- TX with the best range???
- Repowering an old tunnel
- Has anyone tried the Fly Sky FS-iT4 4 Channel 2.4ghz
- Stinger Placement in a Mono
- boat not moving
- H&M Sporty
- Water Coming in thru stuffing tube
- Recommendations for My first Rc Boat. Geico or impulse V2 or ???
- Kevlar inlay VS glassed-in wood stringers
- who was it selling bullet sleeves ?
- Aquacraft Ul1 2030kv motor
- Outer Limits Drive coupling ???
- Programing dual ESC's
- Nubie says hello
- Atomik any good?
- bullet connectors
- 150 hk esc
- Fast Electric Questions
- caps
- 775 motor mount questions
- Whats in this picture?
- Can someone tell me how my boat runs by this graph
- 48 inch custom center console build question.
- Converting a nitro cat to electric
- Somewhat new to FE... Motor, ESC, Battery & Boat Setup Advice
- Mean Machine new build help please
- Need help finding a motor mount
- New Vortex 34 (33.75") by delta force coming
- Has anyone seen, bought or know of these????
- Suggestions on Possible Build
- Need a little advice (speed controllers)
- whip sport 20 or the whip sport 40, which to buy!
- FE sport hydro cowl locks?
- More thought into Hull/Power
- Pictures of Pop Eye transom and location of motor mount
- 29" Cat motor/esc suggestions
- 1/4 scale cracker box
- canard giros
- My Chicago winter project
- Upgrade a shockwave brushed
- best deal on a 180a esv
- blackjack 29 / miss geico question
- Carbon fiber hulls, paint?
- Inrunner, outrunner, whats the dif?
- No BEC at 6s or more?
- Blazer Sport 40 or ML Boatworks SX-400
- Bending a short stuffing tube?
- Hydromarine XRay Low-Profile
- Intro and seeking input
- Cuttin down a flexshaft?
- new to this
- can i make my miss gieco 24 faster with out going brushless
- I need help to choose motor' s kV
- Good resin/epoxy to glue carbon to plastic?
- Hull Type for P Sport Hydro Class..Namba requirements
- ProBoat 1/12 Miss Elam
- Virgina Craftsman?
- deans conectors
- Motor suggestions for CF Cheetah
- Hydros?
- carbon reinforcing?
- Unbelievably easy way to slide the Aquacraft cooling jacket on the motor
- why am i melting 10g wire
- does hobby king make a good upgrade motor for pursuit
- Turn fins???
- Whats hot and what is not? ESC,motor,lipos
- newbie prop question
- New connector for 4-40 push rod.
- new dual outlet - "target sight"
- R2hobbies silverfox 36 catamaran Single set up.
- Need help with motor, ESC selection
- corner markers
- Different wind motors mean what???
- jet chopper 30.
- What diameter prop for 2s sport hydro?
- Replace BEC with?
- russian mono on Guam
- Hard time finding lipos?
- Would there be any interest?
- What kind of wood kits would OSE members be interested in seeing???
- plans for PVC stand?
- lucas oil catamaran
- Orange anodized aluminum outboard mount
- Etti Exiga
- Fiberglass resin?
- # of Batteries Required
- 8mm connectors vs. 6.5mm connectors
- planner boards
- im.sorry
- posting videos
- Cheap and easy to get pushrods
- twin
- Titan 40
- Should I offset my rudder?
- 100 MPH Traxxas Villain?
- Need help with my HPR setup
- Question about off center strut location and the benefit
- Xzess Mr.Crabs motor mount.
- Merry Christmas..........
- What boat next?
- how to program hydra 240 hv from 4s to 5s??
- Tunnel VS Cat setup?
- Trying to find....
- 45 inch mono setup
- having trouble programming t180aesc
- A question for the Tunnel hull guys out there
- How remove wood radiobox from hull
- 4PK-SR Dual esc programming
- Differences with different cell count, same rpm
- Best material for ride pad on 1/8 hydro?
- Race Timing System
- Aeromarine Laminates hulls
- Looking for rc boat builder in md
- Now the Ariane needs a ESC, help?
- CoG for Tunnel Hull?
- Mystic 45 vs 33?
- paint question
- saw hydro
- Happy new years
- Mean Machine Rudder Location Advice
- 1527 Neu quest
- Scorpion Inrunner's?
- Brand new to boats, have a few questions about getting started right
- Harbor Freight Neptune Boat Questions
- Where can I learn about added caps for my ESC?
- Question about repainting the hull
- Any difference between the Blackjack26 and the Miss Geico 1500kv motors?
