- motor shaft / collet-coupler off center
- trim tabs for traxxas spartan
- 110mm Stinger Setup Help
- Timing timing omg
- My DF33
- esc capacitor
- Strut height effect
- finding cg how to?
- Hydro and marine viper
- Fightercat 3730 motor setup question
- TP power motors now available
- Hello! And Guidance...
- Prop help
- Expanding foam question
- TP Power TP4050 5D Pro 2600 Kv 4-pole on 6S
- Is that biig motor (on 3S) suitable for scale boat?
- MHZ mystic C5000 44"
- Can you spray poly clear over new OSE decals?
- P-Spec Hydro ESC recommendations?
- vintage wildcat brushless setup
- Water pickup questions...
- Build advice for a rookie
- Cool Boat Names and Themes!!! Let's See Them!!!
- Another question on Pool Noodle --- inside INSANE 34 MONO
- Fightercat Daytona question
- Need opinion on possible trades.
- Rescue boats and trailer's
- Mini mono motor?
- brass tube for 3/16 shaft?
- Shockwave 26 V3 for the grandson
- ESC Ferite Ring Placement
- got a mark in the glasfiber hull, just paint over or use a type of epoxy?
- What is the best gps to get to test speed
- Super Daytona motor pick!
- Frazzo420 Pursuit Build
- Shipping from OSE to Florida... UPS or USPS??
- ESC Guidance Needed
- Upgraded spartan need help. In laws issues
- SF fets?
- neu 1527
- hardware for daytona/genesis
- cheetah rudder placmet, single drive
- Hatch tape?
- Questions on twin prop rotations
- Water line choice
- Fly Sky FS-GT3C
- Where to get hatch and other detail type decals from??
- Can you guys help me match my colors for the wires on my ESC?
- Should I solder the end of the flex?
- Filling a cup in ride pad....?
- Why use a shaft saver?
- new to boat building
- NeverWet for ESC's?
- Diagnosis: motor murder
- Fightercat Daytona tuning and setup, CG, etc. help!
- Build adhesives?
- Running issue fast for 4 laps, slow for one, then fast again
- 380 bl motors
- Where to begin
- Motor timing for 1600 kv Leo 4082/ Sea King 180
- Traxxas Velineon twin esc setup help
- building cyberstorm 33?
- 70mph Rigger - Winter Build.
- Want to get a hatch for fantasim
- Rules thoughts
- Stingers for 41" Sprint Cat, Buy or fabricate?
- I have a few questions
- The way of water.
- 1st boat-Revolt 30 or Impulse 31?
- Hornet on-board...
- Dumas 1234 1940 Barrel Back 28.5" brushless upgrade?
- 6s apparition cat running really slow
- Sirius 1518 bearings
- Help choosing hardware and electrics for 50" Expresscraft Thunderbolt cat
- new to the sport, help me please,
- 6cell or 8 cell with my set up
- Voltmeters and batteries
- Best Prop
- Traxxas Spartan Fiberglass Hull
- Need help picking a hull
- 54in cat twin 56mm
- stinger
- Heat shrink size for lipos?
- IM31 strut or MG29 strut?
- mean machine 2, please help
- Why did this happen? MG29 + SK180 blow up w/ pic!
- cooling idea for a fightercat motor in a Genesis...
- Understanding batteries? Newbie Question
- Whistling ESC
- Adding watercooling to a brushed 50A ESC - Need help pls
- Help with speed control sizing for MG29 and apparition both to be on 6S
- Who makes the Hor Racing line of motors?
- reverse
- Aeromarine Titan 29
- miss geico 24"
- Neu 1515 1y (2200kv) on 5s
- Proboat ESC brushed
- Tfl genesis stock model? Any heat problems on 4s?
- HPR up and running
- Impulse 31 Setup advice
- The know it all...
- how much pool noodle is enough
- Miss Geico 24 - Rudder Mod (Offset?!)
- stuckt in a rope today with the boat, could it take damage?
- UL-1 Hull Question.
- Want input from everyone for question
- Maidened my Daytona today- some setup tips appreciated.
- Removing paint from epoxy glass cowls ?
- 43" brushless jae rigger
- Revolt 30 Mods
- can you run 2p using different C ratings?
- Mounting 4082/4092
- kv help
- Oil can for your boat!
- 42" aeromarine sprint cat single setup
- Cap banks
- Hello, hello and hello.
- 41" cat build... big single, or twins?
- Just saw this from Kyosho , couldn't resist posting here
- Team believer prop help
- What batteries for 4802 1250 kv Leopard 37: Daytona
- Any experience w/ Easyrun's 1/8 scale 2350kv motor...... ?
