- What are the structural limits of carbon fiber Shocker and Daytona hulls?
- Timing Suggestions for a Turning T600?
- FDM speed controls
- X01 1717 water jacet
- 5 spekky Rx's die after plasti-dipping ?
- Which Delta force for a 6cell setup
- What budget RTR boat has the most potential to grow?
- Need Help with BOAT IDENTIFICATION?....Nitro V-Hull
- Anybody try a new TP 100mm Yet?
- Tp motor sale.
- Q-Mono motor choice
- Aquastar 200 ESC
- MAS Epoxy curing times Q
- schulze 40.160 alternative?
- 3-5c break in discharge
- ESC's for 6s set up in 220amp range, what is the best for $$$, budget is $200
- electrics
- 4082 Leo in a river cat
- Threaded prop, remove dog-ears sleeve?
- Substantial range issue with my spekky system......
- Teather Boat? This is NUTS!!!
- CNC 7075 Magnalium props - what's the skinny?
- D Vs. Y wind motors... How does lower timing on D wind improve its performance?.....
- Where to find props for 3/16 shaft, but less than 38mm?
- anti-spark adapter configuration question? why doesn't this work?
- Stock versus 1mm Stroker Crank
- 1/6th mile lap times?? Where to find pls
- After Run info for a newbie
- Is it pain for the boat to jump/driving in choppy water and re enter with trottle?
- Sprint Cat 40/80 failures..?
- Rudder Length Questions.... Short or Extended from the back of the boat?
- TPpower 4060 5D technical data
- best location for lipo batteries in 41"Zonda cat?
- how can i make a crucible to solder my flexshaft?
- Exceed Formula 1 Outboard
- 2 antennas???
- Atomik Barbwire question-Electronics Question
- Outboard Cable Lube
- DF26 V-Angle
- Osborn rigged insanity
- prather lap cat II need help!
- To use the liner or not?
- SMC race formula lipos
- My water jacket slips and leaks
- Weight distribution vs. CoG
- ready to give up turning into money pit
- Looking for 6S 65C Batteries for a Twin Screw Catamaran... Any Suggestions????
- What prop for this setup on the pursuit
- beat way to waterproof a ice 240
- Hull Balance
- pushing the limits struts vs scale drives
- RC Boat magazine online featuring Bill Oxidean Team Driver interview
- Need a new hull
- Government Grant.
- P-MONO problem ?
- Whiplash 20 power questions
- Cannot tin TP Motor wires.
- Smoked it!!???
- Bonding fiberglass inlay to Spartan plastic hatch??
- motor and esc advice for this rigger
- Max length of a Q-Hydro hull ??
- Should I use a Cap Pack or not?
- ProBoat A3630-1500 Motor or Himax 1500kv 3630
- Noob question about connections...
- How far up the nose of a rivercat does a CF inlay go?
- Have you ever done something............
- leapord 2860 3400kv what esc to run 4 cell lipos?
- Color Match for Pursuit Yellow
- Mono Rudder angle and Strut adjustment question
- Hull id question
- Marine Gearbox
- Is tp 4060 2040kv ok on 6s?
- where do i get flex cable for os outdrive
- fiberglass 37 " daytona
- Schuner flex drives. Where do you find these??
- Frustrated
- HowTo: Change motor mount?
- Proboat esc up in smoke
- Paint color
- carbon fiber popeye hydro prop
- Jet Boat question
- larger Oval kitties
- RC RACING EVENTS Who know how to get in touch with him?
- SF Pro+ 220 - Slow Circles
- Aquacraft motor shaft bent
- My free replacement boat suggestions?
- Dual motor setup - wiring question?
- HELP! Can one still use that rotor?
- Hi is anyone having trouble getting a reply from OSE or is it just me?
- how much foam
- Making an outrigger boat kit available for $35 shipped, need input!
- Rudder length in relation to stinger length?
- jae21fe battery tray?
- Old style T180
- Hydra ICE 240: Current Too High?????
- Replacement O-Rings for the Aquacraft coolers
- Fri the 3th strikes again...
- genesis owners
- Alternative grease for prop shaft and cable???
- Submerged prop boat? Davette runner bottom
- Strut Bushing floating?
- Where is Your First Boat?
- Do You still have Your First Boat?
- Looking for a new 60 amp esc to buy
- Deadlines
- ESC/Prop suggestions
- revolt new motor problem
- A few new things on the horizon from Horizon ( Dynamite)
- Where to buy 1/4'' Assembled Flex RH
- Sometimes I can be such an idiot.....
- Mini mono
- Water cooling problem
- still having TX range problems
- Safe boating discussion.
- Hobby Wing coming out with new 120 & 180 amp esc's
- ml boatworks gp 265
- dual esc set up?
