View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Anybody dealt with Rocketcityracing.com
  2. Need help with FC Cheetah handling issue!!!
  3. has anyone compared the himax 1500 to the pb 1500?
  4. octura coupler 6mm to 250 flex help
  5. Rumrunners suspended ?. Not surprised ....
  6. mystery 100 amp water cooled esc
  7. Rudder cooling inlet wrong side?
  8. Torque roll
  9. Motor esc issue/questions PLEASE Help!
  10. high amp. data logger?
  11. Turn fins
  12. Repair Help
  13. GP335V2 20 SPORTS Hydro
  14. electronic options for atomic arc hull 58in
  15. Lipo warning to all
  16. Bouyies - what to use
  17. "World Championship"
  18. New here does anyone know and good ways to convert the miss bud to brushless?
  19. My TFL Fleet.....
  20. Prop depth for a 50" mono
  21. ESC Suggestions please
  22. brass tube for 1/4 flex help
  23. Hit a buoy and split the hull apart
  24. aeromarine cat good ? bad?
  25. air dam???
  26. Is this delamination?
  27. TP-Power 4050 3Y 2220kv
  28. pros/con's & opinions on Pro-Boat Volere (Chris-craft barrel back)
  29. News from the "Winter Warm-ups"?
  30. will it hurt running a unfinished prop for testing
  31. S-Bend in stuffing tube
  32. Need advice on new hardware
  33. atomik whiplash flex
  34. Mini lathe,cleaning?
  35. Suggestions on Secondary water pick up on a hydro
  36. dual pickup rudder for a pursuit
  37. whats a good hull for fast straight line speed?
  38. Whats the "speed of distruction"?
  39. what do you think?
  40. Power Options for some new Hulls I just pick up ? please help guys : )
  41. Gps
  42. Looking for Skeg Struts
  43. Magnet let loose on brushless rotor.
  44. rum runner
  45. Power supply?
  46. Gas to Electric conversion Nitro Vee
  47. 4082-or4074
  48. HOR Racing ^%#*x!
  49. Basic cooling setup information
  50. Programming help
  51. Duel rudder setup on 50" mono advice needed!
  52. Upgrading a snap p1 720ep
  53. What Brand?
  54. HOR Racing. STAY AWAY!!!!!!!!!!!!!!!!!!!!
  55. need cheetah help.....keeps spinning around
  56. ball bearing strut?
  57. Rigger Help
  58. Looking to build my first real fast electric and need advice on hulls
  59. expanding foam
  60. Have 2 hulls, Which to use :S
  61. ML Boatworks possible logo change...I need your opinions, or ideas
  62. Brushed symptoms
  63. Looking for stronger u-joints........
  64. Prop, Strut, & Coupler question
  65. Anybody have this issue before?
  66. battery trays or no battery trays???
  67. 1/4" stuffing tube and Speedmaster sport 20 strut
  68. Making your own stickers / Decals ????
  69. Limiting speed factor
  70. 4065 1800kv
  71. How to video your own action movies
  72. 26" Rocket - prop question from a norwegian newbie
  73. 21 whip first run
  74. Corrosion X on speed control
  75. Zonda Cat help water cooling???
  76. What BEC to use?
  77. Removable stuffing tube?
  78. thrust bearing ?
  79. New to RC Boats
  80. Gas guy thinking green
  81. .187 flex to 3/16 stub assembly
  82. Problems with MGM 25035
  83. Man O man....... Connector debate
  84. Strut help
  85. Jam Nut and Bullet vs Nylock Style Prop Nuts
  86. For Twin ESC/Motor setups, Strap batteries in parallel or keep separate?
  87. Custom hatches / Bubble canopies
  88. Team believer
  89. took my Villain X out for a shakedown / maiden run today
  90. hydro rudder positioning
  91. hydro rudder positioning
  92. fiberglass 37 " daytona
  93. High RPM driveline setup
  94. Who has a pond/Lake behind their house in a neighborhood and runs their boat in it?
  95. genesis/daytona stingers that work..
  96. Dick Tyndal Contact Info
  97. prather ss props
  98. dumb question 1527 jacket on a 1521
  99. Rudder Bushings
  100. Is this over kill ?
  101. Tunnel Handling Question (video included!)
  102. Traxxas Blast brushless
  103. FE Lobster boats, anyone else have one?
  104. drying out? :-)
