- Bec ?????????
- Saw?
- Hatch tape
- plastic debr wrapped around my prob.need helpi
- ESC programming questions
- Motor shaft length - To cut or not to cut
- Cap Packs
- Finding cog
- Rule book update?
- MMP Rapid offset stinger??
- Graupner Eco Manta rebuild
- jae 21 6s
- P mono suggestion
- Help to identify
- Carbon parts
- How many Boats do You have?
- Nitrs VS> FE Oval heat racing?
- Delta Force 26
- Thermal tape
- Happy holidays, thanks Steve @ OSE
- Thunder tiger Outaw jr obl
- Watts question
- motor/esc/battery/prop setup advice
- T-180 issues...not LVC related
- Gathering gear for my new build need reccomendations
- offset rudder
- Fantasm offset rudder?
- zhonda cat
- Speed control/motor combo
- Off topic
- Virginia Craftsman Turnfins are shipping.
- Delta Force Rudder ????
- Hull ID help
- Rebuilding/upgrading my Apparition.
- twin supercat/ prop question really
- Happy Birthday Reed Eagle!
- Titan 29 strut height?
- MeanMachine
- Where is the (cg) on a rigger
- Genesis 3/16" Drive shaft upgrade help
- How to locate a sunk boat ?
- Speed Freak Gen 2
- Hydra 120 Programming?
- 1180 kv outrunner and esc
- Rev limit on Leapord 3650 2450kv
- Question for ManuelW
- Rant
- Bling rocket 25" setup advise
- Advise on stinger position on twin cat build
- MG24 prop size? pitch?
- 47" mono racing spec
- NAMBA membership renewal now online
- fightercat
- Rescue Boat
- TP motors
- p-spec rigger speed
- HPR Scarab. I want one!!!!!
- 6s rigger
- Hk 4074 2000kv
- H&M Xzess III vs Tobsd Poseidon
- 6s 5000 mAh hull?????
- cg question on a cat with a transom overhang
- hurricane mono
- T p motors - problems
- Twin motors on a single esc?
- Data Logging
- space between the shaft and the stingers
- Pursuit 32.5 in hull
- Anyone have machine tooling access?
- Delta Force 35
- fine design 6 pole black nemisis
- Best motor mount epoxy / cement ?
- help needed and lot of it please 40" v hull i believe
- Filling holes?
- Cutting carbon for transom
- Help, 1527 1Y vs 1717 1Y
- all welcome esc help/SF200 plus
- Composite Envisions - Anyone Used Them?
- revolt 30/ ul-1 props?
- Where to Buy
- BEWARE, anouther NOOB question from me
- Need to buy a new Flex Cable
- Super Hawaii 21" brushless conversion questions
- Ricco 31" FE
- hurricane mono
- Looking for better quality body filler?
- Holding motor mount in place
- Rudder travel question?
- Wow this hobby has come a long way....
- What kind of glue for shaft enetering the hull
- Ready for a mainden run
- Gps speedo app?
- HPI flux tork motors 1Y 2200 kv.
- rigger
- esc recomendations?
- 31.6" RC EP FRP Epoxy Fiberglass Sea Arrow ARR Racing Outrigger Boat
- Conquest again
- Fantasm rudder ?
- P-spec rigger weight
- CC/Neu 1515 1Y has excessive rotor endplay - anyone else ?
- Hydro Options
- 2-part foam? Anyone use it?
- Will this work
- Watts by the numbers..
- Speed Difference, 1600KV VS. 1800KV on 4S?
- opinions on a fast stable race cat hull
- HELP with a 26 bling rocket (df 26)
- How to solder bullet connectors
- What paint to use? Mini zippkit jae
- Catamaran thru-hull water intake placement 101
- Solar powered rescue boat
- Stripped set screw
- What type of solder for metal?
- Flex shaft to motor Coupler Question
- Motor recommendation for FE Cobra Tunnel
- Cutting down a flex shaft...
- Turnegy Dlux 250A HV ESC
- what outrunner should i chouse
- Any suggestion to re-wrap a rotor?
- twisted outrigger hull
- flex cable came apart, too weak?
- How about a BBY Oval master?
- DF Vortex 24" speeds????
