View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Mono Rudder
  2. How to break in motor/batteries??
  3. need help want to go with cat for speed any help?
  4. What a good motor boat pursuit?
  5. New Guy.. Help ..How to install water jacket??
  6. Dusted off the boats, need motor suggestion!
  7. What exactly does "spec motor" mean?
  8. Neu 1521 1.5d Timming
  9. ESC motor timing
  10. Pursuit Stinger Screw Size
  11. I am looking for a good setup Deltaforce 33 " cyberstorm.
  12. 36" tunnel motor prop suggestions
  13. 226 Racers / 724 Boats
  14. weak signal
  15. Geared boats and why? please respond want to know a little kite about why they useit
  16. New to the OSE Forums...Saying hello!
  17. Has anyone ever hydrodipped their boat?
  18. Rudder selection and why?
  19. What's this??
  20. UL-1 hardware on fe30 or whiplash
  21. Basic Fe rigger questions
  22. Well, that was a quick $170...
  23. New to boats. What should I start out with for around $200?
  24. Issue with water pick up from rudder
  25. 3674 2200kv motor wire hot. help
  26. new to the game!
  27. newbie questions
  28. stuffing tube EXPLOSION
  29. P-Sport Hydro Setup
  30. Newbie help with HK OSE strut upgrade
  31. Need 50" props for my twin, but from where?
  32. Mystic 114cm Home build Setup
  33. OSE Job opportunity
  34. Laying fiberglass cloth
  35. Problems with Feigo 7xl ?
  36. Mean machine v3 or fightercat cheetah?
  37. size matters
  38. Proteus Motors?
  39. Anybody know where to buy BK parts?
  40. Prop Advice
  41. 25" abs hydro motor suggestions?
  42. RC boating newbie
  43. 5mm Collet on a 0.187 flex shaft?
  44. Seeking Advice for Lipo ESC and Brushed Motor Setup
  45. Tunnel Hull Rookie Question ...
  46. R Hobbies Boat hulls?
  47. 4082 on 6-s
  48. escs catching fire
  49. Fast Electrics
  50. Zonda cat prop change
  51. strut adjustment question..
  52. Trakpower TK 950?
  53. Proboat....
  54. What sould the rtr weight of a P-ltd sport hydro be?
  55. Hydra 120 Bec?
  56. Silicone tubing question
  57. Props for my Genesis to go 100 kmh+
  58. P-Spec Hydra 120 Timing?
  59. ESC cap question
  60. Insane mono cg
  61. Looking for small GPS
  62. Props for genesis with 1515 1y
  63. 50inch apache
  64. Upgrading a kyosho boat. Need advise. pic's in tread
  65. Any one know where to get 3/16 teflon washers USA?
  66. How to add second water intake on tunnel hull?
  67. Minimono Driveline Fix
  68. PRATHER LAP CAT 32'' Racing Tunnel Hull and Outboard Motor Mount
  69. Extra cap pack
  70. help newby
  71. cc 240 esc
  72. warm motor leads
  73. 1527 1y on12s?
  74. How to find the center of gravity
  75. Help me to choose a motor for this hull
  76. Long Beach California RC Expo
  77. About marine receivers
  78. Cleaning bullets
  79. Auqacraft UL-1 prop?
  80. Submerged miss geico
  81. Zonda carbon fiber n keclar question
  82. Budwiser/Trailblazer Select
  83. ? on cutting my 3/16 OSE flex shaft...
  84. DF 22 Vortex strut adjustment
  85. Prop advise
  86. question about building a drive for a micro rigger
  87. mhz mystic114 mdp clicker drive stingers question
  88. What size prop for JAE .21 FE 3674 1900 kv ?
  89. Has anyone bought a OSE strut that looks like this?
  90. Revolt flex shaft problem
  91. How to fix cracked gelcoat
  92. Help with mean machine setup please
  93. Which bushing is better in a Drive Strut: Brass or Teflon?
  94. New to boats, looking for a big artr or rtr cat
  95. P-mono seaducer setup question...
  96. Black jack 29 6c prop
  97. Economical p mono setup suggestions
  98. FeCalc App
  99. Painting Hardware: Is it bad?
  100. aquamarine ul-1 motor upgrade?
