View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Timing
  2. Noob here with a few questions
  3. Going with a mono...which hull though?
  4. Speed estimate
  5. Hobby Partz water cooled motor
  6. Broke into the 60's today!
  7. Watts Up analyser or Eagle Tree Data Logger?
  8. temp
  9. T Sport?
  10. HD video camera and mounting
  11. 54"long and 15lbs w/twin outdrives, wants to go at least 60 mph
  12. Lead Teflon or brass bushing for this strut
  13. aquacraft revolt or proboat impluse 2
  14. Motor Placement
  15. Need Product # for T-180a esc CANT FINE IT
  16. Twin t120 escs setup
  17. New Here..
  18. HK Genesis vs R2 36" Catamaran
  19. UBec or not for this situation
  20. Repair REK Leg Threads?!?
  21. Central r/c Hobbies 58" Fountain
  22. Hello Folks
  23. Carbon Fiber
  24. Flexshaft
  25. What is the best way to have 5.5 bullets
  26. Motor/ESC Help
  27. fightercat cheetah hull question
  28. Motor and esc
  29. Neu motors ?
  30. s/f 240
  31. sour grapes with kintec racing anyone?
  32. Strut to dive dog washer clearance
  33. Just brought this thoughts on what mods ive brought
  34. Cooling a 2215
  35. Whats up at FC ?
  36. just dont know
  37. stripping df29 innards?
  38. New HK ESC's
  39. Toysport Syncron Maiden voyage HELP
  40. fightercat 300a ESC
  41. Boat Waxing
  42. Grease
  43. OUTRUNNERS??? and cooling????
  44. Are Aeromarine scale parts still available?
  45. Need a store to buy a T-180 esc
  46. Kyosho Twinstorn VE36
  47. Hello Everyone. Newbie from Wyoming needing some help and advice
  48. Which boat for my son?
  49. burned esc
  50. proboat mystic or FC rivercat
  51. counter rotating flex shaft?
  52. Looking for a Good Kitty
  53. Twiin T120 Rivercat problem
  54. Cutting a Flex Shaft. Need advice
  55. First run 32" R2 hobbies cat
  56. Aeromarine Sprint Cat
  57. Is this ESC any good.
  58. Dual motor mount?
  59. Speed calculator accuracy?
  60. fuse
  61. Stingers for GENESIS Twin setup
  62. Setup for 36 inch rigger
  63. I need your comments on these two boats. I am thinking of getting one.
  64. Servo saver?
  65. GPS Unit
  66. Tunnel hull motor recommendations.
  67. FighterCat 41"Fantasm Twin Motors?
  68. RC boat starts slow then takes off
  69. Motley Crew or Mystic 29
  70. Is the ul1 better then the miss geico .
  71. Watercooling Finned Neu
  72. 1520 and 1717 motors
  73. Help with how water is ran on the t-180 esc
  74. Fighter Cat Racing Close UP?
  75. series connections
  76. Brushless Traxxas Blast - Few questions!
  77. Selling and shipping boats
  78. How to program the esc
  79. Looking for setup for Falcon 41" Cat
  80. High Torque/speed UJ
  81. Z-poxy????
  82. Maintaining brushed motors
  83. 41" Cat Rudder Question
  84. Programming the esc t 180
  85. Shaft Alignment? New to hobby
  86. rudder placement 101
  87. 36' explorer, will it work????