- Twin Cheetah motor mounts
- Connecting lipo from outside of the boat
- Dynamite .31 (5.1cc) Gas Engine with CDI - NOT FE, but pretty cool
- ESC Choice
- X447 to X442
- Oops
- Strut height Question?
- am i going to burn up with this setup?
- Scorpion 4035 800kv cooling/ timing
- pro boat black jack 29 and miss geico 29
- heat sensor
- Loctite 638
- belalady on Ebay? Anybody know them?
- need recommendations on motor,ESC, and prop size for my new build 40"x 13" mono
- Proper boat setup
- neu 1512
- Not getting enough water flow on Desperado Jr
- Intruder mk11 100mph set up.
- inbox
- Crashed UL-1 Superior
- Finger injury from prop change
- can anyone help identify this hull?
- water tension
- 1/6 cracker box
- Joysway SMX upgrades?
- ESC for Shockwave 26 V3 Brushless
- Fine design marine wrong motor help
- What's the deal with Sea Monster motors ??
- need some advice with overheating
- Mean Machine Setup
- battery terminal blocks
- 1415 rotor replacement
- best rough water catamaran hull
- "s" bend. hows it done?
- Roundy round hulls!
- tp5850 in a fantasm
- Tuning a cat for different water conditions help
- Which motor is faster
- Amps
- short rudder vs long rudder.
- fiberglass 37 " daytona running wet
- What twin setup for a small 60cm catamaran? Help!
- Hull performance: Mean Machine vs. Motley Crew
- leo 82 1600 vs leo 92 1600 whats the difference?
- Dumb question of the day - Programming reverse
- Mystery Rigger--Help Identify
- overheating .20 whiplash
- experienced builders please have a look. stuffing tube
- epoxy sealers
- How to adjust and maintaince the flex shaft on tfl smash shark?
- Rubber pushrod seal ?
- Awesome hatch retention idea....
- I may be on to something....
- Prop hub balancing
- Another Dumb question - Radios
- Best cat hull for first twin motor build
- Catamaran riding nose high and flipping
- Carbon Fiber
- New genesis build
- New CF Daytona Build.. I really need experience boaters input on this one!!!
- Replacing strut bushing?
- trim fins
- New Build
- 51" Mountain Hobbies Viper Offshore V Hull
- Everything was hot to the touch
- Trim tabs not trim fins
- suppo
- Carbon Fiber Cheetah build. Hardware?
- clear coat pealing
- Gel coat
- Aquacraft gold can o-rings
- HPR Highvoltage hull
- some gps prop testing.....
- need help choosing motors...
- waterproof ESC
- Hole in strut
- Proboat marine grease pump stopped working?
- MGM TMM28026-3 Esc???
- How mutch heat could a hull take before the glue got damaged? Used hairdryer today
- what to use to clean Brushless motors
- Flex shaft question. Building first boat
- IMPBA Question?
- Help,ready to give up on fe
- Why are RC boat rudders wedge-shaped?
- Revolt 30 water cooling question
- MGM esc what are your thoughts
- Got two loose thread that i removed from flex shaft, could i use it?
- Anyone run Aeromarine monos
- Monojeff?
- Twin Setup for a 50"" (1,30m) Mono Deep Vee hull
- Rc boat dock/driver's stand pictures/ideas...
- Behind prop water pickup 4 Q-Sport hydro Questions
- would like your opinion!
- central rc marine
- proboat stiletto motor upgrade
- voltage booster
- What to power 58" hull?
- More top speed for my Spartan!
- thrust bearing.....what's your take?
- Suitable ESC to a Leopard motor?
- Choppy vs calm
- Building a Hull with Revolt Hardware and Electronics
- Another stupid question
- 80+ mph 32" rivercat
- pursuit runtime
- 1730kv vs 2040kv
- 58" King of shaves
- Capacitor...Replacement what size and type?
- Getting back into boating.
- ESC troubles
- Who's selling 200+ amp speed controller
- 30mm bolt spacing watercooled mount?
- Whats going on with Kintec Racing
- Were can i get billet hardware from?
- motor shafts ?
- HELP I need an ESC
- Happy Birthday to Mr. OSE----Steven Vaccaro!
- HK Genesis setup
- Need an 8S-10S ESC that is in the $100-$250 range.... Any Suggestions?
- Need help to secure 4s 6000mha dinogy batteries.
- Emcotec Safety Power Switch, thoughts and/or reviews
- miss circus circus
- Pretty much done with HobbyKing, Do not buy their AM-1005 5.5s or the XT150's
- Cooling Plate on a SF Pro 220
- My new acquisition, another Villain IV to build ...
- swordfish220 race mode
- trying to pick a big motor...help
- props with more pitch
- Vinyl wraps for Daytona
- Wanted: Outboard mount
- Why is my 2 piece flex shaft so loose?