  101. New build need help
  102. Some Advice Needed on an Upcoming Build
  103. FC shocker motor suggestions
  104. perfectly fine ul-1...NOT lol
  105. 4082 on 6-s
  106. Revolt 30 - Motor Upgrade
  107. Want to beat a stock spartan
  108. Newb looking for some advice!
  109. AB marine terminator cat 38 experiences/opinions
  110. Deep v or catamaran
  111. Impulse 31 crack in bow...
  112. What timing for my Feigao 9XLs ?
  113. Looking for Drambuie on Ice Hulls *Pheonix Area*
  114. Record Set
  115. HPR is back in business!!
  116. TP power 4092 amp question
  117. 56" apache
  118. Need help....
  119. Lehner Motors
  120. Allay my fears, or beat me up
  121. BEC on a T180?
  122. Water up the prop shaft. Genesis with offshoreelectric shaft upgrade
  123. Batteries getting HOT
  124. tx and rx question
  125. Teflon liner wont fit into stuffing tube?
  126. What size prop for 21'' sport hydro?
  127. Can I fix an Aquacraft 60amp esc?
  128. Tunnel Hull, please help
  129. Before buying the MLB GP 335 need Help :)
  130. Great Planes Old Wildcat Electric Boat need info wiring it
  131. excel prop chart
  132. Revolt 30 - Grim L45X68- Blown ESC
  133. bec
  134. 1,7m Outerlimits SV43
  135. New boat. YES!!
  136. Update on my pursuit
  137. Sea King 180 esc Timing ? with Leopard 4082 2000kv motor
  138. Talk me about the Prather 32" Racing Tunnel
  139. custom Water blocks
  140. What Prop To Run Delta Force 33
  141. What Prop To Run Delta Force 33
  142. in or out
  143. Max motor; lipo and esc tempature ?
  144. Leapord 4082 1800K or 1600K?
  145. Piano wire drive
  146. T120 esc
  147. shockwave 26 v3 brushed
  148. Zonda cat
  149. Boat gel coat repair and boat painting.
  150. Breaking in bushings question
  151. Got 3 hulls for $85.00
  152. d wind verses y wind on electric motors
  153. Sprintcat 21
  154. bec
  155. whiplash 20 power suggestions?
  156. prop and rudder help
  157. Neu vs Leo
  158. 4s1p or 4s2p in delta force 33 inch "p" spec
  159. Bad day at the lake
  160. 40" mono hull
  161. Does wire drive need greasing?
  162. Prop work
  163. Problem with ICE HV200 and Scorpion 4035-800 Set-up
  164. New RC Boat Magazines
  165. HELP! NEED TO KNOW WHERE TO launch
  166. Where to Buy TP Power Motors
  167. Delta force 41 mono or delta force 36 explorer
  168. Internal resistance
  169. Hobbyking boats
  170. Shopping for my first boat
  171. bec
  172. mean machine offset rudder?
  173. Medusa motors.
  174. Help identifying vintage hull
  175. Picked up a hull but its missing the hatch
  176. Newbie with a question
  177. drive dog grind flat spot
  178. Outerlimits logo
  179. Advice on a Joysway Seafire Super upgrade.
  180. ESC queastion
  181. Cinnabuns first fe discussion
  182. O.S. OB flex cable length?
  183. MHZ usa service?
  184. Recommend a offshore cat for a second boat.
  185. t180 issues...frustrated help plz
  186. Help with tunnel build please
  187. IPhone app
  188. Flush mount water pickup
  189. Protus 520 motors
  190. Water Cooling Question
  191. Rustoleum NeverWet
  192. Can anyone identify this Tunnel?
  193. need help with rescue boat/ convert traxxas blast to brushless for towing
  194. ride pads
  195. Rudder length
  196. to much information
  197. Wanting some input on mod-zenoah v.s. quickdraw pioneer. I know I know, the shame..
  198. Question about motor mount hole spacing
  199. impulse 31 turn fins
  200. Blackjack29 troubles
  201. >>>The June Roostertail is online<<<
  202. Need help with DF explorer
  203. Upgrade motor from stock genesis motor
  204. Traxxas Spartan 67.2 mph run
  205. Cheetah or team believer
  206. Front motor mount water cooling + jacket?
  207. Doh... Cinnabun has no idea what he's doing.. Help rio ep bl conversion
  208. vintage wildcat upgrades
  209. MHZ Mystic 84 cat - need some starting advise
  210. Anybody ever see or use the ebay "Silver Fox" 36" cat hulls?
  211. Delta force 41 build questions
  212. Pursuit chine walking- advice?
  213. Rudder length for a 29inch mono?
  214. Looking for prop selection & ESC
  215. "30 V hull porpoising
  216. Traxxas Blast
  217. SAW ESC question
  218. 8mm or 5.5 bullets
  219. Birdie ESC
  220. battery placement
  221. Rebuild or fix?
  222. finally!
  223. Stiletto hull/hardware/parts
  224. what brass tube for .062 wire drive?
  225. HELP Aquastar 240a esc
  226. 6s lipo 5000mah
  227. Hydro strut question?
  228. Cooling lines on Revolt 30
  229. Team believer 36 motor choice for 6s
  230. Atomik 58 motor upgrade
  231. anyone still using the FC esc,s
  232. cg on mono
  233. CMDI no reply.
  234. Anybody still running a Q-Mono
  235. floatation.....
  236. Etti demon rigger
  237. Fantasim hatch
  238. motor info for thundertiger
  239. Single esc on a twin
  240. oh my goodness... the addiction
  241. Sky Lipo: Good batteries or junk?
  242. help to buy new boat, tfl vs proboat?
  243. Safety net.
  244. Miss Geico 24
  245. Removing Prop Nut
  246. Fithercat esc are they any good?
  247. Set Timing
  248. Tapping Aluminum
  249. Help required on prop selection for 6s rigger
  250. Strut bushings versus bearings