- Looking for input
- UL-1 Aquacraft motor bearing replacement parts
- How do I try to settle my boat down when running wide open
- Smash shark
- Can't get MHZ drives to fit prop shafts, what do i need?
- Mini Zonda & Rocket Upgrade
- This time the camera STAYED ON-board...
- Need help picking paint
- Best Prop for Revolt 30?
- Pro Boat Impulse 31 V2 or Aquacraft Revolt 30?
- thunder tiger outlaw jr
- 37" Fightercat Daytona Dual pickup rudder help
- Time to replace the strut?
- Found a custom KOS 34" on ebay. is it worth it?
- Jeff Wholt
- Thought I would share something Funny about forum registrations
- Conversion
- turnfin
- Kyosho jetstream 888ve, anyone have tryed that boat?
- looking for a 50" or so deep V mono hull
- Systems Sponson Mod
- Question on CG for Whip
- Hull choice HELP
- Flex shaft broken and stuck in tube
- drone mystic anyone?
- Question for non racers only
- Is a carbon fiber battery tray really a good idea?
- Programming 180sea king esc
- Genises boat what size prop
- aquastar esc 120 programming help
- TP 4050 4040 timing?
- Hydro Marine Agitator 6s
- What to build?
- Any interest? Hatch tape peeling paint I have the solution.....
- Frog tape for hatches ?
- please help me identify this hull
- Anybody ever done a twin "p spec" rigger?
- Pursuit testing with a 4074 1800kv 180a ecs x447/3 on 6s ?
- solinger hardware
- Brass water Fitting
- Looking for rigger plans
- Looking into Watt/KV meters
- Transom water pickup location.
- Sprint Cat 40 to brushless
- Octura Collet 5mm x .078
- which motor configuration?????
- External h2o pump to improve cooling.........
- aeromarine rc
- Newbie Prop Question
- OSE Products site upgrades??
- Rescue my sunken boat idea?
- Jae 21fe
- Ep gas rigger,say yes or no?
- T120 in a 36" cat
- Hardware advise for Delta Force 750.
- Help needed for NEWBIE!
- CF Daytona Worth
- Events?
- Thunder tiger outlaw 30 obl
- Twin Setup Cat H&M Maritmo
- 43" aeromarine conquest cat
- Motor ESC bullet Connector Hot
- ESC question
- Fantasm what is it close to in Full Scale?
- Help needed about thunder tiger outlaw obl
- Upgraded prop-Revolt tougher to control
- Setup question
- hull sanding
- Impulse 31 help
- FC300A ESC Parts Information Wanted
- what outrunners to choose for the 50" thunderbolt?
- Hughey flexcables
- Bondo for Hulls
- Soldering station reccomendation?
- What hardware is on this HPR?
- The best way for boat retreival
- Fed up with RTR boats...
- Cheetah strut and balance
- Mean Machine battery placement
- Carbon fiber cloth... Where do you guys get it?
- Proboat Impulse 31 V2 Vs. large fish.......
- Flex Shaft Question
- VIDEO: $50 Rc Boat FT007 Man is this thing GREAT!
- looking for a new boat...
- Extruded aluminum blank for strut????
- Hhhhhmmmmm, anybody seen a ducted fan hydro ?.....
- Found KOS c1 package on ebay
- new to electric boats
- where to buy carbon fiber cloth and resin
- how to mount a screw in the glasfiberhull when the threads is broken?
- Not stock revolt 30 build
- What there a 2013 horsecrap batch of flex drives or something?!!!!
- 5s on AQ 2030 motor?
- Motor mount glue/epoxy
- DX3S range issue's. Should I go with the DX4 or a different route?
- Hobbywing motors
- What are normal temps for boat motors and esc
- Cat for Twin Aquacraft 60-A 1800-Kv Power?
- motor sizing
- the difference between two boats
- Motley Crew
- Kyosho Hydrojet GP
- Shockwave 26 prop question
- Have electrics, need hull, advice please...
- Aquacraft 60A esc issues.
- CG Question
- spark
- continue with rc boat hobby? or quit? need help!
- New boat thoughts?
- Sizing of rudders and turn fins
- NAMBA District 9 - Northern CA & Nevada
- ML Boatworks SX400
- Pressurized hull challenge
- Bearing lube?
- Ultra ever dry
- Best "fun" hull?
- NAMBA district 9 candidate for director
- What type of retainer glue for piano wire to prop shaft
- click drive in USA?
- Boat Plans
- Aquacraft 2030 or 1800
- will a schulze future esc work with a pb1800
- Question for Waveblasters of Florida
- Kroker Sea Wasp 6V spares
- Dual motors & esc's
- Help with esc purchase
- Who does CF inlays?
- Cool Painting options PLasti-Dip