- Hornet F1
- Strut mounting ?'s
- fater cat double 300 amp hv esc
- 41" Cat HELP
- Waterproofing esc
- Leapord for 1/8th scale
- What happens when the L.V kicks in on Marine ESC's
- g freaks esc question
- Wet ESC survival and throttle input
- Fast Apperition advise
- The investments we make - "Old" Tech - a Blast from the past...
- Chrome BOAT!?
- DF-35 Build Need suggestions
- need wiring help on a Graupner dual motor SYSTEMS
- Painting problems using Tremclad spray paint ?
- Need a hull
- Pros and Cons
- Program card problem
- Gas Sport Hydro FE conversion
- 41" carbon kevlar/fiber catamaran opinions
- Is this a BBY oval master?
- Where can I find that kind of rudder ???
- Cheetah Cracks found
- Brass Tubing
- Need twin .150 shafts to 5mm stubs. Where do I buy one?
- P-Spec Aqua 2030
- Do you have experience with those motors ???
- Boat Stands
- Aquacraft V-24 Gas to Electric Conversion ?
- Setup for Whiplash GV or Backlash
- Motor location question
- Central Hobbies 54" Mystic Sport vs Expresscraft 50" Thunderbolt Cats
- Trin tabs mount question
- Spark arrester.
- Handling issue on pursuit.
- Motor Timing - "D" and "Y"
- Lehner Motor Question
- Esc suggestions
- Water tubing
- Rudder assembly???
- Mg motor and esc ?
- What size ??
- motor mount question.
- Rmck hydrolift 1100
- Correct method for bending a stuffing tube. (yes I've searched)
- What glue do I use?
- HPR Shut Down
- ESC and Motor Setup Help
- Motor cooling question
- Caps for a sk 120a
- Newbie Building a fast electric and needing help.
- Ideal numbers on engine, kv, battery and prop
- 56 in catanaran
- Flex Cable ??????
- What esc to use?
- Question about my new fantasm build 41"
- Lerner 30/80
- Pissed and need to vent
- Plz help
- Anxiously waiting for spring
- Stinger Question
- New Rescue rig.
- Gearbox in a Twin Cat?
- Mystic 29 motor upgrade question.
- West System 205 fast hardener vs. 206 Slow Hardener
- Upgrading the Zonda Cat with new Motors
- Building a predator Outrigger
- need info on esc bank
- Any idea on MHZ Skater BTM?
- help to convert a boat from gas to electric
- Looking for advice
- P-Ltd Offshore. What mAhs are you running. How about RTR Weight
- 2028 water jacket
- Question on setup twin cat
- good esc
- Info for bigger build
- Aeromarine
- Scale Steerable Drives
- motor for genesis
- Anybody use a Flier esc?
- Hobbyking Vanquish Battery/prop configeration
- cigarette electric 38 top gun
- Motor question for my proboat Blackjack 29
- Motor mount for force 22
- Racing hull
- Hpr ct04
- Bulkhead question????
- Esc question
- fantasm SAW anyone?
- Power Supply Question
- Anyone ever seen Stainless steel blindnuts?
- Question on 120 Sward fish
- Cheap/decent hull.
- What boat is this ????
- Soldering 6AWG wires
- Short cooling jacket for Neu 1521
- Speedmaster Strut bushing question
- Runnning Motors at WOT on the bench
- HW 120 ESC setup
- metric stuffing tube to .250 ID strut
- WTB which one?
- Glueing stuffing tube. Epoxy or jb weld?
- How to fix fiberglass that was pulled up when decals were removed?
- Hull Suggestions Please
- what does everyone use for Epoxy when building??
- 29" Hydro...What do I have here?
- Esc, Motor Suggestions
- ML GP400 Sport Hydro with Lehner 2240?
- mmp titus vs watersnake
- Can I do this?
- Clear Coating Wood Tunnel?
- looking for advise
- ESC Question
- Scorpion In-Runners
- Remove Boat Skin Decal
- P-spec hydro speed, using Voltron-2
- Fighter cat Cheetah Build question
- ESC help. Time sensitive
- Powering 55in cat
- Hull Vibration and Resonance Good IDEAS
- Twincat Flex Change
- Delta Force Mini Storm (21.5”)
- ESC's
- Favorite P-Mono motor??
- HK Genesis Twin Hull Build ?'s
- Laying Carbon Fiber
- Let me know what do you think of this
