- T-180 programming
- Stinger length vs rudder length
- Bullet Drive Outboards
- Elect quest from a gas guy LOL
- DF 36 cat or miss geico 29
- Waterproof?
- Wire drive
- Cable vibration
- question for you paint guys,,,,,
- cheetah owners need opinions
- Which water cooling jacket???
- Mixing rudder channel with 2 motors? Is that possible?
- comparing water pickups
- Question about twin build
- 55"shockwave hull any good ?
- CC Hydra ICE 240A - Extremely tight fit for cooling lines
- 6s rigger hull size?
- Thunder Power B/L
- Octura under hull strut
- WTB Apparition boat, tell me what I need to know to do it right please
- What time is practice
- Old School comparison - 700bb vs Astro Cobalt 25 Marine
- Hv esc
- 3/16 speedmaster stinger
- would we do this with our rc boats
- Can't solve the vibration!! Need some help
- Paint removal
- How to rebuild a motor that has been sunk a few times?
- N1 mono survived but, How about N1 Sport Hydro?? Could call it N1 LSH ???
- First Custom Boat Setup
- Flex cable ?????
- New to catamarans
- Wildcat EP Motor cooling
- Bending Stuffing Tube - Stainless or Brass?
- New HPR Hulls Available
- Low KV and high voltage vs high KV and low voltage
- Cooling line question
- looking for a fast 30-40mm jetdrive settup for an 800mm Vhull
- Stinger vs hull length
- question about twins one motor newer than the other
- Esc?
- Actuated trim tabs
- cheetah help needed
- IMPBA, NAMBA, FE Rules Etcetera
- unsure....
- Motley Crew or Miss Geico
- 8s cats whats out there
- genesis advise
- what is the best rudder for hk genesis 1045mm
- what boat to buy? new to boats
- Please someone come up with the tool to put the smoke back in.
- extending wires on ESC,...
- Collet Problems
- Toledo Show April 5-7 Toledo, Ohio
- Advantages/Disadvantages of Hull types
- Best way to polish clear coats question
- AC Boats: R-42 T-Offshore
- help with what make of rudder & bracket I have?
- New OSE Pursuit Hull ?
- Programming questions.....
- Auquastar Motor any experience?
- Ose
- Masking tape for painting your boats?
- Leo 4074
- Primer & Paint question
- ESC/Throttle range help
- Thunder Tiger Outlaw OBL
- esc and battery sparking when connecting
- P-Limited Cat
- 2013 NAMBA Propwash-FE Proposals
- Need a 55v 300 amp ESC?
- Best ESC for PSpec racing ??
- Radek?
- March 2013 IMPBA Roostertail Newsletter is up.
- Outboard elevation on John Starks GP-12V3 tunnel hull ?
- power/speed vs weight of higher C & mah batteries
- What causing this to happen
- water cooling
- Outboard riggers
- Help finding parts
- Floating Square End Flexshaft and Thrust Washer?
- Anyone knows who make this kit?
- Will motor timing affect ESC temp?
- I am so done with cheap Controllers!
- Spartan motor and esc in spartan hull
- Sprtan motor and esc in a revolt on 5s
- thinking about buying this
- motor mount #80210
- Help choosing motor mount.
- fighter cat esc
- team believer aeromarine twin power advice
- stryker motor for my mini boat
- Double check before my first run
- Need help identifying old marine ESC
- Removing heatsink from ice 240?
- Miss Geico 29 V2 Neu 1515
- Genesis RC Boat ESC Recommendations....
- Question on battery setup
- looking for king of shaves decal set
- Center of gravity on mhz mystic 1140
- Going to build a df33
- ESC help
- sv27
- Generator which one to buy?
- Blackjack 29...hydra200...motor suggestions on 6s
- 6s mean machine v3
- Rudder is too loose ?
- impulse 31 turn fin adjustment
- Looking for sport hydroplan plans
- Prop suggestions on a few boats
- Transom plugs for a cat
- Esc upgrade for genesis 1400
- Fliermodels esc
- How to tell if the ESC is toast
- Perfect Hull for a 4074/ 2000
- looking for my first boat
- Help, i need a nut, cant find at a hardware store.
- fighter cat esc
- AC Cat question
- Schulze is out of business!
- impulse 31 motor timing
- New CC ESC or not
- 55" Dumas Scarab build
- Just ordered a hobbywing genesis and need some info on upgrades
- Light weaight carbon fiber?
- Pull-pull linkage connector question
- Blackjack 55 electric build?
