- Just Asking
- Stinger or strut?
- Fantasm stingers
- What"s the best way to remove motor mounts?
- TP 4082 2180kv timing?
- Pursuit mono with Leopard 4082 Motor
- Where can I find a KB 45 Cooling Sleeve
- i dont understand the timing on a brushless motor
- Working on new ose stickers.
- CC data log results...is this good?
- Any difference between these two kinds of JB Weld?
- Regular strut vs. skeg Strut
- Water lines done what do you think good or bad
- 8mm bullets....OSE brand or Castle Creations?
- sword fish plus data logging trial
- Water tubing size, does it matter?
- Is This Motor An Upgrade? (Thunder Tiger Desperado Jr Brushless RTR)
- DF Pirate first run questions.
- Lehner 3080 owners question
- How to lay stips of fiberglass in catamaran. Need advice!
- Boat Parts Availability
- Cheetah twin build question
- Delta Force Vortex 22
- Jeff wohlt ?
- Speedmaster 1/4 stinger pics
- Shoe Goo/Household Goop
- Need to be able to connect two balancing plugs for data logging
- Post in this thread to win a FREE 100W soldering iron from MaxAmps.com
- Insane boats 34 mono
- scoops on a cat
- Wiring Questions
- Stuffing box .150 cable run with or without Teflon tube?
- Outrunner or inrunner
- Tunnel Hull Advice Needed.
- Trim Tabs and Turn Fins On a Cat?
- Testing audi r8 cat ( see pag 6)
- Beginner, 22" arrow wind hull. Need help!
- What's the longest runtime I can get?
- Delta force explorer single setup
- Transom support
- Is the AMMO 36/88 motor 2,4,or 6 Pole. What hull is it good for?
- Question on taping an area to paint
- Proteus D/Y option motors - reviews ?
- Bronze strut (propshaft) bushings
- FE funny one - when translations go bad!
- Heads-Up for Genesis owners
- epoxy coating
- The right position of the striger.
- HV FlyModel Escs arrived today Pics
- Pics from OPA World Championships Jupiter Fl
- 2013 FE Boat Calendar Time??!!
- Size of drive
- Help with Rigger set up
- Io@10v
- deep vee 32" HOR twin setup ??
- Play/sport boat setup??? Opinions needed
- New district 20 Namba Member Needing to learn brushless motors,esc. Resorces?
- Newbie questions about which big FE to look at...
- Twin Power SOBER
- Prop and drive cable loss.
- Carbon Fiber Hulls - 2.4 radios questions
- big cat
- atomik arc 58" upgrading to 10s possible 12s need help
- New to forum and rc boating
- Michigan Cup 2013 Announcement
- Alert, stolen items
- Catamaran Rudder question
- Who makes an awesome European hydro in the 30" range? Looking for a top performer!
- Acceptable Temperature's
- Switch for esc
- t180 vs sordfish 180hv
- Mods may have to move. 48 hour special
- Epoxy came loose on Aquacraft motor can it be fixed?
- New Stingers for the GENESIS twin setup ??
- Flex cable for a newbie
- Another Dumas Scarab outta retirement.
- Cat trim tab placement post
- TT Outlaw setup?
- Dynamite 80A ESC
- Power for SprintCat
- epoxy dried-any ideas?
- Geico hardware question
- Where can I buy TP Power motors?
- Water pickup
- LeMans Starts and Tri-Ovals Food for thought
- How to estimat amps needed for wattage of brushlee
- Eagle tree
- Need help on what way to go with all the parts I have
- Seaducer hulls
- Miss geico upgrade
- Mounting of twin stingers on a Deep Vee
- ML Boats Sport 40 hydroplane help and some F1 tunnel hull plans please.
- vanquish hull from hobby king
- help wih Zpoxy and wood for sponson mod
- neu 1521 1.5d timing on t180 please
- Aeromarine Sprint Cat 40
- Getting my boat to work??
- Couplers, which wuold be better ?
- Looking for a post.
- Rudder placement question...
- Cheap spec rigger
- how do u set up a rc mono with a stinger
- DF36 cuts out at distance?????
- Preparation of Surfaces for Epoxy Adhesive Bonding
- Bearing for a Leapord 4074 2200kv.
- P Hydro Motor Issue???
- DF Pirate COG setting
- Adhesive for Lexan?
- vanquish boat not bad like they say
- vanquish hull
- Are my motors fried?
- Anybody try these motors?
- Keith Bradley GPS
- Timing questions...
- Painting my first hull.....HELP??
- Help Needed On A Mono Setup
- Mean Machine Struggle
- 50" FOUNTAIN P1 Powerbot
- 30"+ Hydros, options?
- is this even possible
- Anyone solder like a pro?
- Y ore D winding??