  88. Hobby shops in Hawai???
  89. RTR Cats Day in the Sun
  90. Budweiser Cat from Austraila
  91. 3/8 flex drive
  92. replacement flexshaft
  93. P-Mono Hull
  94. Airdam for shovelnose
  95. Monitoring Temps
  96. Are there special receivers for boats?
  97. Mono hull characteristics?
  98. ESC punch help please
  99. Can someone walk me through a manual set up on a t 180 esc
  100. Newbie in the neighborhood !! Can someone tell me what I have here
  101. Burnt T240
  102. Genesis Pricing, Specs, Recommendations
  103. Locating Teflon Tube Locally-retail uses?
  104. Another T180 Question (sorry)
  105. 90 mph mono
  106. Bullet desoldering?
  107. sv27 strut on df26
  108. "Mini *!**Outboard *!**Motor" *!** First Impressions
  109. Off topic question
  110. Genesis w/Turnigy 180A, Leopard 3270kv, 4s - only 50kph.. Low RPMS.. What is wrong?
  111. POS df 26 wont turn nicely… bout to run this thing over with my car
  112. I need help to find a flex shaft
  113. 1515 1y 6.5mm con
  114. XQ Power Servos
  115. Help with conversion
  116. FC hv esc's
  117. Motor and esc suggestions
  118. Great morning!
  119. New boat!!!
  120. Cyber Storm Hull Questions Racing Set up
  121. Boaterguy Update! have him build your boat!
  122. Graupner Tornado: never run, what would you do?
  123. Any good how to's or ideas on cleaning out a BL motor?
  124. Flex cable stuck in collet!
  125. How do I program the TX after I program the esc
  126. part number for the flex shaft in the genesis boat
  127. sordfish 300a speed controlers
  128. cutting flex shaft material
  129. Three day argument with davie jones!
  130. ESC desoldering! AHHHHHHH
  131. Endbell Heat Sink
  132. Newton plans
  133. Looking for a 30 inch Cat to build.
  134. Stingers for Genesis Twin
  135. how to waterproof transom
  136. Question on 2 part foam
  137. Genesis not running faster than my spartan
  138. Many things have changed in electric racing in the last 20 years.....
  139. Anyone running endurance?
  140. spartan motor in my gensis
  141. Kuddo's to OSE!! But what up with Kintec???
  142. Information on hardware positioning
  143. Mounting hardware in Osprey Hull
  144. Areo Marine Mean Machine.
  145. flex shaft measurments tip to tip
  146. 1/4 flex cable saver
  147. 4082 Rail Mount
  148. What Leak ? The Dog did it
  149. What type and size?
  150. Measuring flex shaft
  151. JAE power
  152. Motor wire lead question/issue
  153. Pistix 5 problem ?
  154. Flex Shaft Lubrication.
  155. Cap Bank ?
  156. fightercat motor question
  157. Build---Paint
  158. Leo 4082 1600 2Y timing question
  159. looking at first RC boat....
  160. Lost Flex Cables
  161. Carbon Fiber
  162. Zonda Cat 41" from Horracing
  163. What is best timing for Fightercat 3126 motor 2200kv
  164. zonda tip and help :)
  165. T-180 Thermaling ?
  166. Shovel nose
  167. Boat hull choices
  168. New Guy Boat
  169. Another way to make parallel connectors w/ the 5.5mm HK bullets
  170. What is another online boating shop?
  171. how do you know what size esc to run ??
  172. Removing Existing Cured Epoxy
  173. I just Quacked Up ; Anyone else Interested ??
  174. Need adjustabe trim tabs recommendation
  175. So cal boaters casting call
  176. This may help some
  177. 2s racing?
  178. A different Genesis question about the hollow pockets under the rear transom.
  179. 36 inch cat.
  180. Any feedback on the SF 300 ESCs?
  181. genesis setups, curious
  182. Low profile stinger?
  183. Why did the U.S. do not make the race electric boats on the triangular course?
  184. HobbyKing order help needed.
  185. HPR 115 Mono (Mystic) or Aeromarine Outer Limits
  186. p-Shoot out update
  187. Ok I'm ready I think
  188. rudder help
  189. Outrigger setup suggestions
  190. Help with repower
  191. Need more speed Plz
  192. New Rules Changed for who ?
  193. Timing on a Leo 4074 2200kv
  194. Hot running help!!
  195. Turbine mono!
  196. did i do ok or just make a newbee mistake
  197. wich motor to go fast with 20" mono?
  198. need advice on newbie boat situation
  199. 2nd boat recommendations ?
  200. What's the difference between these motors
  201. P shootout aftermath
  202. Touch up paint colors for the Genesis
  203. 53 MHZ Drambuie on ice speed's
  204. Advise needed on a mono P spec hull
  205. P-Shootout placements and times
  206. fine 4082 2200kv 1.5y vs O.S.E 4082 2200kv 1.5y ????
  207. Has anyone updated the fe calc program?
  208. This may be the answer to using iPhone as a gos device.
  209. 12s motor 16s HV 200A mp esc
  210. Who races with 1P in open classes (non spec classes) 40" mono setup questions
  211. wich motors for this setup (41" Zonda)
  212. I could use cooling blocks
  213. Which rigger best suited to aquacraft sv27 or proboat 1500kv motor with 45 amp esc?
  214. Out-rigger technical question - dihedral or not?
  215. What brand flex cable collet do you recommend and which do you not.
  216. What type of drive for 40" Dumas Scarab 377 rebuild?
  217. How stupid does the new FCR think i am?
  218. Genesis SAW running gear. What should I get?
  219. T600 Outrunner on 8s
  220. Advice needed on faster motor to replace stock
  221. Painting
  222. Is this motor dead, fried, caput?
  223. Delta Force Pirate 35 on the way.
  224. cooling
  225. Bullet connectors help please
  226. Nitro conversion
  227. Recovery boat electronics?
  228. A pond I'd like to run boats in
  229. help choosing motor esc for 3 boats
  230. Ocean running...
  231. Fightercat ESC settings
  232. Fightercat 16s 200 Amp
  233. Nitro to elec. conversion ?? Pain in the butt or easy ??
  234. SF 300 esc w/datalog.
  235. cog
  236. How Racing Screws Up Everything
  237. Wire????
  238. Help - i really need some advise- conquest
  239. Newbe...
  240. Why are there different length water jackets?
  241. Does Size Matter?
  242. Boat newbee looking for some info. Dont know if im in rite spot????
  243. Bullet Caps ????
  244. gensis powered by castle
  245. Help needed, which plugs and cable area?
  246. corrosion x
  247. Vision tunnel hulls???
  248. 100 + MPH Hulls Who Makes Them Choices?
  249. Midrange price outrunner 1400/1500 kV 500 class ?
  250. OSE Pursuit Mono running hot