- Suggestions or ideas for sealing up thru hole hardware locations
- New build. Setup question
- esc pot temps
- 41"Aeromarine Sprint Cat
- cable grease
- Dumas Donzi z65
- Speedstar Mono 1
- Help! Sport Hydro Lost Speed with new CG
- Stuart Power Boat Races
- 70" fountain central hobbies
- Clear Coats?
- HK Genesis setup Help
- P-Limited Sport Hydro Hull
- twin 90 rigger
- Bushing O.D.
- Best motor for my miss elam 1/12 brushless hydro
- Pursuit Stringer/Upgraded Flex Shaft
- Cheetah question
- do I really need 5.5mm connectors
- Extending esc wires
- Traxxas rx
- TP4040 40mm x 83mm 1450kv
- Stinger - drive dog gap?
- Dare Baracuda
- carbon fiber hull question
- Dallas race May 18-19
- Prop that goes well with A3630-1500 Brushless Motor from proboat
- Hit 60 today
- does this wiring look right?
- cant get new esc to work
- Gas to Brushless 64" bonzi fountain
- Fightercat Cheetah motor question
- Brushless Inrunner vs Outrunner???
- Carbon fiber wrap?
- Consensus - HK no instructions policy
- Coupler/collet Info
- RC Jet boats
- 12s mono
- D2's Thread Lake - Major improvements.
- MHZ hardware
- 1521 1.5D 1900 kv in an outrigger- nprop and battery recommendations
- Motor and Prop Setup for Genesis 6s
- Strange things heard at the Pond yesterday.
- problem buying from kintec racing
- HK Tunnel
- Timing setting
- CC2028 on 12s
- Several rudder and drive line questions
- Servos... Stick with analog or go digital?
- ESC and Lipo Problem
- Geese Control Option?
- Paint for Mystic
- offering from HK
- Thank You Matthias Schulze
- Good esc for a Neu 1527 1D motor
- NAMBA Signup Question -- Newbie
- Female bullet connectors as joiners?
- Threat to R/C Boating?
- "Q" Outboard tunnel discussion. 6S motors and ESC's?
- 3/16 " cable collet
- What diameter prop for Feigo 7s on 7.4v ?
- In your opinion what is???????
- 2.3 to 3.17mm coupler
- Stinger help
- Trying to identify roughly made hull
- Blueprinting a Cheetah hull?
- What is my amp draw
- What would guys think of this boat
- Are my batteries shot, Charger, Or both PROBOAT IMPULSE 31
- cheetah CF inlay
- First run with new motor/esc
- HELP!! with recreational FE tunnel build
- cheetah help
- rc hydros esc (again)
- T180 V1 vs V3
- Cheetah 6S: My first cat!
- Hot setup!!!
- Push and pull cable for 110mm scale rudder
- Marine 120-180A ESC
- Feedback on Hor Racing Zonda 41
- Newbie saying Hi and question about boat purchase
- IMPBA cell voltage question
- I need some ul-1 help
- Which flex shaft fo rREK 3.5cc lower unit?
- ESC Advice
- Central hobbies Mystic 54 build
- Hydro rudder placement
- OSE Mini Ourboard
- Which Would You choose?
- Garmin Forerunner 301
- Jigging of a rigger
- lehner soldering help (tyler)
- Traxxas Spartan about to arrive Monday morning. ..
- HPR 06 help
- Fiddly access help
- RCBB 380a 3-16s HV ESC
- Metal versus plastic prop instability
- flexable vs solid driveshaft question
- Whiplash Strut
- HV CC Cap Pack
- 144 Racers / 457 Boats !!!
- Miss Geico 17"
- Sprint Cat?
- P-Spec NAMBA legal speed controls?
- Mean Machine vs HK Genesis
- Help with MHZ Mystic 1850mm
- Scratch building Deep Vee Mono for the first time.
- What's the most damaging way to to run for your ESC and motor
- Where does stuff from OSE come from?
- Bandit M (COG)
- Help me find a boat for my dad!
- How to connect watercooled ESC?
- Replacing strut Bearing
- Proboat Blackjack 29, my first FE!
- Electric Outboard Motor Mount help!!
- seawing 120a question.
- Should I quit FE?!! Can't take it anymore ! Can't slice CC1515 water jacket on!
- cheetah flex saft size
- Finally cooked my stock esc BJ 26
- ESC suggestions needed
- Anyone evergotten a UL-1 motor that had messed up mounting holes