- the basis of my name (genesis)
- Too much free play in SpeedMaster's strut?
- The coolest thing I have seen in a long time
- Brushless ~ brushed speed controller
- Mounting William Racing Motor Mount CC 2028 Help
- Stuffing tube.
- Mould making resin question
- Help pls.. Whats the trick to deciding where to drill for stuffing tube?
- Mono rolling help
- Why Don't People Convert Car ESC's For Boat Use?
- rigger
- Here is another new one!!
- vintage flatbottom, looking for suggestions.
- Opinions Wanted Gas F1 Tunnel to FE Conversion take a look
- Winter Project? Need opinions...
- Cen Wave Shark+SV power+some lead weight=FUN and it self-rights
- Has the Delta Sniper 44" ever been used for Saw Trials?
- need some info on a delta foce 29 mono
- T120/cap ?
- help with setup sf300pro
- What clear coat to use?
- Delta force 22 hydro test w/ 7.2 & 14.8
- What is good/reasonable priced 200-300amp HV esc?
- Water - Getting the shaft??
- Need help with picking a mono for my winter build
- What Garmins are used (that are still available) in the boats to check MPH
- Motor sugestions for 1/8 scale Newton Marine Shovel Hydro
- Favorite themes / full size boat graphics
- Gluing Pool Noodles ?
- Motor mounting screws loose
- Kyosho jet stream 888
- Who make's a 56mm dual motor mount?
- is there a "magic formula"....
- Better Hull for Impulse 31 hardware?
- Skeg strut????
- fighter cat esc
- DF Pirate temps
- Does any one have or built a MHZ Mystic Study Mono?
- Whilst visiting some friends in Aberdeen.
- Fightercat heat sink tape?
- Got a good sporty question..
- Inodize paint in spray cans
- vanquish on 6s
- Lipo mounting in a rigger
- Outboard on mono hull
- Maiden run issues
- Shock resistant epoxy?
- Motor Kv and prop selection for twin motors on a 57" Deep V
- Brushless outboard motor?
- what is a good high speed hydro hull for 6s
- Dyeing epoxy with liquid paint?
- 60" plus riggers? How about 72"?
- Need Help! Looking for the best FE mono boat I can get
- Dimensions of Avenger Pro or Conquest Hatch
- looking for a mono-hull plan (or kit)
- HK SRA3000 Radar gun
- OSE Mini Outboard Seizure
- Dumb question of the day...UL1 Motor Screw size?
- Stainless steel screw set
- vanquish issues
- Help identify this motor and speed control???
- Rough water medium mono hull?
- how do you delete a post?
- What Connectors
- Teflon liner question
- Fountain P1 50" / 130cm single motor, I need your setup advice
- birdie 200 amp no bec
- Esc recomendation
- Advice for rtr 50mph+ minimal mods
- esc runs but no power
- need help prohraming 180 seeking esc
- Bushing loose in strut. Both brand new. What to do?
- What waterproof servos do you prefer.
- Ca glue and building question
- Electronics Problem?????????
- Turbo Jet 200esc - should I...?
- Old school Kyosho Hurricane
- Best Starting Boat?
- Stainless stuffing tube
- 5.5 bullets
- HV setup question?
- Cold Water Running?
- American made FE stuff?
- Removing wooden plywood from boat hull - help needed....
- Whats it worth $?
- RC Seadoo
- Alien speedo?
- Rc surfer
- It's been a great four years! Thank you OSE (Steven)
- wallypower 118 plan
- CR. how close is too close ?
- what dia. bolt for SM sting strut
- I need Help
- revolt 30 vs impulse31
- Catamaran CG ?
- Value of a rigger?
- Water Jacket moves under Power.
- Question about setting failsafes
- Still too hot !!
- large catamran Purchase
- OSE Shirts
- Hobby King Customer Service Gets An A+
- Neu replacement for leo 4082 1600kv
- Drive and Video ?
- N2 rigger motor ideas.
- Revolt 30 or Spartan?
- Timing
- Cables and 5.5mm bullets very hot?
- Trying to order correct Drive Wire from OSE.
- Cap Banks.....a few questions
- Another COG question????
- What should i use on transom nuts n bolts b4 painted whilst testing?
- Where to buy....
- High RPM on a 3/16 "flexshaft
- BL Motor SSS 5684 6 Poles 1000kV
- Help with Motor Selection 50' tunnel hull
- Fightercat 2s 6s 300 Amp escs
- Delta Force 33 vs. Pursuit
- P-Ltd. Offshore
- Best RC boat for a 4 year old?
- TP Power water jacket
- Want more speed - top end
- O.S. lower unit FE Conversion
- Need HELP!! choosing a motor for a Mr. Krabs
- Triple outboard??
- What setup for a GENESIS twin?
- Motor Options for 59'' Mono
- Electrified