  105. Man o man, what a travesty .....
  106. ML Boatworks GP400 battery recommendations
  107. Mhz USA problems
  108. Hansen Racing
  109. Can I run it or should I wait?
  110. Cars or boats
  111. Genesis twin set up hull where to buy???
  112. Question regarding AquaCraft ESC ( 60 amp )
  113. Gopro on blackjack 29
  114. New Fightercat 240 ESC only 50% power?
  115. Maiden voyage.... Check this out!
  116. Kintec
  117. King of shaves motor mounts
  118. TP Power USA
  119. TFL Daytona/Genesis SAW setup
  120. schulze programming 105wo
  121. Flex shaft thought
  122. JAE Mini Sprint Outrigger
  123. Flex cable to stuffing tube clearance....I'm confused
  124. Interesting Mono Hull on E-Bay - R-Hobbies??
  125. Looking for another hull
  126. GR 40x57/3 Graupner Equivalent
  127. 100 amp ESC with instant reverse
  128. Advice for a DF26 sport setup
  129. I'm new to site.
  130. New cooling gimmics
  131. Method for calculating battery capacity???
  132. ESC Problem (Need help)
  133. best thing to use to add water cooling to a speedcontrol
  134. Calibrating Trim
  135. MTI Catamaran
  136. HYDROLIFT 1900 VS Central RC Marine 72" Mystic
  137. Genesis component selection?
  138. Insane FE30, Thoughts of buying..
  139. Complete NEWB with question on battery palcement and prop selectio
  140. AQ 1800kv motor question
  141. How much salt............
  142. Cannot get ESC to work
  143. P spec cracker box?
  144. Shorten 2028 wires
  145. Twin props. Inboard or outboard?
  146. Am I evil for liking the new RTR boats?
  147. maiden voyage = destruction need help
  148. ESC Question: Setting Maximum RPM...(MGM Controler) Advantage or not?
  149. Zonda or Genesis
  150. Small Eco boat from HK
  151. Trim tab length on Prince mono (DF 26)
  152. one or two batteries
  153. MRP Miss Bud MSC wiring? Not getting high speed from switch
  154. VXP High Power & Voltage ESC
  155. how many caps?
  156. central rc 51 victory
  157. Can a 25in long LSH/Spec hydro be competitive now days
  158. Research Project!
  159. how much?
  160. Pro Boat 1/12 Miss Elam
  161. PRE-Waterproofed ESC options?
  162. How Can I?
  163. COG Help
  164. Looking for 4mm x .062 coupler
  165. OSE closed for vacation
  166. Phil Thomas New Hull.
  167. Pt stealth 30
  168. carbon fiber builders
  169. What should i spend my $$ on :)
  170. Any luck with the orange Rx & module, or the corona system ?.
  171. Cooling water not flowing?
  172. joysway cat questions
  173. 5.5mm Contacts vs. 6.5mm Castle Creations Contacts? Anyone have a compare picture?
  174. Finding a balance point & balancing a boat .....
  175. Motor upgrade for an Apparition?
  176. Alien speedo
  177. Need help on wiring the spart arrester on a MGM controller!
  178. Hydro's SAW capibility?
  179. Drag'n Fly 20 Mark II
  180. DF Hatch tops, Where help!
  181. 40,000 rpm........what's the problem
  182. The search for leaks..
  183. Mhz scorpion 5035 water cooled version
  184. Help me choose motor/esc for this boat
  185. CAtST iiwant to build of purcase a very competable cat, and one got iders please
  186. Current draw for Feigo 7XL?
  187. RC Boat Bitz....
  188. Large (ish) MTB motor, prop and battery advice
  189. Stuffing tubes - water cooled and oiler 6S Hydro, overkill?
  190. Graupner Challenger Boat
  191. WaterProof Rx Box WON'T FIT..Any tips??? REVOLT 30/Traxxas box
  192. esc set up
  193. Question about building 36" Cat
  194. cheetah...needs a long rudder
  195. Bare hull prep questions?
  196. First Villian iv
  197. Garmin e-trec
  198. NAMBA Fe Nationals help
  199. FE Evolution
  200. How would you do it?
  201. HPR powerboats!!
  202. strut/rudder for mg 29
  203. Flex shaft shortening
  204. New to RC Boats
  205. Upgrade 7S to NEU power?
  206. Mean Machine Reliable vs Top Speed
  207. Motor Size for JAE FE Q class Rigger
  208. N2 Sport Hydro for the Nats. Spill the beans.
  209. Trim tabs installation
  210. Need some help on finding a relatively cheep esc for my q-sport build.
  211. flex shaft problem
  212. looking for vinyl cutter suggestions
  213. Villain ex questions
  214. Battery tray how to
  215. 2 hardcase packs swelled on me today
  216. Need help programming my aquarcraft 60 esc
  217. Kyosho --- Anyone running these?
  218. daytona
  219. Soldering 5mm bullets?!
  220. Mhz Lizard build 2014
  221. 1717 vs 1527
  222. P-Ltd Cat flips over in turns
  223. clear coat, how much is enough?
  224. Prop sharp and balancing services
  225. ESC for TP4060 1870kv, 6s & 48mm prop in mono hull?
  226. smoke
  227. Things aren't good at Hor racing, read if you have an order pending!
  228. Anyone having trouble uploading / sharing video via photobucket ?
  229. another OSE endrosement
  230. New product: Rustoleum flexi-dip
  231. What to build for my first boat?
  232. Does Waxing a boat hull increase speed?
  233. best way to darken epoxy?
  234. powering a DF 45 sniper mono ?
  235. Dumas Skater Brushless setup
  236. How do these two ESC's compare?
  237. TFL Pirsuit Strut Acts Like a Water Pump
  238. 45" ish mono
  239. 10WAG wires on ESC. Do I need bigger wires on the motor??
  240. The sound...
  241. Fightercat fantasm out of stock...returning when??
  242. Bad ESC?
  243. Sea Phantom - Interesting Article/Video
  244. Regular V vs. Step V
  245. Has anyone used these batteries?
  246. New miss geico
  247. daytona run time
  248. Added turn fins now have problems . HELP
  249. Rudder set-up Question
  250. Prop shaft tube installation?