- How to remove paint?
- stuffing tube question
- Prop Differences.
- 4" rail mount?
- Getting into racing question - Space Coast (Melbourne, FL)
- Cooling Sleve Required?
- Gps questions
- Sponson angle
- OCTURA Expensive Collet w brass insert Questions
- Turn Fin
- Anyone else ever have this happen ?
- PB Impulse 31 v2 Racing setup
- Latest NEU Motors
- The question is : What have I learned about Aeronmarine hulls ?
- Powerplant Question
- epoxy fiber glass hull finishing putty
- Lehner Hi-Amp vs LK
- Super Daytona owners?
- Traxxas nitro boat question
- Public Service Announcement - HRC Water Jackets for TP Motors
- Is there a correct way to fit a water jacket?
- Help me decide my next cat
- titan 33 hardware
- impulse 31 prop question
- My Smash Shark built up for 4S racing!!!!!!!
- What to seal bare wood transom with?
- CorrosionX Uses and Benefits?
- would a 1700- 1800kv motor be a good choice for a 32 inch v hull
- How did you come up with your user name????
- Who makes a glass whip hatch
- Quick and easy Turn Fin cover?
- Run time difference 1400kv vs 1500kv
- Motor setup on 41" Fantasm
- What does everyone think of the Kintec Racing Mean Machines
- short flex cable filling hull with water
- What can I do to make my boat turn better?
- Square drives
- AQ gold cooler O rings?
- Timimg for my Neu 1527 1.5D, Hydra 240
- OSE 80915 lower unit?
- Now I need a Hydro
- Turn Fins. Rectangle or curved is there a difference in handling ??
- Graupner speed 480 bb ?
- R2 hobbies 36'' Silverfox catamaran
- DIY Hydrographics?
- Best epoxy
- sf300 pro plus issue
- Flooded tube question?
- hobby king suporrt sucks
- From square drive to single flex?
- Where to set center of gravity?
- Help with electric cat
- Help with prop selection
- FPV Boat Racing?
- What do you think?
- Flexshaft size for 1/16th hydro
- Twin electric motor control - how?
- What Deep Vee Hull for this Setup?
- Stuffing tube diameter?
- How are you guys holding your hatches down?
- how does a 1717 compare to...
- So what did you get in the mail today???????
- ESC / MAH and Ripple Current. Experts weigh in please.
- Electric conversion
- Tights on the genesis
- Laminating wood and foam
- Is this a problem?
- is it necassary to water cool an outrunner?
- 110 pages, my head is smoking, thank you!
- MHZ USA shipping?
- 1st boat build, 57" Thundercat Expresscraft Catamaran. Need help & suggestions.
- Zonda cat kinetic racing throttle issue?
- Stinger setup
- Blackjack 26 vs miss geico
- 1/8 Rc car speedo for P tunnel?
- Pat at RC Lipos is in the Hospital
- H&M Drifter S ( P-Limited )
- A Gorgeous "Sport Hydro"
- GP335V2 20 SPORTS Hydro
- PB 1/8 hydro flex size?
- Help removing motor mount
- Site maintance and changes. Import note about gallery
- width of a 1527???
- Few questions about ESC and batteries
- Silent Engines - Anita Michaud
- Pursuit 32 4074 1400kv set up questions..
- Thinking about getting a Revolt 30
- Healp needed, looking for a picture of a black and white hpr 115
- Choosing Motors
- Question on adding mah capacity by adding batteries
- AeroMarine Avenger 36 twin strut
- 65 expresscraft gtx
- Gas engine ?
- New Catle 1515 Smooth can
- New Orleans FE boat / prop shop?
- Opinions on strongest mtr-flex coupling?
- wher to get bulk .187" r and L hand flex?
- Drag Racing
- Mono rudder length?
- max amps verses min amps on esc
- Prop shaft thread pitch and shaft diameter
- Shopping around for velcro strapes
- Aluminum 1/4 scale hulls
- 90 degree bullet connectors
- HOR Racing
- BEC wiring ?
- balanced motor coupler
- battery and esc wires
- flex drive HELP!
- Help me choose ESC
- Help Identifying This Boat
- Are you joking?
- An entry level Tunnel?
- info needed on a neu 1518 1.5d amp draw and timing in a jae21fe
- fastelectrics.net changed address
- 42" Hull, Lehner 19or22 series..
- RC Marine, Korea ??
- New Cat?
- Lucas Oil Cat
- Mickiebeez Jetsprints Decals?
