TFL Genesis Motor
- motor coupler
- Want a 40" class mono... need input.
- Turned my bullet plugs into a blowtorch
- Do you guys know about the build competition?
- I need a new esc !!!!
- August NAMBA SAW report :
- Sprintcat 36
- What's that NOISE????!!!!!
- shear pin on Speedmaster rudder
- Fiberglas Alternative-Maybe?
- anyone have this problem with 4050 t.p. motors
- quick cheetah question
- Whip hydroplane question
- Whiplash sport 20 Kits need built
- Help with my ESC/motor temps
- Motor size 40mm--56mm
- boat cutting out
- paint stripper
- Has anyone played with one of these hulls?
- Newbi questions
- NQD jetski brushless conversion help
- px335
- Any Labor Day Boat Sales Out there?
- what's a better hull delta force pirate 35" or delta force 35"
- R/C Hiatus...
- Carbon Fiber Popeye
- Best Cat for running fast
- Sponson booms for Climate boats Matrix ultimate ?
- Looking for motor wire plug testers
- poll...what color?
- Titan 40 Build - Trim Tabs?
- Poor waterflow on my mhz mystic
- neu motors question
- Outrigger questions
- Please take a look and give advice
- hi
- dx4s thought......
- Miss Geico 24in 72.3 mph video!!! Coming to the video section tonight!!!
- parallel connector jig
- corrosion on eagle tree elogger
- Underwater prop view in action
- Thrust bearing setup help
- Miss Elam flex shaft
- Strut adjustment gauge
- p-ltd hydro/outrigger prop recomendations.
- Usual Question...
- Which cleaning solution should use ?
- Looking for suggestions for 28MM X 45MM brushless motor for 21'' 2s sport hydro?
- anyone have a cnc mill/have access to a cnc mill.....
- Total Melt Down! Why??
- Fantasm Twin setup ? stingers, rudder, wiring etc..
- This is why we test...
- Esc motor match.
- Custom sliding strut assy....
- Blown many Rx
- castle motor cooling jacket question
- Rigging a 42" vintage hydro
- Looking for someone who likes to assemble hull/hardware
- Drilling a water jacket
- Who remembers the builder?
- What happened to OSE Forums?? Did the bottom fall out???
- Cracked hull on bj
- Blueprinting or tuning a mono hull?
- Failed speed controller on my mhz mystic?
- The way I do hatch locks, should I do a batch of them ?
- New Twin Cat Build -> Need Help
- motor esc question
- Aeromarine Sprint Cat
- Equipment Box
- Mounting holes out of spec, frustrated
- Twin Cat Build ---> Need Help!
- Suggestions for next boat?
- A future burner or speed demon?
- small leak issues
- Looking for Motor Compliance Technical Team
- miss geico/ mystic/ blackjack29?
- H&M X-ray?
- Hull strength CF vs FG
- MBP Collet Orientation against Flat Spot on Shaft
- Set Up Questions for 96.8mph Shocker
- Turn fin for 32" pursuit
- Lift from Props..... Can someone please share what that means/ looks like
- First power up after upgrading Genesis. Problem?
- how large of a hole in the transom for rudder linkage?
- Joysway Super Mono X Disappears under water......
- J.A.E .21 / UL -1 power What size prop ?
- Water entry through stuffing tubes
- Submerged drive prop?
- wiring cap bank
- Aeromarine Shadow Setups
- Need some expert help
- looking for info on rebuilding sv27 aqua craft and info on atomic whiplash
- newbie not sure to do this here?
- Saw this on Facebook...!
- FE30 build help
- Motor Simulation
- jetdrive Q & A
- how to make a cheap cap bank.....
- FE 21 rigger cuts out
- Does anyone make a 5mm to .250 coupler?
- My new EBAY boat
- Miss Hydrofoam ? anyone have one ?...
- aeromarine avenger36 questions..
- eighty something!?!
- aeromarine36 build thread?
- What temp is too high for esc and motor?
- Fightercat cheetah twin 1512's on 4s?
- Weird flex cable
- before I go run again....
- RADTEK MYSTIC 25" - Graphics???
- HELP with setup for Atomik arc 58 cat
- What type of bit to use to drill fiber glass?
- first build cf cheetah
- Anyone know about Always hobbies ? :-)
- ml boatworks gp265
- in the 90's again...but
- rigging running gear
- Custom Hardware Services
- STS-250 - Didn't stop my water issue.
- advice for lower unit purchase
- Carbon Fiber Inlay
- Water discharge issue
- Abandonded ship
- MBP collets, where to buy?
- Kintec Racing , Still in Business ??
- Why am I getting logged off so quickly??
- Important service announcement about swimming after your boat....
- Check out the Drive Unit!
- Need opinions for large project.
- Price and opinion on hull and outdrive
- Dual rudder cheetah?
- Sealant for screws through hull - rtv/silicon/threadlock?
- COG for a Fighter Cat / Cheetah please???
- internal access genesis
- New ESC new problem
- Zonda Cat (TFL) - Carbon Fibre
- Local clubs.......P limited question
- Just happened across this fleebay tunnel.
- Club points and Championships
- Brainfart @ Traxxas parts distributor ? .....
